High Pressure Oil Pump / Top End Oil Change - Diesel Forum - TheDieselStop.com
Old 11-26-2009, 08:27 PM   #1 (permalink)
firemediceric's Avatar
While looking for some other information, I found this video: POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
I have owned my truck for over 10 years. I've done all the oil changes and thought I was pretty good about the basic maintenance, but this video presented brand new information that I was completely ignorant about. I was scratching my head wondering how accurate the claim was that the oil in the high pressure oil pump and the oil feeding the injectors did not get mixed well with the oil in the lower end. I proved the issue to to my own satisfaction just today.
I had changed my oil a week ago in the same manner as I always do; drain the pan, remove the primary filter, remove the by-pass filter, put new filters on and put 15 quarts back in. Since that oil change I have put 250 miles on the truck. I would think that would have given the oil plenty of opportunity to circulate through the entire system. I pulled the dip stick today and the oil is still a see through honey color. At this point I followed the instructions in the video and withdrew the oil from the high pressure oil pump. The oil I extracted was as black as coal. Obviously this black oil had not mixed with the new honey colored oil.
This has confirmed in my mind that the claim in the video is accurate. I didn't use the additives recommended, rather I refilled with straight 15-40 oil. I wish I had been aware of this 150,000 miles ago.
1999 7.3 F-350 and 2004 6.0 Excursion
Truck: Tymar type intake, Zoo Dad, muffler delete, By-pass coolant filter, Dahl 100 fuel filter Harpoon & Hutch mod, upgrade to 3/8" fuel line and HP oil X-over, Oil by-pass, Scan gauge II.
Excursion: All stock, so far.
firemediceric is offline
Old 11-26-2009, 08:44 PM   #2 (permalink)
It isn't possible for it to "not mix". The oil supplied to your injectors comes from the HPOP reservoir. The injectors use 7 times as much oil as fuel. The injectors dump their oil into the crankcase. The HPOP reservoir is replentished from the oil pan. You will use about 15 gallons of fuel in 250 miles. That means there has been 105 gallons of oil pumped thru the injectors.
444-4D is offline
Old 11-26-2009, 09:13 PM   #3 (permalink)
I hear what you're saying. Had I not seen it on my own truck with my own eyes, I too would not have believed it. The video spiked my curiousity and now I have proven it for myself to my own satisfaction.
Old 11-26-2009, 09:47 PM   #4 (permalink)
The oil is mixing. The black you found is residual that probably coats the inside of the reservoir. When the engine is first started cold the oil bypasses the filter so unfiltered oil is pumped to the reservoir.
444-4D isn't quite correct about the injectors using 7 times more oil than fuel. The figure is actually much higher than that. All that oil has to come from the pan and recirculate.
Go ahead & change the oil in the reservoir at oil change time- it certainly can't hurt. But don't get worried it has damaged anything by not changing it in the past.
Evel486 is offline
Old 11-26-2009, 10:02 PM   #5 (permalink)
I just watched the link. Would not have believed it either if I had not seen that. I will change the oil in mine.
Buckbuster is offline
Old 11-26-2009, 11:34 PM   #6 (permalink)
Well this is kinda funny. I just did this exact thing this afternoon.
Firemedic.............How much were you able to remove from the pump?
I was only able to remove about 3/4's of a quart.
1999 (early, 10/98) F-350 Supercab 4x4 6-spd DRW limited slip....Drk Tor. Red
4" exhaust, EGT guage, Severe Duty AIS Filter
teesh is offline
Old 11-26-2009, 11:46 PM   #7 (permalink)
mnpowerstroke99.5's Avatar
I changed mine for the first time last spring it was also black as coal.I changed it 3 times like in the video.I always change my oil around 3000-3500 miles and its never as black as the crap I removed from hpop.Now I change it every oil change.I get a little less than a quart each time out of it.
1999.5 F-250, 7.3L powerstroke diesel, extended cab Super Duty,short box, 8'-6" Fisher XTREMEV snowplow,Hypertech power programmer III,Banks Trans Command,Detroit locker in rear end,6 disc cd changer,brush quard,2 1/2" Tuff country leveling kit in front,285/75/16" Pro comp mud terrain tires,Rancho RS9000X shocks
mnpowerstroke99.5 is offline
Old 11-26-2009, 11:52 PM   #8 (permalink)
mnpower...........when you changed it 3 times, does it continue to be black after running for 5 minutes or so like the guy on the video says? Mine doesn't get very dark at all after removing the qt the first time.
teesh is offline
Old 11-27-2009, 02:23 AM   #9 (permalink)
Layson's Avatar
My Photos: (28)
It is normal... you don't need to change out the oil in the HPOP reservoir... it all circulates..
01 F350 CC LB 4x4 SRW,(w/forged rods), 12.5" Lift, OUO Traction Blocks, Dynatrac Prosteer Ball Joints, SPYNTEC Conversion, 40"ToyoMT, 22"MKW M19's, Hybrids, GTP38R 1.15, BTS Chip, Spearco, Headstuds, 910 Springs, 4" exhaust, Coolingmist Water Injection, BTS Tranny, 6.0 Trans cooler, 05' Conv. w/ Mirrors, AFE2, Isspro Guages, ORU Diff Covers, Hella 500s, Transfer Tank, AMP powerstep, Heat Extractor Hood, custom paint, billet badges, Train horns, Recon lights, strobes!
Truck Pics
Old Truck Pics
Layson is offline
Old 11-27-2009, 09:10 AM   #10 (permalink)
i have seen the link changed my oil the next day ran the truck checked the hpop the oil was new the guy says some truck dont seculate the oil as well as others i dont change mine i just look in and see if its new or old oild 40,000 miles sine i seen that link my in still new oil after i put in 15 quarts the truck does hold 18 we all know this and for S and G i have removed the 3 on top but it was new oil so i no onger bother with it i just check to see that it does seculate.
07 raptor 350 jetted and gears pipe (wifes)
03 F150 4x4 5.4 banks stage II 3" exhast (wife's)
03 KTM 250sx scary fast to much to list (mine)
02 F250 4x4 7.3 mostly stock 35's (mine)
02 R6 600cc jetted custom exhust and gears (mine)
00 Z3 2.3 dinen intake and chip (wifes)
87 Quadzilla 500cc scary fast stock (mine)
79 chevy 5.7 425rwhp (mine)
KTM357 is offline
Old 11-27-2009, 10:44 AM   #11 (permalink)
Like you, I was able to remove a little bit better than a pint at a time. I did this over and over again, refilling and letting the truck run in between, until I had removed 3 quarts. Even after I had two fresh quarts in, when I removed the third quart it was blacker than I would like to have seen, but better than I had started with.
Interesting to read the different opinions, but good discussion regardless
Old 11-27-2009, 12:43 PM   #12 (permalink)
This..."Obviously this black oil had not mixed with the new honey colored oil."...is an opinion.
This..."It isn't possible for it to "not mix". The oil supplied to your injectors comes from the HPOP reservoir. The injectors use 7 times as much oil as fuel. The injectors dump their oil into the crankcase. The HPOP reservoir is replentished from the oil pan. You will use about 15 gallons of fuel in 250 miles. That means there has been 105 gallons of oil pumped thru the injectors."... is not an opinion.
444-4D is offline
Old 11-27-2009, 01:40 PM   #13 (permalink)
The first time I changed it,it was pretty black but by the 3 quart it was looking better,but still a little black.Now when I change it,its not as bad as it was the first time I changed it.
Old 11-27-2009, 02:18 PM   #14 (permalink)
I guess from the other experiences posted, I'm not the only one to have experienced seeing the oil in the pan appearing much cleaner than the oil in the HPOP.
Old 11-27-2009, 03:02 PM   #15 (permalink)
JimTJr's Avatar
My Photos: (20)
That guy is a freeking idiot, how can he influence so many people with gibberish? When you change your oil, if you start it and run for any time at all, the "Dirty" oil in the HPOP reservior, flows down into the pan, and mixes with the other 13-15 qts you put in clean. Really, changing that little amount, makes no difference, you better remember to change the oil in the heads too, (Pull them off, drain and flush heads, remove all 8 injectors and drain too).......
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
