Go easy on me. Dealer said its bad and needs to be replaced. I have the extended warranty, but didn't notice it as a covered item. Can someone tell me what it does and maybe I can look it up?
2003 F-250 Toreador Red/7.3/Crew cab/FX4-4x4/285-75-16 Toyo AT/4" Turbo back "Walker"/4" DR spring kit w/DR shocks/6.0 trans cooler/Zoodad/Trans rebuilt @ 120k
I suppose that could be a valid argument, the dealership or warranty company probably won't see it that way. What was wrong with the truck that made you take it to the dealer? HPOPs do go bad, but there are other things more likely to go bad and give similar symptoms.
2000 F-250 Ex.Cab 4x4 Auto with Homemade Intake, 4" Exhaust, DP Tuner Chip, Tugger Kit, 2 HPOPs, ITP Fuel System/Boost Regulator, AC injectors, and Van Turbo/WW
I had a leak. Small one. I have only had the truck for a month or so. Thought it was the main seal. Dealer called said I need the HPOP and cac tube replaced. It was leaking. Nothing more. Under my warranty I see nothing about a "pump" under engine. But, there is "pump" under enhanced fuel system (injection and pump; lift pump and a few other words used). Trying to get my facts stright in case they deny it.
Many leaks can be fixed with a new o-ring. I don't think it is technically an "injection" pump, but it has been called that in the past(by Ford dealers even). I would fight it all the way if they try to deny it.
The part and labor is costly huh? I will. I am just the type of person to fight it, but I like to have all information before hand to carry the conversation. =)
The High Pressure Oil Pump supplies (wait for it) ... High pressure oil to operate the fuel injectors. Leaking should not be a reason to replace it.
CAC tubes are nothing more than steel tubes. Unless they have met a catostrophic event, there should be no need to replace those either.
I believe both are cover under the 100,000 mile/5 yr. warranty. There is a $100.00 deductable.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
I agree, I would take it to another dealer that knows about these trucks, just because the sign says Ford doesn't mean they have a good diesel tech. A leak should be able to get fixed by replacing O rings, unless the thing is cracked?
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
I called the dealer and they will ask the tech. The extended warranty denied the claim. It is on the contract and excluded.
Have them research it again. Does it really say: "the High Pressure Oil pump is excluded"? If they are warranting the engine, and the HPOP is required to run the engine, then it should also be warranted. I once had a service writer claim that a failed water pump (within the drivetrain warranty period) wasn't covered. He changed his tune when I asked him if he would operate his engine with a failed water pump.
But like the other guys said, most likely it's a couple of o-ring seals that need to be replaced.
There is one o ring on the HPOP that is not serviced by Ford or International. It is on the high pressure side and is supposed to be a special part. I tried several Ford dealers and the local International dealer and all came up empty. If that o ring goes out, you stand the chance of running out of oil very fast. There is another posting on this subject where someone pput a standard o ring in it's place and immediatly blew it out. So beware, all HPOP leaks are not readily repairable and a rebuilt HPOP may be the only solution. If I am incorrect on this, please let me know before I install this rebuilt HPOP.
Ron Wilson, 2002 F-250 PSD,4x2, Banks Power Pack, Banks Brake, Built 03/02, BTS Transmission, Garrett Ball Bearing Turbo
1964 Ford Falcon Sprint Convertible, 4 Speed
1963 Ford Falcon Sprint Convertible, 4 Speed
1961 Ford Falcon Sedan Delivery, 302, C-4, Rack & Pinion
2005 Lincoln Avaitor V-8,AWD
They are saying it is leaking internally (on the pump). There is no rebuilt kit available. Rebuilds are done through Ford on the core. Total price (P&L) $1110!
