Horrific Noise when Starting and a Hot Transmission - Diesel Forum - TheDieselStop.com
Old 12-04-2009, 02:16 PM   #1 (permalink)
lone_star_dsl's Avatar
When I started my truck yesterday morning, the engine rolled over twice then the starter (I'm guessing) started making a thumping/grinding noise. The engine rolled over two more times then started. Once it was running, there were no abnormal sounds at all. It was 3 degrees outside and I did not have the truck plugged in.
Since then, it has made the same sound everytime I have started it. This morning it did the same thing even though I hadd the truck plugged in and the outside temps were in the high teens.
Also, I had the transmission flushed about 2 months ago with what I was told was synthetic fluid. Since then, my trans temps have been much higher than they used to be.
I see temps 120-140 degrees above outside ambient air whether I am driving in town, on the highway or plowing snow. Today I was driving home and noticed my trans temp was 170 degrees even with the air temp being 22.
Before the flush, my temps stayed 90-100 degrees above outside ambient air and never climbed over 190.
I will try to get a recording of the noise during starting to give you guys a better idea. It will take a few hours though.
Anyone have any ideas on any of the problems?
2002 F-350 SRW
Lariat, Crew Cab
Long Bed, 4X4
Auto Trans, Tymar Intake
Wicked Wheel, Zoodad Mod
Intercooler Wrap Removal
4" Straight Pipe Exhaust
Recon Smoked Cab Lights
05+ Harley Headlights
6" Upper and Lower Windshield Brows
ISSPRO Gauges, Edge Insight CTS
Acetone Badges
XM Radio, Cobra CB
315 Pro Comp AT's
2010 Elite 20' Dovetail Gooseneck GVW 14,000 lbs
1997 Fleetwood Wilderness 29S
175,000 mostly trouble free miles and counting!
lone_star_dsl is offline
Old 12-04-2009, 02:20 PM   #2 (permalink)
griffy71's Avatar
Sounds like your starter gear may be worn down to the point where it starts skipping teeth on the flywheel. May be time for a new gear, or a new starter
Griffy71
Necessity is the mother of invention.
If it jams, force it. If it breaks it needed fixing anyway.
01 F-250 PSD 4x4 Extended Cab, Bully Dog Chip, Homemade Tymar, AIH delete, Fumoto Drain Valve, Wicked Wheel.
griffy71 is offline
Old 12-04-2009, 02:57 PM   #3 (permalink)
tattoocharlie's Avatar
My Photos: (5)
starter
actually if its grinding prob time to replce BOTH starter and flexplate
2002 f250 lariat 7.3 200k(motor has 170k)
original 4r100 tranny....200k and counting
knock on wood......
tony wildman chip......
stock,economy,daily,towing,extreme,smoke.
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
Old 12-04-2009, 06:39 PM   #4 (permalink)
Well fellas, I guess the starter noise was one of those "auto correcting" problems. Soon after I posted, I went to get a recording of the noise. I cranked the truck and the noise was gone. The truck has been shutoff and re-started four times since without an issue.
The hot tranny is still present though. I was going to the interstate and the temp was showing about 170. Thats 145 degrees above ambient. Soon after, I looked over and the temp was at 130. I know that a slug of cold oil will hit when the cooler valve opens but I had gone about 20 miles before it did anything.
2002 F-350 SRW
Lariat, Crew Cab
Long Bed, 4X4
Acetone Badges
XM Radio, Cobra CB
315 Pro Comp AT's
Old 12-04-2009, 07:16 PM   #5 (permalink)
I wonder if your t-stat is opening correctly in the tranny I'd be taking the truck back to shop. It shoud run cooler with synthetic not hotter.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo. Dieselsite hpop filter, Auto Enginuity program. Dieselsite Adrenaline hpop.
skibarefoot is offline
