How can you check the PCM to see if good /bad - Page 2 - Diesel Forum - TheDieselStop.com
Old 03-05-2010, 07:45 PM   #16 (permalink)
Strang thing, the WTS light worked initially when the truck stopped starting. Then for some reason it stopped working. I checkesd it with a meter when the light stopped coming on and it wasn't getting power through the relay. So I could only figure it had gone bad, or something else was not letting power to it. Well, now since I have removed both the PCM & IDM to check them on another truck (and the other truck started fine with my parts in it) and put them back in my truck, the WTS light comes on. I also checked it again with a meter and it shows the proper reading. It still won't start Do you think I may have a short somewhere, or am I going to have to run down a scanner? So far I haven't been able to locate anyone other than ford. And right now that's out of affordability for me. I live in Allen Texas, just north of Dalls.
Trussell is offline
Old 03-05-2010, 07:57 PM   #17 (permalink)
Excavator's Avatar
My Photos: (11)
WOW, the other truck starts with your PCM and IDM and yours dont.
I still think you have an issue with the connectors or harness on the IDM and or PCM. You may have moved something in the harness just enough and now it has power
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline
Old 03-05-2010, 10:01 PM   #18 (permalink)
Bill1013's Avatar
No start 99 - need help
Trussell
Don't ya just love it when another thread is started for the same problem, all that previous Q&A is all shot in the a$$.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 03-06-2010, 12:39 AM   #19 (permalink)
I have read some of your post from the start, I am no expert but I also have a 99 7.3L, shortly after I bought it I had the some of the same problems, cutting out or stalling in heavy fog or rain, found a good shade tree mechanic that new exactly what the problem was, it turned out to be the cam position sensor on the front of the engine under the water pump (you can get to it from the bottom). After replacing it I had no further problems (around $80). Of course after I replaced it ford recalled some of the 7.3L for faulty cam position sensors. LOL!!!!
sparkies02 is offline
Old 03-06-2010, 05:39 AM   #20 (permalink)
Excavator's Avatar
My Photos: (11)
Yes but look at post #6 and he installed new CPS
Truck Pics
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Old 03-07-2010, 09:31 AM   #21 (permalink)
Anyone haver any more ideas. I have been tracing wires till my eyes are crossed, but can't locate anything that makes any sense. At this point it leads me to belive that it is something electrical. Spraying WD-40 in the intake produces nothing.
Trussell is offline
Old 03-07-2010, 01:23 PM   #22 (permalink)
Spraying WD40 into the intake WILL produce nothing- it doesn't burn.
Looks like you've checked the normal things, next step is a good scanner read by someone who knows how to use it. By all you have described you have an electrical problem. If your friend with the Modus had done a buzz test it would have helped a great deal in the diagnosis.
Evel486 is offline
Old 03-08-2010, 11:35 AM   #23 (permalink)
Thanks for you input. I wish I knew of someone local that had a scanner and knows how to use it. The person with the Modus is a local mechanic I have used for my gas vehicles in the past. That's how I got him to come out and at least run the minimal test he knew how to run in hopes it may be enough to figure it out. If there is anyone out there that has a scanner in the allen Texas area, I would be willing to pay for there time to run the proper tests. Thanks again.
Trussell is offline
Old 03-08-2010, 03:13 PM   #24 (permalink)
SmokeyWren's Avatar
My Photos: (44)
You do. The service manager or one of his techs at your local Ford dealer.
SmokeyWren is online now
