How can you tell if power steering pump is going bad? - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 12-16-2007, 03:18 PM Thread Starter
I dont normally drive my PSD much in the winter but the few time over the last couple of weeks I have noticed a low pitch noise in the cab that seems to sound like its related to turning the wheel. The steering doesnt seem to be any different. Was just wanting to see what you all have experienced.
2000 F350 2wd DRW 6sp PSD Xcab long bed, AFE Intake, 5" exhaust straight back, no muffler, Edge Juice with Attitude, ATS Ported Turbo Housing
170typhoon is offline
post #2 of 18 (permalink) Old 12-16-2007, 04:45 PM
Re: How can you tell if power steering pump is going bad?
Mine's doing that too plus it's harder than usual to turn the steering wheel at low speeds. I suspect it's just a weak pump but I suppose it could be somehow related to the hydro-boost too.
2002, F350, Lariat, CC, LB, PSD, QLJ5, A/T, ESOF(with hub disable switch), LS, Off Road pkg, AIC, Jordan 2020, X-monitor, IAH removed, Fuel pressure shimmed, DP-Tuner 80 econo, acetoned badges, 315 BFG's on Alcoa's, 4"DPPI exhaust, Sonnax/Tricumulator, DIY BIG air filter with ZooDad, Bilsteins, EBV removed, WW, Proflex SS sleeves over the orange manifold hoses, MAP connected to adjustable pressure regulator, EBPS connected to intake manifold, Red line disconnected, Modified factory wastegate, 200 amp large case alternator, AutoEnginuity, Chris Thompson, SoCal Biodiesel Users Group member, Soon to have a bunch of goodies from Riffraff Diesel.
Duzitall is offline
post #3 of 18 (permalink) Old 12-16-2007, 04:47 PM
Check Your Fluid Level. Mine was doing the same thing. When i pressed the Brake or turned the wheel i got a whining Noise... Your Pump is Either going out of is low on Fluid. Mine has been on there since it was new and been turning a set of 40" tires for almost a year now. With 213k Its still Workin like new!
2005 4x4 Lariat F-250 Crew Cab SWB
6.0 Diesel
Stock
Video of Big Red Blowin some smoke!
SOLD-
2002 4X4 Lariat Crew Cab F-350 SWB
Sniper Programmer.
11 1/2" Lift
40" Toyo Opencountry M/T's on 20" Welds
ktyamaha36 is offline
post #4 of 18 (permalink) Old 12-16-2007, 06:08 PM
mine was replaced last week,,,I had no whinning,but the steering at low speeds got worse and worse,,,this affects the brakes as well because of the hydro boost,,,,once the pump was changed everything became normal again,,,139.00 at powerstroke shop
2001 7.3. Lariat...
muffler delete,Isspro guages,AIS,SCMT 1705,CCV Mod,Zoodad Mod
Lone20 is offline
post #5 of 18 (permalink) Old 12-16-2007, 06:29 PM
Chris36, that's the first thing I thought "what the heck, do I have a leak?" but it was not low on fluid.
Lone20, I reckon that's what I need too. I was looking at the AGR superpump for $250. Twice the price for stock but may be better than new. Which turning my 35's was never that great at low speed.
Duzitall is offline
post #6 of 18 (permalink) Old 12-16-2007, 10:21 PM Thread Starter
Ill check the fluid later this week. Thanks!
post #7 of 18 (permalink) Old 12-17-2007, 12:03 AM
Mines doing the same thing. What fluid do I buy?
2001 PSD Excursion 4x4 Limited 7" Superlift Softride lift, 315/75/16 Toyo M/T, Fox shocks, Hellwig rear sway-bar, Air-lift airbags, Autometer Ultra Lite tranny/pyro gauges, DP tuner, Swamps 175/146 single shots, Wicked Wheel, AFE Progard 7, 4" turbo-back exhaust, John Woods tranny w/ 6.0 billet TC, and T/C lock-up switch, Tru-Cool Max tranny cooler. Topped off by Jody's famous tunes.
Audio System: Eclipse 8053 head unit, Arc Audio XXK4050 amp, Arc Audio XXK1500 amp, 6" Morel Integra, JL12w6v2.
WannabePSD is offline
post #8 of 18 (permalink) Old 12-17-2007, 09:01 AM
Have you ever changed the PS fluid?
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 X 7 years / 218K w7.3
Ken1 is offline
post #9 of 18 (permalink) Old 12-17-2007, 10:32 AM
Mobile 1 ATF.....I'm assuming that's auto tranny fluid, right?
Early 99 7.3 F250 Extended cab 4x4 6-speed 200,000 miles DIY intake, MBRP 4" single exit, Isspro EGT and boost, DP Tuner 80 econo flash, South Bend clutch Carbotech Bobcat front brake pads, Door seal and Snowman mods...
Steve91T is offline
post #10 of 18 (permalink) Old 12-17-2007, 11:06 AM
Jinco's Avatar
Yes, tranny fluid. Flushing the fluid made a huge difference in my truck.
Buy Ford. They're not taking bail-out money.
2000
F250 XLT PSD Crewcab, Longbed, 4x4, Auto, LS 3.73
Ford AIS, Frantz Bypass Oil Filter, Baldwin Bypass Coolant Filter, Fumoto Drain Valve, 203* Thermostat, Stancor
Bilstein Shocks all the way around, Timbren SES (Rear), Bridgestone Dueler Revo A/T 265/75/16
Commander Monitor (gauges), Crimestopper CS-2016 DP II FM Remote Start/Alarm/Paging/Turbo Timer/Keyless
Rotella 5W40 Oil
, Texaco ELC Coolant, Mobile 1 ATF Trans and PS
Jinco is offline
post #11 of 18 (permalink) Old 12-17-2007, 04:28 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ken1</div><div class="ubbcode-body">Have you ever changed the PS fluid? </div></div>
Nope...clock has 80K on it and I plan on doing it when I come back from vacation but can I top it off with Mobile1 syn. ATF?
post #12 of 18 (permalink) Old 12-17-2007, 07:55 PM
OK, could someone tell me where the PS fill resivior is? (ducks)
I've never had to look for it.
post #13 of 18 (permalink) Old 12-17-2007, 08:30 PM
Mine has been making a lot of noise lately. I just flushed it and it made a huge difference. The noise is completely gone and the steering feel is actually a little better.
Look for the power steering pump under the alternator. It's pretty easy to see.
Flushing the system is actually very easy. I did that and the oil change in under an hour.
Steve91T is offline
post #14 of 18 (permalink) Old 12-18-2007, 01:13 AM
sirthomas's Avatar
what is involved in changing the fluid
01 F350 Lariat Crew Cab Short Box 4x4,4" Magnaflow turbo back exhaust,K&N air intake,Edge Juice with Attitude,Warn Manual Hubs,6.0 Trans Cooler,B&M Trans Temp Gauge,ATS housing,Turbo Master Wastegate Controller,Banks transcommand,CCV mod,coolant filter
sirthomas is offline
post #15 of 18 (permalink) Old 12-18-2007, 02:41 AM
dtsthx's Avatar
when my truck is in gear i cant turn the wheel without rolling or putting her in nutarel and giving her some diesel pedal
what causes that?
2001 F-350 larait c.c. s.b. 4x4 auto, keenwoodkvt915 in dash dvd 7inch screen ,1 alpine Rtype 12 woofer 1500 watts,pheniox gold mono block class d amp, scorpion BOX, level kit,mr taillight foglight highbeam kit, stock ford 18's on contie's, rancho 9000ES shocks ,6.0 transcooler, derale trans pan ,ccvdiy mod ,zoo dad , powerstrokehelp.com FUEL mods , hood insulation delete ,foil delete , high presure oil x pipe,
DP tuner F-6 = 900rpmEBV, drive-thru tune ,EBV Engine brake tune,40tow ,60 econo, 80econo , supersmoke (use with OD) , 100hp, 120race 140agrresive
, 3 pilier pod , pyrometer, 2trans temps inside tranny/outside ,boost,
diy cold air6637 & 45 degree 4 inch alum.8"x8" , JEG'S 4" downpipe to 5" exhaust flopro 6"tip
, dfuserA.I.H.plug, Extreme diesel Xwheel ,
(commin soon banks technicooler )
dtsthx is offline
