How to change front pump bushing on auto transmission?? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-11-2006, 05:40 PM Thread Starter
My buddy had a real tinny sounding noise, took the truck in and they said that all of his flex plate nuts had backed out, the wife was driving so god knows how long she ran it like that anyway, the tranny is now leaking transmission fluid real bad, we dropped the tranny last week and replaced the front pump seal but that had NO EFFECT on the leak, could the Torque converter be leaking? We have the tranny out again this weekend and we pulled all of the bolts out of the front cover plate but it will not budge do we have to pull the pan to get to the bushing in there??
Thanks for any help!!
97 F-250 7.3
ljg17 is offline
post #2 of 5 (permalink) Old 03-11-2006, 06:30 PM Thread Starter
Re: How to change front pump bushing on auto transmission??
OK the front plate has kind of a build in puller in that the holes are threaded for 3/8 bolts so we got that off, but the bushing didn't look that bad but a lot of tranny fluid was leaking out I hope that this was the problem.
ljg17 is offline
post #3 of 5 (permalink) Old 03-11-2006, 10:50 PM
If the flexplate bolts were loose, allowing the converter to wobble, it would likely wipe out the front pump bushing. A new bushing should fix it, but look carefully at the converter neck.
If it is scored or worn, a new pump bushing will not stop the leak. You will have to replace the converter.
1999 Supercab Lariat longbed 2wd auto, Superchip, Sonnax.
2003 Homestead fifth wheel trailer.
2 Wonderful Boxers and 1 Fantastic wife.
1929 Model A Ford Sport Coupe (Sold it, gone to Wisconsin)
1946 Ford Sedan Flathead hotrod
1953 Ford Sedan Vintage A/C, mild hotrod.
1995 Damon Challenger Motorhome
Tobysdad is offline
post #4 of 5 (permalink) Old 03-12-2006, 05:23 AM
replace the pump and the converter at the same time we did one for around 400 in parts
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission FASS and ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:30s ARB air lockers front and Dana80 rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
OneUp ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
coldair is offline
post #5 of 5 (permalink) Old 03-12-2006, 12:15 PM Thread Starter
Thanks for the replies!
We replaced the pump bushing and now we are trying to get the pump back on, we tried to wiggle it in yesterday with the tranny in the horizontal and that was a no go so we will have to stand it up and use vaseline! (at least that was the advice of another buddy) does anyone have any better ideas to get everything lined up again??? BTW we have a replacement Torque converter and will be replacing that as well, Thanks again for the assistance.
ljg17 is offline
