HOW TO CHANGE IDLE SPEED - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 01-15-2007, 03:57 PM Thread Starter
HOW CAN I CHANGE MY IDLE R.P.M.S., WOULD LIKE TO INCREASE IT APPROX. 50 TO 75 R.P.M.S. TO SOOTH OUT ENGINE?
TJTOM is offline
post #2 of 4 (permalink) Old 01-15-2007, 04:08 PM
Flywheel's Avatar
Re: HOW TO CHANGE IDLE SPEED
Search AIC - Auxilliarry Idle Controller....stock ford part...
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #3 of 4 (permalink) Old 01-15-2007, 05:42 PM
SmokeyWren's Avatar
My Photos: (45)
The idle RPM is controlled by the powertrain control module (PCM), which is the computer that controls the engine and automagic tranny.
Your normal low idle RPM is 680 RPM with auto tranny or 650 RPM with stick shifter. But in cold weather, after a minute or so, the engine will idle at a higher RPM, depending on how cold it is. Click here for some discussion on the cold ambient pkg (CAP).
So the only way to change your idle RPM is to change the computer program in your PCM.
One way to do that is to install the Ford auxiliary powertrain control module (APCM), which is the brains behind the Ford auxiliary idle controller kit (AIC). However, that APCM defaults to 1,200 RPM as the lowest pre-set idle RPM. You can manually set the idle RPM anywhere between 670 and 1,200, but it takes some fiddling with the APCM every time you want to set the idle RPM at less than 1,200.
The only other way is to have a computer programming guru go into your PCM and change the program in the PCM. That's do-able by someone like Jody at www.dp-tuner.com . If you prefer your low-idle RPM to be, for example, 750 RPM instead of 680, then Jody can do that.
Of course, if it's cold enough for the CAP to take over, then your idle RPM will probably be higher than whatever low idle RPM you choose.
SmokeyWren is offline
post #4 of 4 (permalink) Old 01-15-2007, 06:20 PM
klhansen's Avatar
My Photos: (180)
Probably a better approach would be to find out why it doesn't idle smoothly and fix that. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
), AIS,
regulated return,
klhansen is offline
