How to change lpop in 7.3 - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 06-16-2010, 11:10 PM Thread Starter
I have an 02 f550 7.3 and want to change lpop. Does anyone have any instructions or diagrams.
Early 99 7.3 PSD, Reg Cab Long Box, 4" Straight Pipe, A Pillar Quad Pod, Pyro - Boost - Trans Temp - Diff Temp, DP High Idle-40-60-80-100, 5000lbs Rear Air Bags, 5000lbs Front Air Bags, 4000lbs Dump Box Kit (Factory Box), 8'2 Boss V-XT
2002 F-550 Fontaine, Custom Fiberglass Box, 35,000 Lb Goose Neck, A Pillar Quad Pod, Pyro, Boost, Fuel Pressure, DP Switch, DP High Idle, 40 Tow, Jake, 60 Tow, 80 Econo, 140 Smoke, 19.5" Alcoa, F150 Flareside Euro Tail Lights, 8'2 Boss V-XT
cdt79 is offline
post #2 of 13 (permalink) Old 06-16-2010, 11:41 PM
Banned
What kind of shape is the front cover in?
kodaman is offline
post #3 of 13 (permalink) Old 06-17-2010, 07:11 AM Thread Starter
Set comes with pump, haste, and front cover.
cdt79 is offline
post #4 of 13 (permalink) Old 06-17-2010, 07:24 AM
Feedback Score: 2 reviews
He means the engine front cover and if it is scored badly, a new lpop isn't going to help.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is offline
post #5 of 13 (permalink) Old 06-17-2010, 03:43 PM
klhansen's Avatar
My Photos: (180)
You'll have to pull the LPOP to inspect the front cover anyway.
Here's the procedure:
Pull fan off the water pump and remove fan and shroud together.
Remove center bolt from Harmonic Balancer (crank pulley) and pull balancer with appropriate puller.
Unbolt LPOP cover and remove LPOP cover and rotors.
Then you'll be able to see the surface on the front cover that the rotors run against. If it's badly scored, you may need to replace the front cover. The LPOP on these engines is pretty much indestructable, but the weak point is the aluminum front cover that the steel rotors wear against.
You didn't say why you're wanting to change the LPOP. If you're having issues with oil delivery, the problem may be a cracked oil pickup tube in the oil pan. The engine will have to come out to fix that if it's the problem.
), AIS,
regulated return,
klhansen is offline
post #6 of 13 (permalink) Old 06-17-2010, 06:36 PM Thread Starter
I am changing it because I suspect that it is not getting enough oil to hpop. Changed ipr icp cps 8 injectors and still get icp 500 psi, ipr maxed out 65% and throttle of only 2000 rpm at 450 psi icp.
cdt79 is offline
post #7 of 13 (permalink) Old 06-17-2010, 09:17 PM
Did you ever check the op with a real gauge? There is an 1/8 npt port at the back of the block on the driver side.
EDIT-On the trucks I think there is one on the filter housing as well.
rpm1 is offline
post #8 of 13 (permalink) Old 06-17-2010, 09:30 PM
klhansen's Avatar
My Photos: (180)
You're gonna have a new truck soon, changing all those parts.
Try the test for oil aeration. What you do is overfill the crankcase by a few quarts, jack up both rear wheels till till they're about 3' above the ground and start it up. What that does is fully submerge the oil pickup tube, covering a potential crack in the tube that may be letting air into the oil.
The HPOP hates aerated oil.
One more thing - Have you checked your dipstick?
), AIS,
regulated return,
klhansen is offline
post #9 of 13 (permalink) Old 06-18-2010, 11:12 PM Thread Starter
Talking
I have done the Jack up test. None of my jacks would lift the back of the truck. Bobcats wouldn't lift either. So buddy came over with crane and lifted it, no good. Problem is not pickup tube. I tore down the lpop today and found the problem. Truck never seem to have the right amount of power and sometimes the oil pressure for engine wouldn't build up as fast as it should on cranking.
So I tore it down today and found that the rotors had some major damage on it. There was a gouge out of it and some MAJOR scoring in timing cover. Ford wants $875 for new cover and I found one used that I would have to pull out of the truck to find that it may or may not be good. I searched some more and found a cover for $65. New pump gasket and cover $250.
Thanks for help, hope this works.
cdt79 is offline
post #10 of 13 (permalink) Old 06-18-2010, 11:19 PM Thread Starter
Need some guidance on changing front cover tho.
cdt79 is offline
post #11 of 13 (permalink) Old 06-19-2010, 02:28 PM Thread Starter
Is there any special trick to changing the front cover?
cdt79 is offline
post #12 of 13 (permalink) Old 06-19-2010, 11:58 PM
klhansen's Avatar
My Photos: (180)
It just bolts on. The alternator and AC brackets will have to come off to get to some of the bolts. Also, there are a couple of pan bolts that go into the front cover.
The front cover should be installed before the pan, and of course the engine shoudl be out of the truck t do the work.
), AIS,
regulated return,
klhansen is offline
post #13 of 13 (permalink) Old 06-20-2010, 11:59 AM Thread Starter
Guys said that it can be done in the truck by loosening the motor mounts and lifting the front of the motor to access the pan and the pickup bolts?
cdt79 is offline
