How to check turbo condition? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-09-2008, 01:01 PM Thread Starter
detroitfd's Avatar
Hey guys-
I'm planning on ordering a TurboMaster wastegate controller very soon, but am wondering if I might be smarter to get a rebuild kit for the turbo to prolong its life first.
I know I've seen people say to check for play in the shaft and wheel condition. Is this on the compressor side only? I'm not sure if the shaft on the input side is connected to the output side wheel too or not. Do you have to check both sides?
Also, when checking play, are you checking for in/out AND side/side movement? With 95k on the original, I just want to make sure it's good to go.
Also what rebuild kit do you suggest?
Anyone know of a reputable shop in Detroit area for rebalancing?
Any help is appreciated!
Jerry
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, Decel, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ S&B conical filter - Zoodad mod - Suncoast Extreme Duty Trans rebuild w/ TransGo Shift kit, Amsoil synthetic ATF & Magnefine inline filer - BD Triple Disc Billet Torque Converter - 4" Stainless Steel Turbo Back (4" down pipe) Magnaflow exhaust - ATS Turbo housing and 4" intake sleeve - Turbo Master Wastegate Controller - HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter w/ CAT ELC coolant - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge cluster face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub - 4.5" LED marker/turn lights in front bumper - ViAir HD onboard air system w/ 380C compressor, 2.5 gal tank & Grover stutter tone air horn - FireStone RideRite suspension air bags -
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
post #2 of 8 (permalink) Old 02-09-2008, 01:22 PM
Kanman's Avatar
Check play both directions. Any in and out and your turbo is probably shot. Check side to side, a little is ok since the shaft rides on a film of oil. When the engine is not running the oil runs out and thats where the tiny bit of play comes from.
Yes, check Compressor (Intake) side only.
ITP.com offers a turbo rebuild service, although I have zero expirence with it...
Kanman is offline
post #3 of 8 (permalink) Old 02-09-2008, 01:55 PM Thread Starter
detroitfd's Avatar
I saw their kit and service, but I don't have a week to ship it. Plus, I heard the balancing is usually 60-75, so $300 is a bit much IMHO. I'd like to find a local shop if I rebuild it so my downtime is lessened.
Thanks for the pointers. I think I'll pull it into the bay at work now and check it.
Jerry
TOWING:
post #4 of 8 (permalink) Old 02-09-2008, 05:23 PM
Layson's Avatar
My Photos: (28)
Just check for play... and you should be good to go... I think you should be able to install that without removing the turbo. Do you have the map fooler so you don't set off any SES lights...
If there is play. buy a rebuild kit... or upgrade to a ball bearing turbo...
01 F350 CC LB - 14" OUO 525 Series, 38x15.5 Toyo M/T's a 20x12 Weld Cheyenne's. BTS, Terminators, Hybrids...
Layson is offline
post #5 of 8 (permalink) Old 02-09-2008, 05:50 PM Thread Starter
detroitfd's Avatar
No fooler as of yet. The only code I've set so far is the low oil pressure one under WOT in the 80econo setting.
The turbo seems to be performing great, but $150 is cheap insurance against later problems. I didn't get to get in there and look as we got busy. I found a turbo shop in the yellow pages in the Detroit area and left a lessage there to see how much/long to rebalance a turbo.
I might just have the turbo checked when I get the ATS housing put on, and then get it rebuilt later if needed. Just trying to cover all bases. Thanks
Jerry
TOWING:
post #6 of 8 (permalink) Old 02-10-2008, 12:59 PM
NorCalDiesel's Avatar
My $0.02, if you have the turbo off to replace the housing you might just want to get it rebuilt at the same time. You can put the ATS housing on without removing the turbo, I and many others on here have. There is plenty of room. On the other hand getting the turbo out the first time will take a couple hours. Once you get the hang of it you can probably remove it in about a half hour.
When I did the ATS housing, my turbo lasted about another 2,000 miles before it decided that the rear oil seal was finished. When I removed the factory turbo it had no end play and all seemed well. You can't check the oil seal condition without replacing them, so you're guessing that they are good. Instead of rebuilding mine I replaced the entire unit with an aftermarket turbo and sold the ATS housing.
2002 X PSD, Billy Boat 4", AirRaid, Gillett Diesel Service Turbo, High Output turbo exhaust housing, KCM HPX Crossover, ITP Overboost Annihilator, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp
DP-Tuner 6 pos No Start - 140 Aggressive
Thanks Jody and Diane
Super Heavy Duty / Triple Disc 4R100 built by Jim Galatioto at ATO Transmissions in Sacramento.
NorCalDiesel is offline
post #7 of 8 (permalink) Old 02-10-2008, 09:45 PM Thread Starter
detroitfd's Avatar
Where are these seals at? I'm planning on having the ATS put on w/o removing the turbo. Just wondered...
Jerry
TOWING:
post #8 of 8 (permalink) Old 02-20-2008, 11:34 PM Thread Starter
detroitfd's Avatar
Bump? NorCal, looking for more info. I have seen an oring kit for turbo rebuild. Would this cover that? Does the turbo have to come off to replace?
Jerry
TOWING:
