OK, I follow everything you said as it will all affect the end result. One thing you left out was the exact refrigerant charge amount. Do you know what is in your truck (stock is 2 lbs 10 ozs) or did you charge it to a certain value on the gauges? Inquiring minds want to know. I am still hot......
FOMOGO
__________________ 2001 F-250 Lariat, Black, CC, SB, 2WD
304 hp and 627 tq on Dunbars Dyno
2001 F-250 XL standard cab, beater, hauling trash... Stock except for a 60 horse flash...
304hp and 617 tq on Dunbars Dyno
2001 F-250 Xl Standard cab, project truck...
Custom Tunes by DP-Tuner, Custom Fuel System by ITP Diesel, Custom Trans by BTS
In what mode are you guys measureing? MAX,BI LEVEL,etc? It seems to make a big difference with mine. MAX being the coolest of course.
2011 F350 Lariat DK.Blue/Silver,Black Leather Crew Cab,Short Box SRW. Supplemental Heater,3.55 ELD, Remote Starter. Used for hauling 16ft x 8.5ft. Work Trailer , 8ft. Fisher Plow, Lance 820 truck camper for those days I can get away.
Ok Bob, you gotta spill the beans on how to get that temp. I haven't seen temps like that since R-12. Help us hot people out. I already have your valve installed and get about 48 degrees.
FOMOGO
I think Bob needs to hie himself over to the SCPSD get together next weekend and tune up all our A/C units.
Mine blows cold enough for Upstate SC, but I was in Canada last week when it was 100* here. Then again, I ride to work with the windows open in the mornings and the A/C full tilt for the return trip in the evenings.
plainredtruck
'99 F250 7.3L SC SB
Powered by DP-Tuner
No more cupthrowers!!!
Next - ITP fuel system and Stage 1's
Those are some key bits of info that are almost always missing. Those along with ambient temp, engine speed, and fan speed can easily make 20 degrees difference in vent temps. One thing I'm sure of is that idling, fan on high, blowing outside air, and 99 degree ambient temps, Bob Rileys truck will not blow 34 degree air.
ok i also have to ask whats a SSM and what exactly is the importance of this to my 01 truck......all info is appreciated since this 110 heat index garbage is starting to piss me off [img]/ubbthreads/images/graemlins/vomit.gif[/img]
very easy fix for that bro...remove the fan under the hood and take a flashlight and look at your condensor...I am sure it looks like caked mud in your 99...take a water hose with low pressure and spray your condensor off. you may need to simple green it first. the water will drain out the bottom so dont freak...but after its clean it will blow colder and harder than before...in 100 degree heat mine will give me goosebumps in about 5 minutes after leaving a jobsite it has sat at all day...
Tom [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
CTFD
Contact Info.. tom@reynolds-excavation.com
512-762-1485
LATE 1999 F350 CC Dually 2WD,4" stainless Magnaflow.Highly Modified GT38 Turbo
DP-Tuner 4 Pos. chip, PS2000,4" intake with fleetguard filter ,Suncoast Tranny With Triple disc T/C, Lunar Guages
12 Speaker 770 watt Fosgate,Sony and Infinity system with (((XM))), Stull Billet,BFG's and acetoned badges.ART rotors, More to come. 8100lbs.
1/4 mile 14.80 @ 94.24 MPH
2000 Limited 4X4 Excursion Toreador red and tan,(((XM)))Rancho RSX's, Hellwig anti sway,V codes on front, skyjacker dual stabilizer, Edge Evolution AFE with PG7, Eddins House of Diesel 4" Exhaust with Polished 5" tip, Suncoast tranny with triple lock, 15.1" DVD monitor,now rolling Akuza Bounce 20's w/ Toyo 305/55/20 AT's
An SSM is a special service message available to Ford techs and dealership personnel. Kinda like a TSB, but basically they are just engineering summaries for basic common problems that the hotline techs are getting frequent. calls for.
I need a vin to pull them up. [img]/ubbthreads/images/graemlins/smile.gif[/img]
As I recall, their is one for our trucks that states that if the truck has a problem with the a/c blowing warm at freeway speeds that you need to add 1 lb of refrigerant in addition to the amount on the underhood label, it gives a specific charge amount, but as I recall it's about 1 lb in addition to the amount on the underhood and whats listed in the service manual.
18674 1999-2006 F-SUPER DUTY/2000-2005 EXCURSION - LACK OF A/C COOLING - EVACUATE AND RECHARGE THE A/C SYSTEM
SOME 1999-2006 F-SUPER DUTY AND 2000-2005 EXCURSION VEHICLES MAY EXHIBIT A LACK OF A/C COOLING AT HIGHWAY SPEEDS. THIS MAY BE CAUSED BY RAPID CYCLING OF THE A/C COMPRESSOR CLUTCH DUE TO LOW SUCTION PRESSURES. TO SERVICE VEHICLES BUILT BEFORE 7/18/04, EVACUATE AND RECHARGE A/C SYSTEM WITH: - 45 OZ (1.28 KG) OF R134A ON VEHICLES WITHOUT AUXILIARY AIR. - 68 OZ (1.93 KG) OF R134A ON VEHICLES WITH AUXILIARY AIR (EXCURSION ONLY). THE LABEL ON THESE VEHICLES WILL INDICATE A DIFFERENT RECOMMENDED CHARGE LEVEL. ALL VEHICLES BUILT AFTER 7/18/2004 RECEIVED THIS REVISED CHARGE WHEN PRODUCED, BUT THE LABEL HAS NOT YET BEEN UPDATED IN PRODUCTION. FOR VEHICLES BUILT AFTER 7/18/04, AND ALL OTHER LACK OF A/C COOLING SYMPTOMS, REFER TO SECTION 412-00 OF THE WORKSHOP MANUAL FOR NORMAL DIAGNOSTICS.
EFFECTIVE DATE: 06/10/2005
