Which dash vent are you guys measuring the temps in? I have read that the far right (passenger vent) will be the coldest, which makes sense, since it is closest to the AC unit. With OAT in the low 90's, I can get 41 degrees at the "middle" drivers side vent. I haven't tried the passenger side vent yet. I've done the bypass mod and insulated the "cold" lines under the hood.
Roger
2002 F350 XLT, CC, SB, 4x4, Auto, AIC, DiabloSport Predator, BD X-Monitor, Kenwood TM-V7A, Pioneer 7400MP3, Infinity 5.25" Components, Infinity 10" Sub in a Q-Logic Box, Heated Mirrors, Gentex/Mito Auto Dimming Mirror, Rear ID Bar, Uniden PC78 Elite CB, Clifford Matrix RS3 Alarm/Remote Start, Keypad Entry, Homemade "Tymar", custom, muffler back exhaust, 6 Whelen LED's in rear window, 6 Whelen Strobes in the Front, Rears still not installed...
I would like to add something else as a consideration. I work on garbage trucks for a living and something we see very often with them is the evaporator core gets crusted over with crud. The evaporator is cold and (on Mack trucks the A/C thermostat which kicks compressor out has sensing probe inserted into evaporator) compressor cycles excessively. The air coming out the vents is not cold at all - sometimes not even cool. The airflow arcoss the evaporator fins is blocked by the crud which is usually a crusty layer of dirt and lint and such that has stuck to the moist surface of the evaporator on the side the air is blown into. I have saw over 20 degrees temp drop in air outlet temp by cleaning the crud off the evaporator.
The thing is this is not so hard to do on most trucks we have. I realize it would be much harder on most of the pickups we are relating to here. Has anybody ever saw their evaporator core to know if there is a layer of buildup that develops on these as well? It would seem to me to be very probable that the same situtation could be possible especially on high mileage trucks - mine has 208,000 now.
As EXCAV8TER has noted the debris that acculatates in the 3 cores will positively cause A/C related problems and also cause you to have engine overheating problems that happen going up long hills or prolonged hard pulls, then temps drop back down when pulling eases up. I have personally saw this many times especially on high mileage vehicles. Often times people start wanting to replace fan clutches and thermostats when the simple problem is there is a starving of airflow thru the cores to remove heat.
Mike
Mike Lassiter
Recertified ASE Master Medium/Heavy Truck Tech, ASE Advanced Diesel Electronics early 99 F-250 SuperCab 224,000 miles, Banks PowerPak with Power Elbow,Complete 4" Banks SS exhaust Pillar mounted Banks gauges currently running Predator 100 HP program instead of OttoMinder from Banks.Fumoto Oil Drain Valve, SilverStar Headlamps. Engine made on 5-29-98 - My birthday! Must be a sign!
2002 John Deere 4610 Tractor with loader/backhoe attachments
IH TD 9B Dozer
<font color="blue"> 18686 </font> <font color="red">1999-2006 MULTIPLE VEHICLES - A/C PANEL VENT TEMP DIFFERENTIAL
</font> SOME 1999-2006 VEHICLES MAY EXHIBIT A SIDE TO SIDE TEMP DIFFERENCE OF UP TO 10 DEGREES (UP TO 15 DEGREES FOR EXPL/MOUNT). THIS IS NORMAL. IF TEMPERATURE RANGES MORE THAN ABOVE STATED, PLEASE REFER TO THE WORKSHOP MANUAL FOR FURTHER DIAGNOSIS. TECHNICIANS SHOULD VERIFY INTAKE VENTS AND VACUUM LINES ARE CLEAR OF DEBRIS AND PINCHING. FOR DUAL ZONE, CHECK ACTUATOR POSITION PID (BINARY COUNTS). THEN PERFORM RELEARN PROCEDURE OF DOOR POSITIONS AND COMPARE TO ORIGINAL READINGS. IF LESS THAN ORIGINAL READINGS (COLD) OR GREATER THAN ORIGINAL READING (HOT), DOORS HAVE LEARNED NEW POSITIONS AND CONDITION SHOULD BE RE-EVALUATED. CHECK BLEND DOORS/ACTUATORS FOR A BINDING OR BROKEN CONDITION. IT IS CRITICAL THAT THE SYSTEM IS CHARGED WITH THE RECOMMENDED AMOUNT OF REFRIGERANT. DO NOT OVERCHARGE THE SYSTEM.
EFFECTIVE DATE: 06/21/2005
Caution, dont go out and add an extra pound of 134 freon. the 134 systems have to be weighted in, they are very sensitive to the freon level. Gauges usually will only get in the ball park.
Mine will get 38 on the drivers side vent..but I have top-secret AC mods..
BTW-anything below ~37 will start throwing ice balls out the vents..This is a sign that the system doesn't have the right amount of freon in it..
2000 F250 SC 4A SB OEM TC, OEM Trans, OEM Turbo, OEM Injectors, OEM Airbox, OEM CAC, Quad Pod W/4 Autometers, 3 Guage cubby-hole, Jody-isized, Fuel System Mods, Mag Hy-Tec, Schaefers 9000, Transgo, Interior is soundproofed, 3.5" DP SS XL Magnaflow, LPG, 106k miles, NVK5 to MNMO, 2200 WATT BI-AMP, 18"s, Best MPG-22.80, Best MPT-760 miles.
FORD-DIESEL.COM MODS--Heater Hose Cutoff Valve, T/C lock, EBV brake, MIAH Plug, QD's removed, Wrapped CAC Tubes, Double Clamped Coolant Hoses, Zoodad, Relocated License plate, painless fuse box. Other RSB Mods
388HP 818Ft.Lbs.@ 130MPH. 4th gear dyno run, 2.1 60, Home-Made Traction bars.
This is a Street truck, 18+MPG(No LP), 14.2 at 98mph, 13 sec Motor, 14 sec Truck(NO Traction)
2004/03 CC SB Auto 6L W/OCT flash, 19+MPG, 20%Bio, AFE, Magnaflow XL SS 4" Exhaust, 75K, Heater By-pass mod, 21.1 MPG best.
2006.5 Jetta DSG 14K 41MPG Best
2005.5 VW Jetta 1.9 TDI 49MPG Best 73K
Kubota 7800 30 HP Hydrostatic 4X4
All Diesels
1969 Mach1 351C 4M 9"
