How do I tell if the turbo is going bad? - Diesel Forum - TheDieselStop.com
Old 12-05-2007, 04:23 PM   #1 (permalink)
2000 F-450 7.3 375,000 Miles
Heres the problem truck was driving do the highway and lost all power. Check it had fuel and good filter but no oil bone dry crank case. The tailpipe had alittle darker soot than normal not really oilly. I did refill the engine and did start but smoked white. Very similer to when I installed new injector in another truck. Went for a ride and lose about 8qts in about 5 miles.
From what I remember reading on the forum about turbos when it start going out its one of the things that happen before the turbo goes out.
Just wanted to confirm before I go ordering a turbo.
Jack
2000 F-450 PSD, Auto 19.5' Flatbed Wrecker
Mods: PTO Mounted on trans and Trans Gauge, 6.0 Cooler, and Dieselsite Trans Filter Kit
2002 F-450 PSD, Auto WheelLift
Mods: Banks Exhaust, Triple Gauge pod Autometer Ultra-lite (Boost Pryo Trans Temp), FactoryTech Valvebody, Dieselsite Trans Filter Kit
2003 F-550 PSD 7.3, Auto WheelLift
Mods: DiPricol Guages (Boost Pryo Trans Temp, DP Chip (Stock, 40 Tow, 80 Econo), BTS Valvebody, Dieselsite Trans Filter Kit, 6.0 cooler, 4" MagnaFlow XL Exhaust Customized to fit infront of the axle with a 6 inch tip
2004 F-650 Supercab Black Flatbed Cat 7.2 Straight 6 with an Allison Auto
Jacek82 is offline   Reply With Quote
Old 12-05-2007, 04:30 PM   #2 (permalink)
Re: How do I tell if the turbo is going bad?
I think you have bigger problems than a turbo sounds like major engine problem if you lost 8 qts in 5 miles. You need to find out where the 8 qts went to.
2000 Ford F350 7.3 Ext. Cab Auto.
Armboy9589 is offline   Reply With Quote
Old 12-05-2007, 04:31 PM   #3 (permalink)
Its not in the coolant. So that rules out the injector sleeves.
Old 12-05-2007, 04:33 PM   #4 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Chitown_Tower</div><div class="ubbcode-body">Its not in the coolant. So that rules out the injector sleeves.
</div></div>And it's not on the ground or in the valley? That would rule out HPOP leaks.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline   Reply With Quote
Old 12-05-2007, 04:33 PM   #5 (permalink)
Its not leaking on the ground anywhere or dripping out of the exhaust
Old 12-05-2007, 04:34 PM   #6 (permalink)
YOu have one serious problem there. 8 quarts in 5 miles is ALOT. I'd look into something along broken piston rings, in addition to turbo seals, as well as other things...
2000 F350 CC SB SRW 4x2 7.3L
Work in progress...
DP Tuner 4 position chip Stock, 80e, 100p, 140e, 4" magnaflow turbo back, afe stage 2, 4R100 with shift kit/heavy duty clutches
and more to come...
Items waiting to be installed: BDP Stage III Hybrids, Beans Modded H2E
Future mods: BTS trans, fuel system, studs, PULSE HPOP
matthewd11 is offline   Reply With Quote
Old 12-05-2007, 04:37 PM   #7 (permalink)
Does the fuel have any oil in it
Old 12-05-2007, 08:52 PM   #8 (permalink)
The truck is the 201" wheelbase with a pretty long exhaust pipe. I had a chance to talk to driver he said it started slow down and smokeing white out of the tail pipe.
I did however remove the turbo and the valley was pretty clean. But when I took off the turbo apart it was pretty soaked on the compressor side and the turbo shaft did have some play form side to side.
Old 12-05-2007, 08:53 PM   #9 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: matthewd11</div><div class="ubbcode-body">YOu have one serious problem there. 8 quarts in 5 miles is ALOT. I'd look into something along broken piston rings, in addition to turbo seals, as well as other things... </div></div>
Did a compression test and all where pretty even.
Also when I refilled the oil the truck ran fine untill it was low on oil again.
