Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-03-2007, 11:15 PM   #1 (permalink)
FLpowerstroke's Avatar
How do you check for bad ball joints?
Well the subject says it all. Somthing is loose under my front end, I dont know what but definately something. I found my tie rod adjustment sleeve thing was very loose and the tie rod was wobbling around inside, I fixed that but there is still another problem. Also just installed new PS pump & new dual steering stabilizers. It helped a litte but there is still somthing wrong. I thought maybe a bad ball joint(s)?
Early 99 F250 PSD 4x4 Born 03/98, Superchips programmer,warn manual hubs, straight thru exhaust, AIS intake system w/fender foam piece, Autometer full pillar cluster,Euro headlights, In-tank pre-pump & vent tube mods, 3" Trailmaster level kit, fabtech adj track bar, Skyjacker Dual Steering Stabilizers, Rhinoliner, 35" Pro Comp A/T on 17 x 10 Ultras, ART rotors & PF pads w/ATE blue DOT 4,Brand new 4R100 Tranny & 2 coolers w/mobil 1, A/C mod from dieselsite, coolant filter kit from dieselsite, boost tube & over boost valve from black cloud, covercraft seat covers, Redhead Steering Gear,& '93 F150 lightning w/everything!
"Theres never time to do it right but theres always time to do it over" - So true
http://www.community.webshots.com/user/flpowerstroke
FLpowerstroke is offline
Old 02-03-2007, 11:37 PM   #2 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
Re: How do you check for bad ball joints?
Jack the front of the vehicle off the ground. While someone pushes and pulls the top and bottom of the tire, watch the ball joints for movement. Pushing and pulling the tire from side to side will show any slack in the wheel bearings or other steering components.
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum.
Winter Operation (How I Do It)
Hard/No Start? Check here first
2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
Old 02-04-2007, 01:36 AM   #3 (permalink)
if they are really bad the top of your wheels will be leaning in!
squeek417 is offline
Old 02-04-2007, 01:58 AM   #4 (permalink)
Stick a prybar between the knuckle and the housing. Sometimes the push and pull does't tell the whole story.
CEMeyer is offline
Old 02-04-2007, 09:19 AM   #5 (permalink)
Please correct me if I'm wrong here. When I check for loose/worn ball joints I jack up the tire and use a steel bar under the tire to lift it and watch the joints for any movement.
This works for me.
Jimbo
2000 F-350 7.3L 4X4 CC PSD LWB DRW, Diesel Innovations BD-4 Chip, BTS rebuilt Transmission, 5" Exhaust, TC Lock switch, Autometer A-Pillar Gauges, Detroit Locker in back,Air-Lift bags, Dual tranny coolers, Wix Prepump F/W separator, Fumoto Valve, Marinco Plug, Zoodad mod, APC billet grille.
jamming4jim is offline
Old 02-04-2007, 09:28 AM   #6 (permalink)
CPUNeck's Avatar
My Photos: (10)
Yeah this would work, but putting the bar between the knuckle and the axle is easier to see with less movement. You should not be able to move anything under there concerning the ball joints. If it moves, it's bad. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Early 99' F250 XLT SD SC SWB PSD, 4x4 Auto Hubs, Ford AIS, 6leaker OEM cooler, Htr Core by pass valve, Synthetic every fluid (Mobil), Detroit LOCKER, BTS, Lunar Autometer gauges, DI 6-pos chip
SVO Conversion Updated SVO stuff
CPUNeck is offline
Old 02-04-2007, 10:51 AM   #7 (permalink)
Found mine this way ...
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
>202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203º T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
techkdb is offline
Old 02-04-2007, 10:54 AM   #8 (permalink)
Sabre2th's Avatar
Same here...
Black 1999.5 F250SD XLT AUTO 4x4 reg. cab(6/99), Pre-pump & Tank Mods, AFE Intake, Racor Filter/Separator, HX Mod, ZooDad, WW, Power-pedal Mod, Pop-up gooseneck ball,Brush Guard, 3.5" lift, BFG Commercial AT tires (265/75), 65hp ATS chip, and #2 cologne. Ball joints replaced, and thinking about a BTM and shocks....!
Drain valve repair write-up with pics
Sabre2th is offline
