How do you test fuel injectors? - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 02-09-2011, 05:41 PM Thread Starter
I have a 2000 Ford F350 with 7.3 engine, stock. It is very hard to start, seems to crank at half the speed of another 7.3, It has to have block heater plugged in and then must crank on it for a long time, more than once, when it does start must hold pedal off idle, sounds like it has a miss, after a while it will smooth out, but has a sound like open valve coming from air box.
towingbeast is offline
post #2 of 12 (permalink) Old 02-09-2011, 06:22 PM
RT
RT's Avatar
In the truck, you can test them by doing a cylinder contribution test, a buzz test, or by watching the %deceleration (PERDEL) with a scanner. You could also observe the oil flow from individual injectors while the engine is running. Out of the truck, there are injector shops that can bench test them.
However - injectors won't cause a change in cranking speed. That sounds more like batteries and/or starter issues. Also, the miss could be from one or more bad glow plugs.
RT is offline
post #3 of 12 (permalink) Old 02-09-2011, 06:46 PM
xstroker's Avatar
for the cranking problem it could be- one battery is junk, both are weak, parallel battery cable has a loose terminal (pulling from only one), starter issues. how cold is the truck on startup
xstroker is offline
post #4 of 12 (permalink) Old 02-10-2011, 09:22 AM Thread Starter
installed new glow plugs and relay.
thanks
Dan
post #5 of 12 (permalink) Old 02-10-2011, 09:23 AM Thread Starter
temp has been in the low 50's down to low 30's.
Dan
post #6 of 12 (permalink) Old 02-10-2011, 09:38 AM Thread Starter
replaced both batteries, charged to 14.4 volts, cleaned battery connections, checked battery cables on each side of connections for corosion, found none. replaced all glow plugs and relay. even with the block heater plugged in, it will not start now. It sounds like it wants to but will not seem to hit no all cyl, only a couple.
post #7 of 12 (permalink) Old 02-10-2011, 10:27 AM
RT
RT's Avatar
Where are you at? Someone might have AE close by.
RT is offline
post #8 of 12 (permalink) Old 02-11-2011, 08:25 AM
toddman35's Avatar
Do you have any oil leaks from the HPOP fittings?
'11 F250 CCSB Lariat 6.7 FX4
toddman35 is offline
post #9 of 12 (permalink) Old 02-11-2011, 09:47 AM Thread Starter
I am near susanville, ca. Doyle, CA. No oil leaks, oil level is up in hpop. Is it possble that the engine cranking speed is to slow to develope the pressure required for the injectors ?
Dan
post #10 of 12 (permalink) Old 02-11-2011, 10:02 AM
RT
RT's Avatar
Yes - even with good batteries, a bad starter may not be able to get the 100 RPM minimum the truck needs to start.
RT is offline
post #11 of 12 (permalink) Old 02-11-2011, 10:03 AM
itorchedparis's Avatar
Have you replaced the starter? I had a OEM starter that was starting to crap out and would barely turn the engine over during cold weather....I upgraded to a DB high torque starter and HUGE difference in cranking time. You could have the best batteries in the world, but if the starter is crappin out on you, you're gonna be hard pressed to turn the engine over.
2000
F250 7.3L Lariat, Crew Cab/Short bed 4x4. AFE stage II intake. Magnaflow 3.5DP/4" SS exhaust. Isspro gauges (EGT, Boost, Trans Temp) AIH Delete with riffraff boost fitting adapter, Foil delete, Muffler Delete, CCV Mod, Performance tranny from Revmaxx, Revmaxx stage 4 triple disc low stall torque converter, Revmaxx performance valve body with custom shift kit. 6.0 tranny cooler, ported compressor housing, turbomaster wastegate controller, garret high flow outlet, Non EBPV pedestal, dieselsite boot kit, Marinco mod, Fuel Bowl mod, HPX mod, Riffraff Frx, DP F6 tuner (60 tow, 80 econo, 120 race, High idle 1200, Drive Thru) Warn Hubs, Moog Balljoints, 08 tailights, 05-07 front end conversion, 08-11 rear end conversion, Line-xed rocker panels/wheel wells/bumpers
itorchedparis is offline
post #12 of 12 (permalink) Old 02-11-2011, 11:44 AM
firefighter32246's Avatar
I would take the starter off and take it and have it tested . Then I know this sucks specially if you have everything back on the motor but you need to test your UVCH and Valve cover gaskets to make sure you are getting a good connection . You may have a easy fix that just requires a little time and effort to pin point it . THis is if the starter checks out fine . None of these cost money to check just time .
firefighter32246 is offline
