How long does it take for your glow plugs to heat up? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 05-02-2005, 06:53 AM Thread Starter
Mine takes 10-15 seconds every time I get in it. We have a few chevy's here at work (Which is the only comparison I have) and it normally takes one second or less for those. I have an '02 model, so is this normal?
gatkins94 is offline
post #2 of 5 (permalink) Old 05-02-2005, 07:03 AM
Re: How long does it take for your glow plugs to heat up?
They say the Wait to Start light is not tied directly to the actual time the glow plugs are on, in the Cheby's it may be. Though I do notice differences in time that the WTS light is on, but it is probably just not the actual time that the GP are on.
reyjay is offline
post #3 of 5 (permalink) Old 05-02-2005, 07:38 AM
I have noticed that mine stay on longer or shorter depending on outside temperature. But that may just be a fluke.
2001 F-250 4X4 Crew Cab Lariat, 6 Speed, 4 inch lift, 35 12.50 16.5 BFG
kawasaki150hp is offline
post #4 of 5 (permalink) Old 05-02-2005, 08:45 AM
Yes, the glow plugs stay on for up to 2 minutes, regardless of the wait to start light being on or off. The WTS light is supposed to tell you when the cylinders are preheated enough to be able to start, but the glow plugs keep running anyway. If you're really in a hurry to get it started and it's not too cold out, the WTS light can just be ignored... but I have just gotten used to turning the key on, then buckling my seatbelt, and in all but the really bitterest cold weather, the WTS light is out by then.
I guess the Ford method of doing it is pretty confusing, but the simple answer to the original question is "no point in comparing it to how some other brand works"!
Duncan
The 1997 F250HD Crewcab:
The 2000 XLT Excursion <font color="red">(SOLD)</font>:
The 2003 F250 Crewcab 6.0L:
The 6.0L Bible:
The 6.4L Bible:
frobozz is offline
post #5 of 5 (permalink) Old 05-03-2005, 02:18 AM
Flywheel's Avatar
The glow plugs will not even come on whent he oil temp is above 130F - even though the WTS light comes on.
So sure, once you are at operating temp, don't be shy about starting it right up...
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
