How many fuel filters and where? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 10-22-2011, 09:46 AM Thread Starter
callhimup50's Avatar
I would like some direction as to HOW MANY fuel filters my 7.3L has and where they are. Also how often to change, I was told aprox. 20k miles.
2002 F250 Lariat, 7.3 Liter, 4x4, crew cab, short bed, 161,000k miles, rebuilt automatic transmission Mobile One Full Synthetic ATF, 6.o liter trans cooler, ISSPRO EV2 trans temp, pyro, & boost gauges, AIH delete, Air Bags, NAPA 6637 Air Filter, BRP 4" down tube to 4 1/2" exhaust, 285 BFG A/T TA KO2 load range E, camper shell.
Pulling a 30' two axel toy hauler, 2016 shockwave. GVWR of trailer is 10,000lbs.
callhimup50 is offline
post #2 of 7 (permalink) Old 10-22-2011, 09:58 AM
toddman35's Avatar
There is one fuel filter that is in the center of the engine under the plastic powerstroke shroud. 20K should be an acceptable change interval.
There is also a "sock" in the tank that keeps large debris from getting run through the fuel pump. I suppose that could be classified as a filter too.
'11 F250 CCSB Lariat 6.7 FX4
toddman35 is offline
post #3 of 7 (permalink) Old 10-22-2011, 10:14 AM Thread Starter
thanks Toddman35
post #4 of 7 (permalink) Old 10-22-2011, 01:05 PM
woodnthings8's Avatar
Depending on where you buy your fuel. I change mine at 15k, I get my diesel from only high volume stations where the fuel doesn't sit very long. That doesn't guarantee anything, but is better than some of the places around my place that don't move much fuel.
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #5 of 7 (permalink) Old 10-23-2011, 08:02 AM
SmokeyWren's Avatar
My Photos: (45)
You should drain the fuel filter/water seperator about every oil change interval. Change the filter element about every year or so.
If you always buy your diesel from busy truckstops, then the filter element may not need changing for a coupla years or so. In over 11 years of ownership, I changed my fuel filter about 8 times and never had a fuel problem. You can buy new fuel filters for $25 each from
Fleetguard FF5418 Fuel Filter at DieselManor
In the diesel FAQs off the home page, look at the '99-up FAQ. On the left side of the screen there is an index that includes draining/changing the fuel filter on your 7.3L.
The TheDieselStop.Com 1999-up FAQ
That FAQ doesn't do an outstanding job of telling you where the fuel will pour out when you drain the fuel filter reservoir. It is not right next to the yellow drain lever, but instead is a drain pipe (metal tube) that goes from the drain valve and ends halfway down the block on the front of the engine, behind the engine fan. If you simply flip that yellow lever, you'll have diesel all over the front of the engine and all over the ground or floor under the front of the truck.
Most of us old timers permanently installed a foot or so length of plastic tubing onto the drain pipe, so the end of the hose would reach down into the top of a 2-liter Coke bottle or a one-gallon milk jug. After the draining chore, bend the hose up into a hole in the front end somewhere and tie it with a zip-tie so it won't flop around for the next 5,000 miles. If I remember correctly, the drain tube is 3/8th OD, and I used plastic tubing that was 7/16th ID, then a small hose clamp to make it stay on over the years.
SmokeyWren is offline
post #6 of 7 (permalink) Old 10-23-2011, 09:56 AM
I have seen two different fuel filter replacements on the market. One is a canister, that is cheaper of the two, and drops right into the bowl. There is a lid that screws on top of the bowel. There is a tool that I bought from one of the Diesel Stop sponsers that makes removing the lid very easy.
The second filter type has the lid attached to the filter. This one is more expensive because of the lid. It is easier to remove but you pay for the lid which is thrown away.
You have to remove the cover on top of the engine to easily access the filter bowl. There are two nuts that have to be removed to remove the cover. I put the nuts back on top of the threaded bolts that are left standing up. I sliced open my hand doing a filter change years ago.
I get the filters for my truck from my John Deere dealer. My dealer's oil and fuel filter prices are less than the local parts stores, not by much but still cheaper. More importantly, they almost always have the filters in stock. Until I started sourcing the filters from JD, I would make multiple stops at different parts stores to get my filters. Worse case now, the dealer will be out of stock and they will mail me the filters. If I order on a Monday I will have the filters by midweek at the latest. The shipping charge is less than the cost of diesel fuel to get to the dealer.
Later,
Dan
2002 F350 SRW CrewCab, 4x4, PSD, 6 Speed, Lariet, Long Bed, Stock
dmccarty is offline
post #7 of 7 (permalink) Old 10-29-2011, 11:28 AM Thread Starter
Thank you all so much! Your help is appreciated. I will look into draining the fuel filter / water seperator this weekend or next, i never thought to look at the FAQ's area of the site. Hopefully I will get this handeled, I'll keep you posted.
