How much does a 7.3 weigh? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 02-05-2008, 10:48 AM Thread Starter
My Photos: (31)
Just curious on how much it weighs?
Michael
2001 F350 XLT White Crew Cab 7.3L Long Bed * (CCV) Racor 4500 * Fumoto (Oil Drain Valve) * AFE Stage II(Pro Guard 7) * AC control valve * AutoMeter Lunar gauges on the pillar (Pyro - Transmission Temp - Boost) * (TTM) Turbo Temp Monitor * 6.0L Tranny cooler * 6.0L IC * 203 Thermostat * (SS) HX-Hose * Non-Wastegated Van Turbo w/ATS housing & Stock Wheel * Gutted Pedistal * Line X * ZooDad Air * 4" DPPI SS dual exhaust from ITP * Aeroturbine 4040 * Donahoe 2" (mini spring packs) leveling kit * F5 DP Tuner chip with live custom tunes * Brians Truck Shop Transmission (BTS)
Ford Makes It - International Shakes It "FOMOGO"
Humdinger is offline
post #2 of 11 (permalink) Old 02-05-2008, 12:16 PM
I'm sure it depends on the configuration but my '01 super cab long bed is 6033 pounds. Check your vehicle registration - it's probably listed on there.
Basically stock 2001 PSD
MyWyoming is offline
post #3 of 11 (permalink) Old 02-05-2008, 12:35 PM
Are you asking about just the engine? Depending on year, normally a 7.3 is around 1050-1100 lbs.
2002 F-250 PSD shortbed supercab, 4R100, BTS transmission w/ 6.0 trans cooler, 285/75R17s Copper STTs, TS chip (stock,high idle,50 tow,80 tow,100,125), tymar intake, diamond eye 4 inch exhaust, isspro boost, pyro, trans temp guages, firestone ride-rite airbags, light cup-holder mod
fatyesno is offline
post #4 of 11 (permalink) Old 02-05-2008, 12:37 PM
I have a 2002 2wd auto supercab with a cargo box. Full 38 gallon of fuel it weighs 7200 lbs.
PayToPlay is offline
post #5 of 11 (permalink) Old 02-05-2008, 12:39 PM
SmokeyWren's Avatar
My Photos: (45)
If you mean just the wet engine, it's about 960 pounds.
If you mean a wet but unloaded naked truck, a CrewCab 4x4 PSD longbed weighs about 7,400 before you add things such as toolbox, bedliner, stuff behind the seat, stuff in the console, gooseneck or 5er hitch, cooler, etc. An unloaded truck with normal stuff such as the above will scare 8,000 pounds, and most will go over 8,500 pounds with normal driver and passengers and tools, etc. A shorty is about 200 pounds less than a longbed. A 4x2 is more than 400 pounds less than a 4x4.
SmokeyWren is offline
post #6 of 11 (permalink) Old 02-05-2008, 01:57 PM Thread Starter
My Photos: (31)
Yeah just the motor, thanks guys.
Michael
post #7 of 11 (permalink) Old 02-05-2008, 05:17 PM
Michael
International : T444 E
Link above under specifications says that it weighs 930 lbs dry.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: starter, batteries, cps, brakes, tires, alternator, ball joints, AC compressor, serpentine belt.
DonWarkentin is offline
post #8 of 11 (permalink) Old 02-06-2008, 09:20 AM
PSDForever's Avatar
My Photos: (6)
Smokey, curious what a stock V8 gasser would weigh. I've been told that the diesel is several hundred pounds heavier, perhaps as much as 600 lbs?). Anyone have that figure handy for a stock V8 that would be in a F250 or 350?
Dw
LED running lights below doors for turn signals, marker lights, and courtesy lights from JadSolution
FOKISD (Ford, Ohio, Kentucky, Indiana, Super Duty Club), Charter Member.
2001 F-350, PSD, 4X4, True Blue, 152 WB, SRW, Auto Trans, Manual Hubs, PMT3, Off Road Package, AIC, Heated Excursion Tow Mirrors w/cut off switch, Extang Tonneau Cover, Westin Step Bars, Lund Bug Shield, Nifty floor mats, Custom rear bumper/w fog reverse lights & 3rd brake light, LED running lights below doors, Poron USA reverse backup sensors.
"It's mine,ALLLLL mine, (Till Andrea wants to drive it)"
PSDForever is offline
post #9 of 11 (permalink) Old 02-06-2008, 09:33 AM
BMacD's Avatar
Not sure on the weight of the 5.4 but the triton V10 weighs around 635 lbs
Black 2002 F350 ext cab SB
BMacD is offline
post #10 of 11 (permalink) Old 02-06-2008, 05:11 PM
not sure of the weight of the triton engines, but as a base line a small block chevy weighs about 500 lbs., and a big block weighs about 750 lbs.
2000 F250
Maual 4 wheel
4" superlift
315/75r16 Goodyear Wrangler MTR
Straight piped
203 stat and billet housing
Mag-Hytec rearend cover
autometer sport comp guages
170,000 miles
ironworker25 is offline
post #11 of 11 (permalink) Old 02-06-2008, 10:41 PM
Not sure of the weight, but I can pick up and move a small block chevy bare block by myself, I would guess the weight of a complete small block v8, (by how my thumb felt when it got pinched) at somewhere around 500 to 550 lbs.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
