How much horsepower does a 2000 Powerstroke have? - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 05-06-2009, 06:56 PM Thread Starter
Anyone know?
2000 F350 2wd DRW 6sp PSD Xcab long bed, AFE Intake, 5" exhaust straight back, no muffler, Edge Juice with Attitude, ATS Ported Turbo Housing
170typhoon is offline
post #2 of 12 (permalink) Old 05-06-2009, 07:19 PM
Trouble1263's Avatar
If I remember correctly, Stock HP is 245. I may be wrong and I'll about hear it.
Duane
2001 CC LB 4X4 Lariat,Bilsteins,Mile Marker Hubs,Tool Box,V-Box,Yakima Roof Rack,6637,CCV Mod, Isspro Gauges,WW, HPX,Rough Country Steering Stabilizer,THE DP-Tuner W/ NS,DT,S,80E,40T,Decel,60T,120 Race
Trouble1263 is offline
post #3 of 12 (permalink) Old 05-06-2009, 07:20 PM
chuckster57's Avatar
Here's the whole package
Type: Diesel, 4-Cycle Type, Direct Injection
Configuration: OHV V-8
Displacement: 444 cu. in. (7.3 litres)
Bore & Stroke:4.11 x 4.18 in. (10.44 x 10.62 cm)
Compression Ratio: 17.5:1
Aspiration: Turbocharged with Back Pressure Device for warm-up
Rated Power: 210 hp @ 3000 rpm
Rated Torque: 425 lb.-ft. @ 2000 rpm
Total Weight - Dry: 920 lbs (417 kg)
COOLING SYSTEM
Water Flow: 80 gpm @ 3300 rpm
Thermostat Location: In Water Pump Housing
Water Pump: Centrifugal Type
Water Pump Rotations: Clockwise
Fan Hub: Right-Hand Thread
Lubrication System
Type: Full Flow
Capacity (Including Filter): 12 U.S. Qts. (11 liters)
Oil Pump: Gearotor Pump
Oil Cooler: 30 Fins per inch
Lube Oil System: Enhanced for New Injection System
Lube Oil Filter: Microglass - Extender
Oil Filter Motorcraft/Part Number: FL-1995/F4TZ-6731-A
Oil Drain Interval: 3000 - 5000 miles with microglass filter
High Pressure Lubrication System
High Pressure Pump: Gear Driven Swash Plate
Pressure Control: Pulse-Width Modulated Pressure Regulated Spill Valve (EEC-V)
Oil Rails: High Pressure Rails in Cylinder Heads
Oil Lines: High Pressure from Pump to Rails
Lubrication Oil Tempurature: Used for Injection Control Strategy
Fuel System
Type: Electronically-controlled Direct Injection
Supply System:
Pump: Mechanical Tandem: Diaphragm/Piston
Filter: Replaceable Element (FD-4595A/F4TZ-9N184-B)
Return: Flow Regulated
Fuel Delivery And Control:
System: Unitized Injectors
Injector Actuation: Hydraulic/Electrical
Injector Timing: Electronic Controlled by EEC-V (not adjustable)
Fuel Control: Electronic
Diagnosis: EEC Quick Test, Diagnosis with Super Star Tester II, Pressure Gauges
Electronic Engine Controls
System: EEC-V
Injection Control: Injector Driver Module
Cylinder Head
Combustion Chamber Design: Re-entrant Chamber in Piston
Rocker Arm Assembly: Plate-Type Valve Lever
Exhaust Valve Material: Made of Hot Forged 21-2n Material
Fuel Passages: In Cylinder Heads
Cylinder Block
Cylinder Block Material: Cast Iron
Piston Material: Aluminum-Alloy, Cast in Ni-Resist Insert
Integral Combustion
Piston Rings:#1 Full Keystone, #2 Taper Faced, #3 Two Piece Oil
Connecting Rod Design: Forged Steel, Larger Connecting Rod Bore for Wrist Pin, Larger Boring Surface
Piston Pin Bore Diameter: 1.3086 in. (21.45 cm)
Train Horns:
PM please not visitor message
chuckster57 is offline
post #4 of 12 (permalink) Old 05-06-2009, 07:37 PM
1999 and 2000 235hp/500lb-ft
'15 F350 Crew DRW 6.7L Auto 4WD Lariat
Sold '99.5 F350 Crew DRW 7.3 6sp 4WD Lariat
'08 BMW M5 E60 6sp
'10 Subaru Forester 6sp (wife)
manioso is offline
post #5 of 12 (permalink) Old 05-06-2009, 08:04 PM
Originally Posted by 170typhoon View Post
Anyone know?
My valve cover says 235 HP @ 2600 RPM. I see you have a stick shift. Some of the sticks had 275 HP but I can't remember when. It may have been the 01's. Did your truck come with a catalytic converter?
444-4D is offline
post #6 of 12 (permalink) Old 05-06-2009, 08:10 PM
SmokeyWren's Avatar
My Photos: (45)
manioso is right.
chuckster57, I don't know where you got your numbers, but
"Rated Power: 210 hp @ 3000 rpm"
it's not a 2000 7.3L PSD in a pickup, which were rated at 235 HP @ 2,600 RPM and 500 lb/ft torque @ 1,600 RPM.
The PSD in an F-650 and F-750 were rated 210 HP, but only at 2,400 (automagic tranny) or 2,300 (stick shifters) RPM, with torque of 520 lb/ft @ 1,500 RPM.
Maybe your numbers were for one of the options for the similar 444 engine in an International truck? I know they had about 210 HP , but I didn't know they were high reving @ 3,000 RPM to get there.
"Late" 2001s, beginning with production about November 2000.
SmokeyWren is offline
post #7 of 12 (permalink) Old 05-06-2009, 08:17 PM
Mine came from another diesel truck forum..I don't go there and now I know why . Feel free to DELETE my post.
Train Horns:
post #8 of 12 (permalink) Old 05-06-2009, 08:45 PM Thread Starter
So around 275?
post #9 of 12 (permalink) Old 05-06-2009, 08:54 PM
SmokeyWren's Avatar
My Photos: (45)
So around 275?
No. 235 at the flywheel. Less at the rear wheels.
post #10 of 12 (permalink) Old 05-06-2009, 09:14 PM Thread Starter
Gotcha. Thanks for the info!
post #11 of 12 (permalink) Old 05-07-2009, 12:22 PM
The 12 quarts of oil got my attention too.
2002 F350 SRW 7.3PSD Crewcab LB 4x4, 6 speed manual, South Bend Clutch, 3.73LS, Swamps 175/146 Injectors, Hydra Chip, Driven Diesel Regulated Return, BFG All-Terrain T/A KO 295/75 R16 Tires, DiPricol gauges, AIS intake, MagnaFlow 4" exhaust, Power Slot Rotors with Hawk pads, 293K+ miles
RC_02F350 is offline
post #12 of 12 (permalink) Old 05-07-2009, 01:47 PM
kb9snp's Avatar
Yeah, I believe that should be 15 quarts with filter change. But i think the engine actually has a total of 18 quarts if you include the high pressure oil system.
2001 f250 4x4 7.3 PSD
kb9snp is offline
