how often to change glow plugs? - Diesel Forum - TheDieselStop.com
post #1 of 24 (permalink) Old 02-14-2007, 06:04 PM Thread Starter
Fairly new to the truck just curious as to how many miles or years should one go before problems?(changing glow plugs) would like to prevent a breakdown and be left sitting some where.
f-350 2001 7.3 superduty 268000 km
DP chip with F5 switch and tymar intake
4" exhaust with cat delete and Pilar mount gauges
True cool tranny cooler 44'000
pweiler is offline
post #2 of 24 (permalink) Old 02-14-2007, 06:41 PM
Powerstrokedogg's Avatar
Re: how often to change glow plugs?
the glowplugs won't leave you stranded, but the GPR will
i pulled the glowplugs out of a early 99 this summer it had 120,000 miles on it and they were origonal, none of them were bad
i pulled mine out witn 126,000 miles on them and didn't find any bad ones
these glowplugs are 12 volts wich makes them continuous duty once the relay clicks on it stays on, the old 6.9L-7.3L IDIs had 6 volt glow plugs wich heated up a little faster but the relay would have to cycle on and off to keep them from burning out
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
2007 Arctic cat 700 diesel ATV
1975 W900 Kenworth 500 Cummins
1997 Ford school bus 5.9 cummins
Powerstrokedogg is offline
post #3 of 24 (permalink) Old 02-14-2007, 06:59 PM
haul_n_horses2's Avatar
My Photos: (17)
They are not like spark plugs. Only get juice when the PCM instructs the relay to close. As mentioned the relays fail with regularity. I replaced my relay with a Stancor contactor rated to 600 amps peak and 200 amps continuous current. No problems in over about 4 years. I was on my third OEM relay in my first cold winter.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #4 of 24 (permalink) Old 02-14-2007, 07:45 PM Thread Starter
Should a guy pack an extra one with them then and if so how much do they run (relays)
pweiler is offline
post #5 of 24 (permalink) Old 02-14-2007, 07:50 PM
fyrehose's Avatar
what about the California trucks? I think they have some type of module. Why do they not put in a GPR? Is the module supposed to be better?
2001 F250 CC 4X4, 4" lift on 35's
Swamps 250/30%
DP Tuner
Stealth Stage I
JW Trans
38R
PMR's
9.2 @73mph 1/8 mile
fyrehose is offline
post #6 of 24 (permalink) Old 02-14-2007, 08:37 PM
What is the telltale sign of the GPR going bad?
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
DarthSurplus is offline
post #7 of 24 (permalink) Old 02-14-2007, 10:18 PM
klhansen's Avatar
My Photos: (180)
The module was for emissions. It monitors each glow plug individually and sets a code if one goes bad. Like the other guys have said, I've seen very few bad GP's. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
A bad GPR will show up as hard starting in cold weather. More smoke when it does start. Might have a miss initially till the affected cylinder(s) warm up enough from the heat of compression to burn the fuel.
), AIS,
regulated return,
klhansen is offline
post #8 of 24 (permalink) Old 02-14-2007, 10:38 PM
RIP
Just wondering how many GPR's there are on my truck? I'm scheduled to have my glow plugs replaced tomorrow (on the '02 in sig.) and was wondering if it might just be a GPR. I saw two relays on the top of the engine that look like the GPR that was on my old '96 PSD...but there's two of them on this truck! How do I know if I have a bad GPR? It does smoke more than it used to on a cold morning start and idles rough for a minute or so.
MINE: '02 F250 4x4 CC SWB 7.3L PSD, 130k, 4" downpipe and straight exhaust, open-element Amsoil Eaa, Baldwin by-pass filter, 48 gal aux. tank, SCMT 1705 (Tow Safe Level)
WIFE'S NEW: '06 Dodge Ram 2500 SLT Quad 4x4, Cummins 5.9L
[color:"red"] FIGHTIN' TEXAS AGGIE CLASS OF '92 [/color]
RIP is offline
post #9 of 24 (permalink) Old 02-14-2007, 11:20 PM
Flywheel's Avatar
There are 8 glowplugs - one per cylinder.
Change them out as they go bad - I had 2 bad ones for a year - just changed them all out in DEc - and found 2 new ones bad - total of 4. Truck still started fine - little white smoke at 30F.
put a meter on the relay - also, if you just open your dooe at night and turn the key on (engine cold) you'll notice when the dome light gets brighter when the relay shuts off - (from 10 seconds to 2 minutes - but more like 20-40seconds here in Texas)
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #10 of 24 (permalink) Old 02-15-2007, 06:44 AM
as for the glow plug relay theres really no way to tell if its on its way out, one day it just won't work [img]/ubbthreads/images/graemlins/shrug.gif[/img]
post #11 of 24 (permalink) Old 02-15-2007, 08:11 AM
My Photos: (17)
[/ QUOTE ]Do you carry jumper cables or a large screwdriver in your truck? If so you have what you need to start in an emergency. Use the jumper cable between the two large studs on the aft most relay on the passenger side valve cover. If you are brave, you can use the screwdriver to jump the two studs but remember there are a LOT of amps going to that circuit. So it is not necessary to carry a spare GPR. Just put a good one (Stancor) in and forget about it.
post #12 of 24 (permalink) Old 02-15-2007, 10:00 AM
Is the Stancor relay different in some way from the OEM nitrogen-filled relay?
Where do I buy a Stancor relay?
post #13 of 24 (permalink) Old 02-15-2007, 10:04 AM
My Photos: (9)
227k on original GP's and GPR, But then again It really doesn't get cold enough, long enough, here to have to cycle the GP's much. Plus my truck only has 1 cold start per day, and once shes up and purring then off to work we go. I do have many other starts during the day but my engine never gets cold enough for the WTS to come on for more than a few seconds.
1999(05-99)truck, engine (3-99), F-250SD CC SB 4x4, DP Tuner,1.15 van turbo with ATS housing,6.0 IC, ISSPRO guages, AFE big boost filter, Zoodad, SS HPXOVER ,dualCCV, FASS Fuel system,fuel bowl delete, custom turbo back 4" straight pipe split and out the back with dual 5" slash cut tips under the bumper, 305-70-16 Hankook DynaproMT mudders, 02 headlights,lots of electronics, 263,000 + miles
2006 Laredo 30BH 5er wieghing in at just over 11K
bdrummonds is offline
post #14 of 24 (permalink) Old 02-15-2007, 10:14 AM
My Photos: (17)
I would take that sealed and filled with nitrogen with a grain of salt. I would be willing to bet that lasts only a few hours in an automotive environment.
NCHornet bought a bunch at a REALLY cheap price and has them listed in the for sale forum. NCHornet's post Otherwise Allied Electronics, Mouser etc. carry them. Search on Stancor and you will find the links. Put one in and don't look back. There is a pic of it mounted in my gallery. The Stancor is huge. Kanman's pic of the Stancor vs. GPR 109
post #15 of 24 (permalink) Old 02-15-2007, 11:36 AM
Does the Stancor mount to the OEM relay mounts, or did you have to devise your own mounting method?
