How to plumb in a coolant filter - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 17 (permalink) Old 10-30-2007, 08:07 PM
haul_n_horses2's Avatar
My Photos: (17)
Re: How to plumb in a coolant filter
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ponyboychris</div><div class="ubbcode-body">Thanks for the pics, Smokey. I don't know about anyone else but pictures always help me think things through better. That looks very do-able and clean. Did you plumb a water temp sensor to the water pump plug by chance? </div></div>Returning the coolant to the degas tank effectively bypasses the t-stat as well (as I understand it from AutoJim). The return should ideally return to the heater return line. There is no problem putting a sensor in the waterpump port other than the port is 1/4 NPT (IIRC) and most sensors are 1/8 NPT. Where Smokey hails from, the coolant is hot before he ever fires up the engine, LOL. He probably wouldn't notice the difference when the pump is disconnected. Those of you with ball valves in the feed line to the filter can turn the valve off and compare warmup times. It does make a difference, especially when you are starting with a cold soaked engine at 0 F.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #17 of 17 (permalink) Old 10-30-2007, 08:13 PM
My Photos: (17)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ELLIOT02</div><div class="ubbcode-body">I cut my Baldwin coolant filter open and there was no sediment in there.(3,ooo miles)It's probably stuck to the water pump seals! LOL </div></div>It's ok to satisfy your curiosity but normally I just run the filter until the filter no longer gets warm with use ie. it has zero flow. Then change it out. I cannot remember how long that took on my first filter but it was more than 3000 miles.
