How to quiet down my 2000 power stroke - Diesel Forum - TheDieselStop.com
Old 11-30-2006, 11:58 AM   #1 (permalink)
I have a 2000 power stroke with only 38000 miles I bout it new and do not drive it much as I have a company car so it has been babied. My question is my truck is much louder than the newer diesels. I have heard you can quiet them down ( something about the fuel rail). Does anyone have any info on this?
Jim
z71jim is offline
Old 11-30-2006, 12:14 PM   #2 (permalink)
Re: How to quiet down my 2000 power stroke
Regulated Return Fuel system
High Pressure Crossover line for the oil in the heads
Acetone
Synthetic Oil
Engine Oil Defoamer
Acetone
Two Stroke Oil
It will purr like a sleeping baby kitten.
2000 PSD Haulin Hot Rod
Terminator Oil, Big Ole single squirts, BB turbo, custom tuned chip, a lot of other junk to keep it together [img]/ubbthreads/images/graemlins/smile.gif[/img]
thecosmos is offline
Old 11-30-2006, 12:21 PM   #3 (permalink)
what would i do with the acetone and two stroke oil
z71jim is offline
Old 11-30-2006, 12:28 PM   #4 (permalink)
Flywheel's Avatar
My Photos: (6)
Check your torque converter - eraly ones were known to rattle - sounds like engine cackle but can really quite it down.
There is a way to lock the TC when truck is in neutral - if you notice a difference in the sound of the truck - just replace that.
Very hard to distinguish the sound from engine noise - so don't dismiss it....
99.5 F-250 CC LB 4x4 7.3 Red New Pics 1/5/10
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Timbrens, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, DS Boost Relief, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F5, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand Bumpers, Original Cup Thrower, B&W GN Hitch
Autoenginuity
Flywheel is offline
Old 11-30-2006, 12:31 PM   #5 (permalink)
Fuel tank.
It really, really, really quietens the injectors down.
Just a few ounces of Acetone, and maybe half of one of they tiny little jugs of 2-stroke oil on a full tank.
Old 11-30-2006, 02:20 PM   #6 (permalink)
Thanks everyone for the suggestions
z71jim is offline
Old 11-30-2006, 02:26 PM   #7 (permalink)
I found a way to quieten my truck down, selling it, along with replacing drive shaft,fuel pump, two cam sensors, coolant tank, both front bearing assb.,pinion leaking, doors loose, fuel drain leaking, turbo bolts coming out, elec. window motor, bad thermostat, lower goose neck leaking, two batteries, fuel lines sucking air, along with the stumble/miss at 1600 rpm, and now I think I have a bad injector all in 75000 miles. but the ball joints are tight and it steers easy if your appling the breaks. I'm just not going to do all this other bull $h** to quieten truck doun and make it run right I have spent enought that I could have another half paid for. Just had to vent alittle
2000 f250 cc lariet 4x4,tank an pump mods,shimmed fuel reg.70psi,dp F5 stock 40t& 60t
reg2862 is offline
Old 11-30-2006, 02:53 PM   #8 (permalink)
I have a 2000 XLT and I thought it was loud but it gets less noisy when I take it for a good drive 30 miles or so. I have 76,000 miles and the truck runs real good so I'm not going to worry about the noise some diesels make more noise than others and throw fuel into it along with the oil you are using and the air temp and I could go on.Drive it and enjoy it.
2000 SC LB 4x4 auto 373 ltd slip M/hubs
duplex is offline
Old 11-30-2006, 03:18 PM   #9 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
Jim
It will never be as quiet as the newer Cummins and DMaxs and there is nothing you can do to make it so. lots of suggestions but no magic bullet. Some say this helps and other say that. None of them work for everybody. Mine changes from day to day. Fuel quality seems to make the biggest difference. It really don't care for winter fuel.
Throw in a little fuel additive and park beside an older 12 valve Cummins [img]/ubbthreads/images/graemlins/smile.gif[/img]
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
Old 11-30-2006, 04:07 PM   #10 (permalink)
Mine runs quiter went I run fuel additives in it.
2000 F350 PSD SRW Lariat Offroad Blue&Beige CC/LB Auto stock 3.73gears 285/75/16 BFG's
Isspro pyro,trans,and boost
AIS Intake,Walker BTM
that's how PMS starts
71 Bronco 351 W 3sd 4.10gears 33X12 BFG's
aric262 is offline
Old 12-01-2006, 08:58 AM   #11 (permalink)
Do you want to actually quiet the engine down OR do you want to quiet the apparent sound of the engine inside the cab? If it is the later, dynamat applied liberally to around the cab and engine compartment will have a dramatic effect on apparent noise. Somewhere, I read an article about fishing that medical rope (that soft rubber rope they tie around arms when they draw blood) through the door gaskets really has a dramatic effect of quieting the cab down. I like loud outside and quiet inside personally [img]/ubbthreads/images/graemlins/biggrin.gif[/img].
The Hutch mod and HPX mod will help with the noise...the regulated fuel system would help too.
1999 F-350 - CC/LB, gauges, 40K trans-cooler & external filtration & drain, 203 t-stat mod, Mag-Tech Trans & Diff. cover, AIS filtration, zoodad, HPO x-over, Jody Tipton 40HP tow PCM, Hutch mod and harpooned, Baldwin prepump fuel filter
"Better to be judged by 12, than carried by six!"
nlemerise is offline
Old 12-01-2006, 01:13 PM   #12 (permalink)
ELLIOT02's Avatar
You will never quiet your engine as much as the newer ones.That's mostly due to the new pilot injection they incorporate into them.I found that mine runs quiter with a oil crossover line connecting the heads($50)and lower viscosity oil in colder weather.And lots of Dynamat helps too!
'02 Black F-350srw Lariat. 7.3/CC/SB/OR. BTS tranny with 6.0 cooler,coated TN bb1.00 w/Hi-flow outlet,Non-EBP ped,BWD coated/bellowed up-pipes,D.P Tuner.F5(stock,Hi-idle,60tow,80econo,120race),4" SS Magnaflow,BDS stabilizers ,Fluidampr,AFE Stage2w/PG7&pre-filter,Spearco 6.0 IC,PML pan,HPOX,Airdog,ITP reg.return,MAP Maximizer,8 spring front, BFG 315/75/16 AT's,DTS 4.56LS gears,Mag-Hytec cover,Dieselsite SS ESOF lines,coolant filter,203* stat w/billet&Fleetrite,Optix fuel on column,Ultra-Lite trans,pyro,boost on pillar.All fluids Mobil1,Energy polys,Centramatic,Fumoto,Billet,Line-X,Husky box,Extang,EGR,Alpine,Viper,Dynamat,Sirius,PIAA,Hu sky-Liner,Bilsteins. Door ding,overhead console,Snowman,Zoodad,Harpoon,AIH,Marinco,CCV,foi l mods. Hawks and Powerslot cryo's
ELLIOT02 is offline
Old 12-01-2006, 06:47 PM   #13 (permalink)
My Photos: (6)
Quiet?!? Can't hear you over the sound of my DIESEL! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Really, I don't mind the noise in or out. My wife gets company cars from GM, so I get a chance to drive some of their trucks. Actually my 7.3 is as quiet (or quieter) than some of GM's gassers at highway speed. I don't care about the noise around town since it lets people know I'm coming. Enjoy the status.
D
01 250 PSD Lariat; Off Road; SB; Green; Beige Leather; Black Tube Steps; Tonneu Cover;
Reverse sensors; K&N Air Filter; ;Banks Six-Gun Tuner & Monster Exhaust; A-Pilar gauges; Rancho RS9000X; Marinco plug upgrade;Auto Enginuity Scan Tool (Laptop); Truckputer beta installed; Towing 01 Timberland 28FBS; Statpower 20+ charger; 1kw Inverter with auto transfer switch; Custom AV Systemhttp://photos.thedieselstop.com/showgallery.php?cat=998&thumb=1&si=dnr250
dnr250 is offline
