Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-16-2008, 03:49 PM   #1 (permalink)
Supporting Member
HPOP to head lines???
What are the high pressure lines from the HPOP to the heads? What could of connection? Do I need any special tools? How much to replace or repair?
One of them it leaking at the pump side.
Thanks in advance.
Best Regards,
Moxie (from 1828 Noah Webster Dictionary) : The ability to face difficulty with spirit.
2K F350 DRW Lariat 6spd CC White/tan 7.3L, 226k miles, 4" Magnaflow, CCV, SP Diesel, DP-F5, AIH delete, fuel @ 65psi, DIY Tymar 6637 Filter, Fumoto, MAP sensor reg. (fooler)
2K Excursion Ltd Burg 7.3L Auto, 130k miles, 2x4, HX, FX, Fumoto, fuel (66psi), Roof rack delete, DIY Tymar w/ 6637 Filter, AIH Delete, 100HP Diablosport
Late 98 (04/98), 7.3L WHT F250 Std Cab 2x4, 6 spd, Southbend Kevlar bushing, 298k miles, Tank, CCV, HX, FX, Coolant Filter, DynoMax, Shimmed return (67psi)
$$$ Penny glow plugs at AutoZone
Pics
moxyspirit is offline
Old 05-16-2008, 08:53 PM   #2 (permalink)
F350_6's Avatar
The HP oil lines are a quick connect type fitting. The special tool is a U-shaped tool used to push the disconnect so the line snaps off. You can first check to see if you can just tighten the fitting going into the head with a wrench. I've seen 1 leak that was fixed that way.
If not then you'll just need some new O-rings to put in there to fix the leak. The hoses themself should be fine. You'll need Viton 90 O-rings size -906
Chris
2002 F350 6 spd 3.73LS XLT Heated Seats 260,000 & counting.
F350_6 is online now
