HPOP oil leak from plug under high pressure lines (non-user servicable?) - Diesel Forum - TheDieselStop.com
Old 02-26-2013, 03:25 PM   #1 (permalink)
jordanmills's Avatar
My truck is leaking a good bit of oil. After several attempts to find the leak, I finally narrowed it down to a plug on the drivers side of the HPOP just under the high pressure output lines. Is that the non-user serviceable plug that's replaced by diesel orings kit 8-007 at #8-007 Serviceable Replacement HPOP Plug - High Pressure Oil Pump - 1999-2003 Ford 7.3L ?
If that's it, I'm planning to just order the 8-002 with the plug option and engine mounting gasket. Seems that I might as well replace all the seals as long as I have it out.
2002 F-250 black super cab 7.3 L PSD auto trans. 4X4 Lariat with a little lift and mud tires.
Veggie oil system removed while I rebuild and redesign it.
jordanmills is offline   Reply With Quote
Old 02-26-2013, 03:59 PM   #2 (permalink)
Never mind, after reading another manual at the site, that's exactly what that plug is.
Old 02-26-2013, 04:11 PM   #3 (permalink)
RT
RT's Avatar
That's a good idea - much easier to re-seal the whole pump while you have it off. Don't loose that little check ball. You might even consider rebuilding your fuel bowl while you are that deep into it.
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is online now   Reply With Quote
Old 02-26-2013, 04:12 PM   #4 (permalink)
Not a bad idea. I might see if I can make time for that. Thanks.
