I replaced Master & Slave Still not Working - Diesel Forum - TheDieselStop.com
Old 06-03-2009, 07:38 PM   #1 (permalink)
Hello,
So after lots of reading I came to the conclusion that I needed
a pre bled MC & SC set from ford. Put it in... and nothing ! the clutch feels
great ! but doesn't do anything ! I push it in and out and it feels like normal.
How it all started was I was parking the truck at a store and the peddle just
went to the floor. I talked to people at ford , read everything I could online
and it sounded like that was the problem. The only other thing I can come
up with is ... some how I put it in wrong ? ... Or ... the the clutch fork is bent/
broken. The only reason I thank that the fork is not bad is that I'm not sure it
is an issue on an early '99 ( it's really a '98 ) but at this point I'm very upset
and low on funds. So if ANY ONE can shed some light on this I
will be for ever grateful and will name my next child after you if you can tell
me what the deal is or at least point me in the right direction !
rockdrill is offline
Old 06-03-2009, 09:32 PM   #2 (permalink)
calico5string's Avatar
My Photos: (14)
There was an issue with a batch of trucks that had defective throw-out forks. As I recall, they were made in such a way that they had a weak area in them, and after a lot of use, would bend or break. The new, replacement forks (from Ford) are of an updated design, and stronger in the subject area.
Sorry to give you bad news...but it sounds to me like you may need to pull the trans and check it out. Maybe you've got a bad clutch, too (?).
Good luck
Al in SoCal
2000 F350 SRW CC 4X4
AFE Stage II w/PG-7
Garrett 38R Turbo
Swamps Stage II Single-shots
Stealth Dual-HPOP
ITP Custom-modified Regulated-return Fuel System
DP-Tuner PCM & F-5 chip (Live tuned!)
Autometer Gauges (Pyro, Boost, Eng oil temp)
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
4" Custom S/S Exhaust into 5" Dual Aussie Stacks
ZF 6-Spd "Hand-shaker"
Southbend Double-Disc clutch
...plus some other goodies...
calico5string is offline
Old 06-03-2009, 09:42 PM   #3 (permalink)
VTRedSled's Avatar
My Photos: (12)
I have a March '09. Last year my fork went, pretty much broke in half. You can tell by measuring the distance from the housing to the contact point on the fork vs the length of the slave cylinder rod. I don't know the exact measurement, but if its longer than the slave rod, I would think it's shot. It was not that bad to replace.
99 F250 Super Duty,7.3L Turbo, 4x4, Manual
89 F350 7.3L, 4x4 C6
VTRedSled is offline
Old 06-03-2009, 10:55 PM   #4 (permalink)
not sure if this may help you or not... i ran into that same prob with a ford ranger a while back i like to drove me crazy! some ford mc have to be "pressure blead" there is a kit you can buy to do this but if you are really careful you can drill a smalle hole in the top of the reservoir and put a SMALL amount of air to it while someone is under the truck working the bleeder valve. watch your fluid (it drains fast) and no more then 5 or 10 psi otherwise the cap will blow off and brake fluid goes everywhere! remember brakefluid eats paint!!! its worth a try... if you have any more questions pm me
02 F-250 7.3 Lariat 4X4 4" manaflow Exhaust, AFE stage II intake, Industrial Injection 530 Hybrid injectors, Comp Cams cam, valve springs and solid pushrods, ARP Head Studs, H2E modified turbo kit, Boost fooler, HX hose, Adrenaline HPOP, FASS Fuel System, DI regulated return, DI intercooler, DI 6 poss chip, Circle D billit triple disc converter and full billit trans, Auburn lockers (front & rear), Forged rod & Piston short block, Fluidampr balancer, HP????? going to bts for dyno tuning in mid june... Wanna Play??
JoshJMW is offline
Old 06-03-2009, 11:58 PM   #5 (permalink)
My Photos: (14)
Originally Posted by JoshJMW View Post
some ford mc have to be "pressure blead" ...put a SMALL amount of air to it while someone is under the truck working the bleeder valve.
The Super duty clutch hydraulic system is all plastic. There are no bleeder valves in the system.
Ford does sell a pre-filled, pre-bled assembly (I think that's what the OP purchased and installed) which is highly recommended if you need to do any work on the system.
There is a factory in-vehicle bleeding procedure, but it's a PIA, and really does not work very well. But here it is:
Al in SoCal
AFE Stage II w/PG-7
Garrett 38R Turbo
Stealth Dual-HPOP
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
Old 06-04-2009, 02:56 AM   #6 (permalink)
klhansen's Avatar
My Photos: (169)
Originally Posted by rockdrill View Post
Or ... the the clutch fork is bent/broken. The only reason I thank that the fork is not bad is that I'm not sure it is an issue on an early '99 ( it's really a '98 )
The early Superduty trucks WERE the ones with the weak clutch fork. I have a 1/99 build (99.5) and when I changed the clutch I bought the newer fork and put it in, even though that wasn't the issue with my clutch. The new fork was definitely beefier than the original.
I'm guessing that the fork is your problem, and as the other guys said, you should be able to remove the slave and check for depth to the fork.
Hard or no-start? Check Here
klhansen is offline
Old 06-04-2009, 04:39 PM   #7 (permalink)
My Photos: (19)
To the OP... you said that after the prebled unit install you had what felt like proper pedal and it all seemed to work other than the clutch just wouldn't disengage? That would sound to me like a pressure plate or spring issue. No?
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 06-06-2009, 01:14 PM   #8 (permalink)
Thank You all for the in put I have been out of town for a few days
on work. So first I will try and check the slave cylinder opening on
the trans. and see if thats the issue, It seems like a lot of work to
pull the trans. in the driveway, to replace the fork ( if thats it )
so I might call around at see how many millions of dollars it would
take to have a shop do it.
Thanks Again for all the info.
