ICP Sensor leaking - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 02-17-2017, 11:19 AM Thread Starter
ICP Sensor leaking
2002 F-350SD, 7.3L. Can someone tell me what the part is that the ICP screws into? Mine is stripped and spraying oil.
tonycvfd1 is offline
post #2 of 4 (permalink) Old 02-17-2017, 12:28 PM
klhansen's Avatar
My Photos: (180)
If the threads are truly stripped where the sensor screws into, you'll probably need to replace the cylinder head. Ouch!
But before you do that, inspect the sensor threads themselves and be sure it's not whats stripped. It could just be the o-ring that seals the sensor where it screws into the head. Does the sensor actually tighten into the port or spin free?
If it is the cylinder head that's the problem, a hydraulics shop may be able to repair it with an insert pressed into the port after it's machined out to accept the insert. I don't think that a helicoil would work, as the top end of the threads would be too rough to form a good seat for the o-ring. The specs for an SAE boss o-ring connection call for a smooth taper at the top of the threads. Maybe the shop could cut a larger groove and use a fatter o-ring than the stock one.
Welcome to TheDieselStop
), AIS,
regulated return,
klhansen is offline
post #3 of 4 (permalink) Old 02-17-2017, 03:36 PM
greenskeeper79's Avatar
timesert but I'd be worried about the shavings getting into the high pressure oil system.
There are other ports you could use for the ICP, but you'd still have to plug the failing port with something.
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD
99 F-250 CC 4x4 7.3L PSD ZF6 E99 CALI DELETE
ROTELLA 5W-40, MOBIL1 ATF, PENNZOIL SYNCHROMESH
greenskeeper79 is offline
post #4 of 4 (permalink) Old 02-17-2017, 04:48 PM
klhansen's Avatar
My Photos: (180)
I don't think a timesert would work either. Might be better than helicoil, but the profile at the top of the hole would still not be in spec.
Using another port for the ICP is a good idea and would work. You might be able to tap the damaged port for a pipe plug, which will seal without an o-ring. Whether the size is close enough remains to be seen. A grease filled tap will contain the chips if you're very careful.
), AIS,
regulated return,
klhansen is offline
