idle fine, dead pedal when SES light on, light off- everything fine - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 12-19-2007, 10:22 PM Thread Starter
2001 F350 7.3 starts fine every time. Idles fine. Service engine soon light comes on; still idles good but accelerator is dead. SES light goes off and I can rev engine fine. Read a bazillion forums and changed the EBP tube, EBP sensor, gutted the EBP valve at the turbo and unplugged the two wire sensor there. Nothing, notta, nill...still having same problem. Can't stealership or shop it as I pull a trailer daily with my construction co in south Louisiana.
What's my next suggestion or step?
240,000 miles and not even considering a different vehicle [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Clippercliff is offline
post #2 of 15 (permalink) Old 12-19-2007, 10:28 PM
Re: idle fine, dead pedal when SES light on, light off- everything fine
Get the code ....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #3 of 15 (permalink) Old 12-19-2007, 10:29 PM
whitjo's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: clippercliff</div><div class="ubbcode-body">2001 F350 7.3 starts fine every time. Idles fine. Service engine soon light comes on; still idles good but accelerator is dead. SES light goes off and I can rev engine fine. Read a bazillion forums and changed the EBP tube, EBP sensor, gutted the EBP valve at the turbo and unplugged the two wire sensor there. Nothing, notta, nill...still having same problem. Can't stealership or shop it as I pull a trailer daily with my construction co in south Louisiana.
240,000 miles and not even considering a different vehicle [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img] </div></div>
X2 with ACTION get code.
TPS assembly is most likely faulty and the IVS is sticking.
IVS (idle validation switch) tells PCM "no pedal we are idling"
press the pedal and the switch don't say "PCM time to go!" so it just sits there thinking you still want to idle.
IIRC you replace the pedal assy, about 125.00 to your door.
Some have wd-40'ed the switch and loosened it up, worth a try!
it's on the pedal bracket, easy to see!
Early '99 F250 SD, 4X4, SuperCab, Long Bed, 7.3L "PowerStroke" Diesel, Auto, PMT1 PCM w/DPTuner 80 tow, 190K miles,
Volant intake, ISSPRO gauges, BDS front leveling kit, 4" straight piped, Dick Cepek 18x9 DC1-Chrome, Nitto Terra Grappler 325/65R18,
Pro GOD, Pro Guns, Pro Life Important Notice, Pro Life changes when someone breaks in.
whitjo is offline
post #4 of 15 (permalink) Old 12-19-2007, 10:31 PM Thread Starter
no codes on my scangauge or my other code reader when ses light is on or off. Perhaps I have crappy code readers; not sure. Do you recommend one?
post #5 of 15 (permalink) Old 12-19-2007, 10:36 PM
klhansen's Avatar
My Photos: (180)
Most generic code readers won't get the codes off a PSD.
AutoEnginuity is a good one. http://www.autoenginuity.com
About $350 for hardware (DTC connector to laptop) and Enhanced Ford software package. Reads ALL PSD codes and will do nearly all the tests that Ford can do.
), AIS,
regulated return,
klhansen is offline
post #6 of 15 (permalink) Old 12-19-2007, 10:37 PM
whitjo's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: clippercliff</div><div class="ubbcode-body">no codes on my scangauge or my other code reader when ses light is on or off. Perhaps I have crappy code readers; not sure. Do you recommend one? </div></div>
scanners:
cheap ones ain't good and
good ones ain't cheap!
AE is what I use, PC based, USB connection, very detailed data "grabber".
You can select the IVS output and watch it changed state from closed to open as you push the pedal down to verify proper operation. Invaluable to a "shade-tree" like me! [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
whitjo is offline
post #7 of 15 (permalink) Old 12-19-2007, 10:40 PM Thread Starter
Wow, thank you all for such a rapid response. It definately makes sense. I typically jump under the hood with problems but this is the component attached to the fuel pedal under the dash with wires going into it?
I'm heading outside now to try the wd-40 thing. Is that a part I can find locally or internet only?
Thank you and have a constructive day!
post #8 of 15 (permalink) Old 12-19-2007, 10:47 PM
Do you have a DVO meter?..
Rick.....
post #9 of 15 (permalink) Old 12-19-2007, 10:47 PM
whitjo's Avatar
on mine you can get down close to the pedal with the motor off and hear a faint "click" as the IV switch opens.
here is a good place
I would call to insure you get the correct part if you need it.
whitjo is offline
post #10 of 15 (permalink) Old 12-19-2007, 11:25 PM Thread Starter
I tried CRC screwloose on the "coils" by the pedal. It has helped quite a bit. The light goes off sooner and on-off more intermittently then before. I believe it has something to do with it. Thanks for the link; I'll make an order tonight. Question...the throttle position sensor came up around $35. Is that different than the IVS and pedal assembly ($125)? What's the correlation among them and how do I know which one to order?
post #11 of 15 (permalink) Old 12-19-2007, 11:31 PM Thread Starter
I don't have a DVO meter and I am researching a new code reader. Hooking up to a laptop tells me these scanners mean business and I like that. Seven years old and high milage I need to invest in a good scanner. Thanks for all the leads!
post #12 of 15 (permalink) Old 12-19-2007, 11:32 PM
whitjo's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: clippercliff</div><div class="ubbcode-body">I tried CRC screwloose on the "coils" by the pedal. It has helped quite a bit. The light goes off sooner and on-off more intermittently then before. I believe it has something to do with it. Thanks for the link; I'll make an order tonight. Question...the throttle position sensor came up around $35. Is that different than the IVS and pedal assembly ($125)? What's the correlation among them and how do I know which one to order? </div></div>
See if it has one switch or two seperate ones. The earlier models had two and you have to replace the entire assy pedal and all(I did)
Later had one switch and IDK maybe it's just the switch you can R&R? Someone here should know, but you can call tomorrow and ask Bob for the correct part#. I can't say for sure that's it.
whitjo is offline
post #13 of 15 (permalink) Old 12-19-2007, 11:38 PM
whitjo's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: clippercliff</div><div class="ubbcode-body">I don't have a DVO meter and I am researching a new code reader. Hooking up to a laptop tells me these scanners mean business and I like that. Seven years old and high milage I need to invest in a good scanner. Thanks for all the leads! </div></div>
It will pay for itself many times over! and get you some buddies you never knew you had!LOL
On edit: get you a DVO meter too.
whitjo is offline
post #14 of 15 (permalink) Old 12-25-2007, 06:58 PM
Same Problem........Idle Only!!! SES light is displayed .....tried using my code reader but pulled up nothing , Do I Need A Special Scan Tool????
I have the Actron CP1935 OBD II Auto Scanner
*BMW* is offline
post #15 of 15 (permalink) Old 12-25-2007, 07:10 PM
Kanman's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: FordSuperDuty02DieselF250</div><div class="ubbcode-body">Same Problem........Idle Only!!! SES light is displayed .....tried using my code reader but pulled up nothing , Do I Need A Special Scan Tool????
I have the Actron CP1935 OBD II Auto Scanner </div></div>
Sounds like a TPS (throttle position sensor) gone bad. In other words, you need a new fuel pedal, they are fly by wire.
I don't know a thing about that scanner, but Ill bet ya it does not work with our trucks.
Kanman is offline
