Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-28-2008, 09:15 PM   #16 (permalink)
jgarden's Avatar
Originally Posted by klhansen View Post
The IDM is located behind the F250 emblem on the driver's side fender. Pull the rear of the wheel well liner loose and you'll be looking up at the IDM connector.
Where is it located on the F350? (sorry couldnt resist)
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
Old 05-28-2008, 09:26 PM   #17 (permalink)
klhansen's Avatar
My Photos: (92)
I usually type it as FX50, but didn't pay attention to what he had and just picked one.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 06-02-2008, 11:39 AM   #18 (permalink)
My Photos: (43)
Well it turns out it was not the IDM (so now I have one it listed it the for sale section here if anybody needs one)
I borrowed the scanner and got a P1274, so lucky for me I only had to replace one UVCH (for now) and it was on the easier side (drives). UVCH from Int was $30 +tax, that was as low as they would go but they did take $6 off of it so I was happy.
Replaced it and put everything back together and the truck runs better now than it has for the last month.
**** goonerbilt ****
2000 F350 SRW CC.
6" lift on 37x13.5x17 Toyo Open Country MT's mounted on eagle alloy 145's
South Bend OFE Clutch / Diablo Sport Predator / Wicked Wheel
Home made muffler delete ending with a 5" exhaust tip
Heated & Lighted TT mirrors
Marker lights under cab and on tool box! 19 total!!
2005.5 American Spirit Horse Trailer
tgoon is offline
Old 06-02-2008, 12:22 PM   #19 (permalink)
For the true cheapskate...
Ford part #2C3Z-14A163-AB is a kit that comes with three (in case you lose one...does both sides with one left over) little wedges that go down into the UVC harness so it won't disconnect on it's own anymore. Sells off our front counter for about $15.
Early '99 F-250 Isspro Guages, shift kit, digital lockup valve, torqshift cooler, Diablo 4 bank, straight factory exhaust...aFe stage II, F.A.S.S. 150/180, working on homemade regulated return... FS2500 and Motorcraft full synthetic 5W40
'01 Excursion Isspro Guages, shift kit, lup valve, torqshift cooler, Diablo 4 bank, 4"stainless (mostly), pro-comp 325/50/20 on weld cheyenne 8's...the pro-comps blow chunks but they look good...
shaggy_tech is offline
Old 06-02-2008, 02:41 PM   #20 (permalink)
rdnck83's Avatar
I have checked my UVCH with both a multimeter and w/ visual and neither have come loose. If it is the IDM, I hope the stealership will let me know. I unfortunately took it in today. We will see. I just want them to diagnose the prob.
2000 F-350, Off-Road Package, 4" pro-comp lift, 35" pro comp mudders, Helo wheels, front replacement bumper (300 lb.), dual 4" exhaust, 50hp plug in hp increase, shift kit w/ 3 disc torque converter, k&n replacement air filter, pioneer stereo w/ OEL display, dual 12" subs (250 amp ea.) to play country music on.
"You can't build a reputation on what you are going to do" - Henry Ford
rdnck83 is offline
Old 06-02-2008, 10:38 PM   #21 (permalink)
I've had several trucks with p1667 that ended up being the pcm.
Usually this is an intermittant code...meaning unless the condition exists while it is being tested it is not really possible to come up with a definitive diagnosis.
Old 06-26-2008, 03:59 PM   #22 (permalink)
I've got a problem that after reading through this thread seems like it may be the UVC harness. The truck is an '02 F-550 with 7.3. I've lost all the cylinders on the driver's side of the engine, it happened on the road. I experience an extreme loss of power, I was barely able to get the truck home.
A mechanic friend suggested I start the truck and pull the harnesses one at a time to the valve covers. In doing this, the engine shuts down when I pull the passenger side, there is no change at all when I pull the driver's side. I've read here that the harness can come loose, is this on the underside of the cover? The harness has little clips at the plug to hold the plug together on the outside, is this the updated harness that has been mentioned?
God, Guns & Guts made America free!
Visit HeavyEquipmentForums.com
Lagrangeville, N.Y.
'97 F-350 DRW dump (sold)
'01 F-350 SRW flatbed
'02 F-550 Dump
Redneck_Steve is offline
Old 06-26-2008, 05:31 PM   #23 (permalink)
I got the valve cover off and discovered the inside plug had backed out of the gasket plug about 1/16". Is this enough to cause my problem?
Can the truck be started and idled with the valve covers off without making a mess? I'd like to verify that I've solved the problem before putting it back together.
Lagrangeville, N.Y.
'02 F-550 Dump
Old 06-26-2008, 06:07 PM   #24 (permalink)
F350_6's Avatar
It's an electrical connection so if you have enough separation it will kill that side. The truck can be started without the valve cover. The mess won't be too bad. Throw something over the inner fender and lay something down beneath the truck. If that's your problem you'll want to make some sort of shim to wedge in the connector so it doesn't come loose again.
Chris
2002 F350 6 spd 3.73LS XLT Heated Seats 260,000 & counting.
F350_6 is online now
Old 06-26-2008, 06:24 PM   #25 (permalink)
I dropped the valve cover in place and ran the truck a little, the loose connector doesn't seem to be the problem. Driver's side bank is still dead. A visual inspection doesn't show any problems, and I don't see any corrosion in any of the plugs. Is there anything else I should be looking for?
Lagrangeville, N.Y.
'02 F-550 Dump
Old 06-26-2008, 06:41 PM   #26 (permalink)
F350_6's Avatar
Well you could look for oil discharge at each of the injectors to visually see if they're firing, but if that sides dead that won't help you any. If it's not the UVC wiring or connector, I'd trace the wires from the plug back toward the IDM looking for shorts. If you don't find any, pull the plug from the IDM and ohm the wires to check for continuity between the IDM and valve cover plug.
Chris
Old 06-26-2008, 08:24 PM   #27 (permalink)
Here are the fault codes I had:
P0562 System voltage low
P1670 Electronic feedback signal not detected
P1316 Ignition diagnostic codes detected
P1247 Turbo boost pressure low
Is there a place other than the harness where the signal to the injectors are split between sides of the engine?
Also, since all of the injectors on that side are not firing, it seems it would be a ground issue? It doesn't seem likely that all the hot leads would have a problem simultaneously.
Lagrangeville, N.Y.
'02 F-550 Dump
Old 06-26-2008, 08:30 PM   #28 (permalink)
F350_6's Avatar
The center pin on the connector that plugs into the valve cover is the ground wire. The reason I suggested ohming the wires between the IDM and valve cover is this is starting to sound like you might have an IDM issue, and I don't know of any way to test the IDM besides swapping it out.
You could ohm the ground wire and see where that gets you, but I'm not sure if that would be the problem.
Chris
Old 07-04-2008, 03:44 PM   #29 (permalink)
I finally had a chance to do some checking. The ground wire has 0 resistance to the plug that connects suspended over the valve cover, this is the connection between the engine and firewall, square connector with about 20 pins. However, between this connector on the truck side and ground, I get a .14 with the meter set on 2M. I'm not an electronics wiz, so I don't really know if this is what I should expect or not.
Where is the IDM located? I'm having trouble following the harness at the firewall. I'm checking the hot lead on the front cylinder next.
Lagrangeville, N.Y.
'02 F-550 Dump
Old 07-05-2008, 03:04 PM   #30 (permalink)
cpope's Avatar
uvch
easy solution...no shims...no new harnesses...
SUPER GLUE
after 3 idms a $2 tube of SG solved my problems.... harnesses were causing shorts that were killing the idms
I luv super glue almost as much as duct tape
2000 F250 CC PSD 4x4 Long Bed, 8" All Suspension Lift, 40x13.5x17 GoodYear MTR's, Dynatrac Upgrades Front & Rear, 4.56 Gears, Warn Premium Hubs, Custom Leather Seats, Frontier and Ranch Hand Bumpers, EBPV Delete, Straight Pipe Exit in front of Rear Wheels, Regulated Fuel Return, Gauges, DIY Tymar, Zoodad Mod, CCV Mod, Limo Tint, Hide away Gooseneck hitch, blah, blah, blah
SOLD99 F250, CC, 4x4, LWB, 6" lift, 37's, Ranch Hand bumpers, tool box, top bed plates, blah feakin' blah....
01 Excursion, Limited, DIY Tymar, CCV, Zoodad, 5.9k mod, 220,000+ miles
cpope is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
&raq
