Does anyone have any recommendations for a good injector cleaner fuel additive? I mean can you notice the results in power and mileage? Thanks for the help.
Well, I have put all sorts of snake oil in my tanks. However, the best stuff I have ever found was on the injector tester bench. I took out 6 injectors out of my MB diesel and had them tested. 5 were good and one was spraying badly and had lower pop off pressure. They disassembled it and cleaned it till it was just as good as the others. Power was a little better and ran smoother according to the wife who didn't know what I did. So, before I spend money on that snake oil, I'd make sure the injectors were good or bad. I would do my MB again after 100K. For the truck, I would probably do it at 150K.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
stanadyne is good. you mentioned seafoam. not familiar w/ it but a tech on our ford message board said a customer poured some of this down his intake & damaged some of the pushrods & rockers. don't do this. thought his eng. was damaged for good. its probably just as bad as using either & too much at one time. either is not recommended for these engs.
Hi kan. After reading this thread, I logged onto the Sea Foam site and found these directions:
1. Fill primary fuel filter with SEA FOAM. Be sure filter is fully primed to prevent air locks. This will clean injectors quickly.
2. Use 1 pint of SEA FOAM to every 25 gallons of diesel fuel to add lubricity, clean fuel lines, injector pump and remove moisture.
3. Use 1 pint of SEA FOAM to every 4 gallons of oil to clean rings and other engine parts internally. For best results, use SEA FOAM for 1 hour before oil change. Results in cleaner engines and longer oil change intervals.
This lists three 'separate' procedures for the product. I don't know about you, but it takes me about 2 hours to replace the fuel filter, so I really don't want to get into that. However, adding it to the fuel or oil just before changing wouldn't be a problem. Which of the the 3 procedures do you follow? Or do you do all three?
2012 F-350 SD Crew Cab, SRW, LWB, 4 X 4, FX4 Offroad, White Platinum w/Adobe, Navigation, Moon Roof, 5th Wheel Prep, Step Tail Gate, King Ranch Package
I have used Stanadyne for years about every 3rd tank. I recently tried Howe's and got the best MPG so far in my truck. It only picked up just under 1 MPG, but with these fuel prices, every little bit helps.
I have used 1 & 2, both with good results, option 2 you will notice a differance within a tank. Option 1, you will notice a differance within a few seconds. Just bleed the fuel canister, fill with seafoam, start like you would when changing a filter, smile, drink a beer, or in my case a Makers Mark and water. Bourbon mixes with water a lot better than diesel.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
"I have used 1 & 2, both with good results, option 2 you will notice a differance within a tank."
Who said anything about dumping into the intake?
Andy
"customer poured some of this down his intake & damaged some of the pushrods & rockers. don't do this."
OOPS
Andy
1) You drive or idle the truck for the suggested 1 hour?
2) The amount of time after you add SF and run the truck until the oil can be changed?
i only ask because I have about a 45 minute ride to work, but then it would be 4-6 hours until I could actually change it. Just wondering if it would be better to put it in before I leave and then change it when I can, or to idle it for an hour before I immediately change it, or 3) wait until I'm home...
I would add it when I came out from work and change my oil as soon as I got home, except for the two beers of course (forty-five minutes home, two beers = 45 min.)
Andy
