Injector control module? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-02-2005, 05:57 PM Thread Starter
gpp
Greetings all,
I have been told by the stealer,I mean dealer, that my ICM is bad. The truck has the symtoms of a bad CPM by reading the posts here. Have any of you experienced this problem? Thanks in advance for responding.
I have a 2000 F-250 , 7.3 PSD, 6 speed handshacker, totally stock except for a EGT gauge.
gpp is offline
post #2 of 5 (permalink) Old 03-02-2005, 06:03 PM
haul_n_horses2's Avatar
My Photos: (17)
Re: Injector control module?
Welcome to The Diesel Stop, the best source of information on PowerStroke Diesels on the web. By bad CPM do you mean the PCM ie computer or possibly CPS, cam position sensor?? What were the symptoms your truck was displaying?
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #3 of 5 (permalink) Old 03-02-2005, 06:09 PM Thread Starter
gpp
Thanks,
I meant a bad cam position sensor. The truck rangood and all of a sudden cut off. I restarted it with no problems and drove another mile or two, it stopped again. I restarted again and drove it another 15 miles or so till I got to the dealership. It ran fine, made me feel silly! Anyway, they put it on the diagnostic machine and came back with the "injector control module" was bad. They had to order it, so I should get it tomorrow.
gpp is offline
post #4 of 5 (permalink) Old 03-02-2005, 06:19 PM
My Photos: (17)
Well it is a pricey item and they would not replace without the codes. Hope you are still covered under the engine warranty. The ICM is covered under the 5 year /100K mile warranty. But if I were you I would go to www.powerstrokeshop.com and order a replacement cps ASAP. They have them for about $80. Put it in your glove or tool box and make sure you carry a 10 mm deep socket with short extension and the wrench. If you do a search you can find a guy that will ship it to you for $60.
post #5 of 5 (permalink) Old 03-02-2005, 06:28 PM Thread Starter
gpp
Thank You Haul_n_Horses,
Sounds like good advice. The dealer did say it was covered under the warrenty. Thanks again!
gpp is offline
