Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-09-2008, 07:33 PM   #1 (permalink)
gamudslinger88's Avatar
Injector knock?
I heard what I think is an injector knocking in my truck today. I only notice it when Im in the stock setting on my DP tuner but when I put it in 80 econo I can barely hear a knock, you have to be listening for it. Should this be something of consern?
2001 F250 4x4 long bed extra cab 6 speed hand shaker . DIY Tymar, 4" turbo back straight pipe w/ 5" stainless tip, DP tuner F5 w/ stock, high idle 1200 rpms, 60hp tow, 80hp econo and 120hp performance. Auto meter Boost and EGT gauges on an A pillar pod. 203* thermostate. CCV mod run to the back between fuel tank and skid plate. 2.5" leveling kit and running 315/75/16 Hankook MT. Cobra CB with dual 3' whips. 9000 miles + on WMO and ZERO problems.
Sitting in the garage but not installed yet.
Banks wheel, HPOP line cross over, 92 gal auxilary tank.
gamudslinger88 is offline
Old 05-10-2008, 06:43 PM   #2 (permalink)
anyone??????????????????
Old 05-12-2008, 11:49 AM   #3 (permalink)
74 views and not a single comment, come on, I know someone has some kind of info or something.
Old 05-12-2008, 02:40 PM   #4 (permalink)
I don't see in your sig. where you have done any in tank mods or a regulated fuel return. That quieted my injectors a lot. Can you tell which side it is on it may just be the long lead injector on cyl. 8. You may be just pulling air into the fuel lines thru the factory connectors between the tank and the fuel pump causing the injector knock.
2001 Ford F-350 drw 4x2 auto,4.10 gears,Turbonetics ball bearing turbo, ceramic coated up-pipes and exaust manifolds, DIY Tymar, 4 inch exaust turbo to tip, Isspro guages EGT,Boost, Trans temp from DieselManor, 6.0 trans cooler, AIH delete with boost attachment, ITP Regulated Fuel Return kit,hutch and harpoon mod done, ITP in tank and prepump mod kit, Rotella ELC, 203 Stat.
DP Tuner-no start, stock,40,60,80E,120
BTS Transmission,(BTS-BUBBA)
Toys: 03 Screaming Eagle Duece Harley
37ft Cyclone by Heartland 5th wheel toy hauler
ford4me2 is offline
Old 05-12-2008, 05:11 PM   #5 (permalink)
I have done no tank or fuel line mods, I have come across a write up about on a while back but I cant remember where I seen it at. Could someone point me in the right direction?
Old 05-12-2008, 05:22 PM   #6 (permalink)
klhansen's Avatar
My Photos: (92)
ITP and other vendors sell an in-tank and pre-pump mod kit. I think ITP's website has the instructions available, so you can see what's entailed with the mods. Here's ITP's kit. ITP 7.3L Fuel Tank / Pre-Pump Kit
Basically, the pre-pump mod eliminates the QD connectors on the fuel line on the suction side of the pump, one at the top of the fuel tank and the other at the inlet of the pump.
The in-tank mod eliminates the thermal mixing device that recirculates warmed fuel returned from the engine back thru the pump. It re-routes the return line away from the pickup to let the air out of the returned fuel before it gets sucked into the pickup. The tank pickup assembly also has an aux pickup above the screen on the foot that can admit air if the fuel level drops below it. That's blocked by most in-tank mod kits.
Hope that helps.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 05-12-2008, 09:16 PM   #7 (permalink)
I had a lift new lift pump installed about 3000 miles ago by the dealership, would this have anything to do with it? what about running thicker fuel like a 50/50 mix of WMO and Diesel?
