If you pull your valve covers, and run the truck, you will see oil spilling up around the injector that is bad. There is a oil deflector over the area where oil is supposed to come up, but the bad one may have oil coming from different areas.
In my opinion - if you have the valve cover off - and if you already have one going out - you might as well change them all or you'll just be putting off the inevitable.
