Injectors - Diesel Forum - TheDieselStop.com
Old 07-01-2009, 09:06 PM   #1 (permalink)
Injectors
Where is the best place to buy new injectors I think mine are do to be replace Is this a easy project for the do it yourselfer with some mech abilty
dhurley is offline
Old 07-01-2009, 09:24 PM   #2 (permalink)
woodnthings8's Avatar
Check out Dynomite DIesel in Monroe, Wa. They are pretty well known for there injectors. They are having a event on the 11th of July, you should check them out.
Dynomite Diesel Performance: Reliable Diesel Performance Products and Injectors for your Cummins, Duramax or Powerstroke - Monroe, WA
Injectors are not difficult, just take your time and you will be fine.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 07-03-2009, 12:37 AM   #3 (permalink)
rosewood honest good job the best
speeder is offline
Old 07-03-2009, 08:12 AM   #4 (permalink)
JimTJr's Avatar
My Photos: (20)
If you just want stock injectors, find someplace that sells Alliant injectors. Many diesel or turbo repair places carry them. A stock injector should only cost about 200.00 plus core. David at Diesel Innovations also carries them I believe.
Why do you think yours are "DUE FOR REPLACEMENT"?? They can last 300k miles with proper maintenance, (oil changes, fuel filter changes, good fuel ect...) And on the other hand, even with those things you can have one fail at 150k...
However it's rare that you should have to replace the whole set,,, if you have one bad, just replace that one.....
UNLESS of course you want to upgrade to a performance set...
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 07-18-2010, 10:30 AM   #5 (permalink)
ForceFD's Avatar
I would not recomend Dynamite Diesel for injectors. I had my truck basically tore down to the short block by them getting head studs, EGR fixes, Banks 6-Gun, etc and also the famous injectors and it ran great for about three weeks then broke down. Unfortuntaely I was moving from base to base as we do in the Army and I was over 300 miles away when it occurred. I called them up, they told me to go to someone they knew that was close to where I was, the guy diagnosed it, called them and told them what the problem was, and they refused to pay for the repair claiming to warranty on Injectors. I outlined to there boy Ryan, that would have been good information to know since I asked for fixes to the known 6Liter problems when I went to them for assistance....before I started moving my family across the country. Anyways, just a word of caution. I dont think they made the mistake on purpose when they did my injectors, but the fact that they wont stand behind there work, after i paid them $10K, is disturbing.
04 PSD 6.0
SilverLine Exhaust
AFE intake
Banks 6-Gun
ARP head Studs
Pricol gauges
FabTech Lift
KMC Addict Rims
Nitto Trail Grapplers
ForceFD is offline
Old 07-18-2010, 10:45 AM   #6 (permalink)
You say Dynamite Diesel, while I mentioned Dynamic Diesel. We have a Dynamite Diesel in Snohomish, and Dynamic is in Monroe, WA.. Are you speaking of either one of these?
What broke on your trip?
Ken
TSB Information
Old 07-18-2010, 04:54 PM   #7 (permalink)
RT
RT's Avatar
My two cents - wherever you get them from, make sure it is a company that bench tests each and every injector. There are too many horror stories from people who buy cheap injectors off of e-bay or some other high marketing-low quality company and then have two or three injectors that won't fire. Then you get those replaced, and find one or two of the new ones are crap. You end up doing the installation several times before you get a good set. I have never heard anything bad about Beans injectors, and the price is reasonable:
http://beansdieselperformance.com/st...productId=1094
RT is online now
