Intermittent starting 2001 7.3 - Diesel Forum - TheDieselStop.com
Old 01-13-2013, 08:49 PM   #1 (permalink)
I have a part failing, need assistance identifying.
After glow plug cycle, truck will start 20% with no problem. 80% of the time, the engine turns over with a light buzzing sound from the dash area. On third or fourth attempt, buzz will dissapear and truck starts normally. Problem is overtaxing starter and cold months, exhausting batteries before ignition. Any insight would be helpful.
Successive starts are problem free once warm.
jimbo99 is offline   Reply With Quote
Old 01-13-2013, 09:32 PM   #2 (permalink)
tinman13kup's Avatar
Sounds like it's time to get the batteries load tested. Make sure they are disconnected before do so.
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
tinman13kup is offline   Reply With Quote
Old 01-14-2013, 10:37 AM   #3 (permalink)
Tom:
Are you suggesting battery health is cause of Buzz and no-ignition. There is no lag in the starter or engine rpm at starting, therefore good compression. Repetitive cranking eventually results in truck starting. Want it to crank 1st time. Will load test at your suggestion. Thanks Jim
Old 01-14-2013, 11:11 AM   #4 (permalink)
Load testing is usually a good first step, even if it doesn't prove to be the issue.
When cranking w/ no crank/buzzing, do lights dim? Perhaps try with the dome light on. It could be a bad connection on the starter relay too. The buzzing is typically low voltage to the relays
Sent from my DROID X2 using AutoGuide.Com Free App
Tom
