IPC question - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 10-07-2010, 11:03 PM Thread Starter
IPC question
I have a question in regards to the IPC sensor: I noticed that my ICP is starting to have some oil in the connector, so I decided to get a replacement. Because I have some experience with aftermarket sensors, I decided to go the safe route and get an original Ford or International one. I found one on ebay, bought it and it finally arrived the other day (Long postal way thanks to costumes).
Now my question: The sensor is not in a original packaging and dose not have any number stamped on it that matches the Ford or International article code F6TZ-9F838-A or 1807329C92.
The numbers are: 1835923 and C922350A. Is this an original or is it an aftermarket? I want to be sure about this before I contact the dealer on ebay.
Thanks for the help.
Eriol: 2002 F350 PSD Lariat SCSB 4WD 4R100(deleted) ZF6; 460,000 km as of Sep. 2014
AFe Big Boost 24-91042 on home made intake, 4" turbo back magnaflow exhaust, Edge Evo 2, running 60% SVO in tank, Hellwig big wig sway bars, HPx.
in-tank fuel mod (hutch mod and harpoon mod).586-902 stancor GPR moved out of the valley. Baldwin 1212 pre-pump filter mod. Always bright OHC. boostvalve. TrueTrac diff in rear.
AE: southern Vancouver Island, B.C. or wherever I go.
Camper: 2012 Palamino Maverick 8801
eriol is offline
post #2 of 3 (permalink) Old 10-08-2010, 02:58 AM
klhansen's Avatar
My Photos: (180)
Those numbers look like International numbers. There are a few iterations of the ICP sensor, but not sure what that 1835923 number matches.
), AIS,
regulated return,
klhansen is offline
post #3 of 3 (permalink) Old 11-24-2010, 04:30 PM
ju015dd's Avatar
same question here, got mine in the mail today and it doesn't fit. has different threads
ju015dd is offline
