IPR oil leak - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-25-2006, 05:12 PM Thread Starter
IPR oil leak
My IPR seems to be leaking oil out the end where the Tinnerman nut is. Is this possible? I can see the oil build up and then drip out the end. I have verified that the two lines on the drivers side of the HPOP are not leaking and also the two hex plugs. Will the IPR rebuild kit solve this issue?
Please advise
99.5 F250,PSD,6 SPD,XLT,4X4,XCAB,LB,HD SUSP,MAN HUBS,TT PKG,CAMP PKG,WHITE STOCKLAND SHELL
TONE is offline
post #2 of 6 (permalink) Old 09-25-2006, 05:13 PM
My Photos: (22)
Re: IPR oil leak
Please advise
Most likely.
Hammer
Check out what I recently bought:
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red">
</font>
Get Your Tuning Here:
and your Fuel kits here:
TheHammer69 is offline
post #3 of 6 (permalink) Old 09-25-2006, 08:32 PM Thread Starter
Re: IPR oil leak
Thank you for the reply Hammer. I have never had an IPR and solenoid out on the bench so I am trying to understand the failure mode for this oil leak before I start buying kits and removing parts. Is there a gasket/o-ring between the solenoid and the IPR? I was under the idea that the oil leak would have to stem from the o-ring between the HPOP and the IPR interface, which makes the oil at the end of the Tinnerman nut confusing [img]/ubbthreads/images/graemlins/shrug.gif[/img]. Would you mind venturing an opinion on which gasket/o-ring has failed. Any information is greatly appreciated.
TONE is offline
post #4 of 6 (permalink) Old 09-26-2006, 01:00 AM
My Photos: (22)
Re: IPR oil leak
My thinking is that the oil leaked at the O-ring where the IPR screwed into the HPOP and seeped down between the Solenoid and the part of the IPR it slips over.
Hammer
I still have the:
<font color="red">
</font>
post #5 of 6 (permalink) Old 09-26-2006, 03:10 PM Thread Starter
Re: IPR oil leak
Does anyone know if there are any o-rings common to the Tinnerman nut/solenoid/IPR? If there are what are the sizes? Also what is the size of the o-ring between the IPR and the HPOP?
Thanks,
TONE is offline
post #6 of 6 (permalink) Old 09-26-2006, 04:45 PM
klhansen's Avatar
My Photos: (180)
Re: IPR oil leak
The solenoid slides right over the stem of the IPR, without any o-rings, and is held on by the nut.
I don't know the size of the o-ring for the IPR-HPOP seal, but you can get a kit for all IPR o-rings from either Ford or Int'l. I believe it's internal as well as external o-rings.
IPR O-ring kit
Ford F6TZ-9C977-AA
Intl 1825806 C91
), AIS,
regulated return,
klhansen is offline
