ipr valve replacement - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 05-21-2007, 01:19 PM Thread Starter
who has the best price on a new ford powerstroke ipr valve? mines gone bad and i need to replace it. thanks.
superpro is offline
post #2 of 6 (permalink) Old 05-21-2007, 01:22 PM
Re: ipr valve replacement
The best prices we have seen are on E Bay...Around $100-125.00 [img]/ubbthreads/images/graemlins/shrug.gif[/img]
What is the problem with yours?....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #3 of 6 (permalink) Old 05-21-2007, 01:24 PM Thread Starter
had a scanner put on it, its idleing at appx 425 psi with and eractic idle and stumble during take off.
superpro is offline
post #4 of 6 (permalink) Old 05-21-2007, 01:34 PM
What happens when you unplug the ICP...?
Rick.....
post #5 of 6 (permalink) Old 05-22-2007, 08:48 AM
Have you thought about changing out the o-rings on the IPR first??
IPR seal kit: Ford # F6TZ-9C977-AN
International # 1825806-C92
If this fixes your problem, it's a whole lot cheaper than a new IPR
2k F250 XLT CC 6sp PSD, 3.73 LS axle, Superchip, W-D Turbo Brake, Memphis speakers & 5ch amp, WD-Pyro & Boost gauges, Rechargable MagLite, quick disconnect jumper cables, CAT batteries, ARE tonneau,
"una
able" on the tailgate!! New door actuators!!
T-304 Stainless exhaust turbo back, Southbend clutch
Tina is offline
post #6 of 6 (permalink) Old 05-22-2007, 03:07 PM
calico5string's Avatar
My Photos: (31)
Excellent suggestion Tina! That was gonna be mine too [img]/ubbthreads/images/graemlins/wink.gif[/img]
Leaking IPR seals will drasticlly affect the performance. Check and/or change them first.
Another source for IPR's (if you end up needing one) is: HERE (click me) Part #HTS102 (scroll down the page a ways...)
I bought a new one from them (and an HPOP) when I went to the twin-HPOP system. Service was good, prices were fair, and FREE shipping!
Good luck...
Al in SoCal
2000 F350 SRW CC 4X4
AFE Stage II w/PG-7
Garrett 38R Turbo
Swamps Stage II Single-shots
Stealth Dual-HPOP
ITP Custom-modified Regulated-return Fuel System
DP-Tuner PCM & F-5 chip (Live tuned!)
Autometer Gauges (Pyro, Boost, Eng oil temp)
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
4" Custom S/S Exhaust into 5" Dual Aussie Stacks
ZF 6-Spd "Hand-shaker"
Southbend Double-Disc clutch
...plus some other goodies...
calico5string is offline
