HI, I have a 2002 7.3 powerstrock diesal truck and its seems to be something exotic cause I can't find any mechanic that can fix one. Here is a summary of what is happening I drove it and it started vibrating big time through the truck when I shut the ignition off then tried to restart it would not start. It finally has started again but it shakes violently when I try to drive it.
Does anyone know why the truck would still run and be vibrating and shaking so much when it's driven.
First, welcome to the Board. Ask any questions and the knowledgeable people here are always willing to lend a hand. Or just sit and swap stories with us.
Lemme start with a few questions
you say:
Let's try and isolate the shake.
Does it shake violently when it's rolling or just when the engine is running without the truck moving ?
If it's not rolling, does it shake when it's in PARK or NEUTRAL or only when it's in DRIVE (assuming it's an automatic) ?
Also, where are you located ? Put that in your personal info so someone who might be close to you could be of help, locally. There might be a good bodyman or a good diesel mechanic who could help you out.
RoGrrr
I like BIG, LOUD, heavy trucks, light, tiny women, shooting, and BIG glasses of heavy beer (not necessarily in that order, either ). http://www.youtube.com/watch?v=-TC2xTCb_GU
The little gal I bought my truck from called it her "COWGIRL HARDWARE".
I call it "LURCH" !
96 F250 4WD, 35 INCH TIRES over a inch lift kit, DUAL 5 INCH STACKS (sounds pretty darn good), BLACKed OUT WINDOWS, SNOW PLOW
CENTRAL OHIO
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
HI thanks for answering I am from Stoughton, MA. The truck is an automatic and it starts to vibrate/shake when it is running and I start driving down the street at about or around 20 mls per hour it starts to shake???
1. Its spelled DIESEL.
2. There are a few different issues you could be having, and as your description of the problem is rather general, all of them could be the problem.
Injector failure/Injector harness failure.
Torque converter/total transmission malfunction.
One or more sensors on the engine are malfunctioning.
High pressure oil pump malfunction.
Fuel system component malfunction.
Thats just a few of the more probable things that could be the problem.
The best thing you can do is to have it diagnosed with a Ford specific code reader, to see if there are any trouble codes stored in the PCM.
I cannot help you find a DIESEL mech, tho, yer kinda on yer own with that...
Sorry.
"Blizzard" The big white bio-burning 03 7.3 4x4. 6637, straight piped stock exhaust, and a "New" secret blend of Haul a$$ing mods and upgrades. Suffice to say, its not the fastest, but it quite possibly is one of the quickest.
Thanks, someone was saying to me it might be the ball bearings because ford is noted for that and since I have over 125k mls, or something about a hydraulic something???
Not ball bearings, Ball joints. The shock looking thing wayyy down under your front axle is probably what they were referring to. Called a hydraulic steering damper. HOWEVER. Your truck wont be vibrating while sitting there idling if these are the problem. It would have to be moving. If you mean that when you drive it and it starts to vibrate, then yes, these two components are usually the first thing to be checked. Ball joints can be checked easily. Jack one front wheel up, grab it by the top, and the bottom, and try to shake it. If theres movement at ALL(Clunk clunk) then yes, yer ball joints need replacing. Its a good idea to change out your steering damper at the same time you do your ball joints. Another problem that can cause vibration at speed is worn out pan hard bar (Track bar) bushings, but then you would also have a slight "Wandering" Condition while you are driving, and clunking when you turn.
I would venture to say it's starving for fuel, missing badly thus your "Shakes" Does it sound terrible also? These things sound like they are going to blow up when they are starved for fuel.... knocking / rattleing really bad.
If you take it to an IH dealer, they'll probably scratch their heads,,, I mean, if they can't cross fuel filter part numbers for the PSD,,, then how can they work on them? LOL.....
If it was driving,,, and started "Shaking" ,,,died, then started very hard,,and still "Shakes" I bet the fuel pump is barely supplying enough to run,, or it may even be siphoning just enough to run from the tank,, who knows. (The fuel pump can "RUN" and not move any, or enough fuel, if you hear it cycle on when you turn on the key) SO I would do this...
Lay under the truck on the front passenger side, there should be a metal tube that hangs down nearly to the top of the oil pan and just ENDS there. That would be your fuel/water separator drain. Put a rubber hose on it that is just long enough to drop down through one of the holes in the cross member. Then have someone drain the fuel bowl while you hold a container under that tube. After the bowl is empty, have someone turn the key on while the drain is still open. If fuel does not come out pretty hard, (I believe I have heard it needs to flow at the rate of about a quart every 15 seconds or so) If fuel comes out much slower than that, you likely have a dead/near dead fuel pump.
At least if your pump is healthy, you have eliminated one thing that is possible.
Good luck, and let us know what you find.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics!'03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
I agree 100% with JIM. It sounds just like a fuel starvation issue. Check the fuel pump by doing what he says. WHen the engine runs out of fuel it shakes horribly idleling and moving until all the air is out of the fuel system, then it runs fine.
2001 F250 7.3L White 4X4, Lariat Crew Cab, 7 1/2" Superlift, Mickey Thompson Classic lock Wheels wrapped in Dick Cepek 325/80/16 tires, 05-07 Grille and Headlights, wood dash kit, Pioneer Flip out DVD player, Cobra CB mounted under the 4x4 switch, DP-TUNER WITH STOCK, NO START, 80 ECON and 140 AGRESSIVE, DIY Intake with napa 6637 filter, IC Foil delete, new aftermarket tranny with sonnix shift kit and triple disc billet Torque converter, 4" Magnaflow Turbo back exhaust, Plantdrive wvo kit with 75 gallon external L shaped heated tank in the bed, Racor filter inline before the stock one, 146,000 miles
Thanks to all you guys for your help. I did what Sleeperstroke suggested with some help by shaking the wheels and found the loose piece, I am not sure of the names of these parts like you are but it was the bar (at the joint) that is in front of the bar that holds the two wheels? It was loose at the joint and the bar was attached to both wheels and then the steering wheel???? I know that sounds juvenile but I don't know it that well. That was some great suggestions and information it was a huge help for me to not get ripped off. Now I have to see how the replacement goes. I will let you know.
Thanks again!!!!
