Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 10-30-2009, 03:33 PM   #1 (permalink)
I've read the search results - Glow Plug Relay
Why, online and ebay, you can find a glow plug relay for under $25, but when I call Autozone and Oreilly they want $195.
I do have a relay and not a controller, correct? 2003, 7.3L 2wd
gager2002 is offline
Old 10-30-2009, 03:37 PM   #2 (permalink)
klhansen's Avatar
My Photos: (107)
It's their "economic stimulus package".
No idea why they want to charge that much, but if you buy from Ford, you pay at least twice as much as the identical part from International. And when I say identical, i mean down to the International number stamped on the bracket.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 10-30-2009, 04:25 PM   #3 (permalink)
Now that's just crazy. Does anyone know of and have experience with an International Parts house in Houston? Location? I see that there are a few, but all are over an hour drive from my home.
Old 10-30-2009, 06:13 PM   #4 (permalink)
I bought my GPR from Napa at $65
patphish is offline
Old 10-30-2009, 07:05 PM   #5 (permalink)
I just picked one up from Napa two days ago for about $35. Part number GPR-109.
When installing, take note of the various connections orientation from old relay vs. new relay. The plastic 'rib' between the connection terminals is the same shape on both, so it's not very difficult to connect the new one correctly. The only thing is once you've made the connections, the bracket will not bolt up to the two bolts holding it down. You will only be able to use ONE bolt, unless you can get enough slack in the wires to turn the new relay 1/4 turn counterclockwise as viewed from the top. Even with only one bolt, it seems to hold it just fine. Just crank the other nut down, or keep it in your glove box/console for possible future use.
It only takes about 5 minutes to change one out. Just make sure you unhook the battery so as not to cause electrical damage/personal injury.
Also, if for some reason you can't change out your relay and need to get the truck started when cold, use a pair of jumper cables. Either jumper both big terminals together or clamp one end to the battery's positive terminal, and the other end to the relay terminal feeding the glow plugs. I had to do that the other morning, before going to get my new relay. Let it heat the plugs up for ~15-45 seconds and it fired right up. Then disconnect your jumper cables, obviously.
wsigo is offline
Old 11-01-2009, 05:28 PM   #6 (permalink)
I just bought my GPR from international for $28 in stock. That's in Ohio though
victorng is offline
Old 11-01-2009, 11:06 PM   #7 (permalink)
jgarden's Avatar
$30, two weeks ago at an International Dealer. Not quite sure why you would buy one anywhere else for more money. The one from the Intl dealer is the OEM part.
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
Old 11-01-2009, 11:28 PM   #8 (permalink)
WSIGO I installed a Napa #109 for $30 in my truck a few months ago and i was able to mount it w/ both bolts. Just hook up the cables to the posts they reach. It will work just fine.
I bought the NAPA GPR because I don't have a Int dealer near by.
2000 F-250 7.3 PSD
Auto 4x4 x-tra cab 6ft bed
Edge Evolution Tuner
cman962 is offline
Old 11-06-2009, 12:37 AM   #9 (permalink)
tomjon's Avatar
My Napa GPR's lasted less than one year. I have had the white/rodgers for 3+ years now. Probably won't find that local though ....
01 f250 7.3 diesel ,x-cab,xlt,144k,...stocker , powerslots and hawks , Rotella ELC , Dieselsite coolant filter
69 Bronco 302 np435 , not enough tires, lift ,time or money.
tomjon is offline
Old 11-06-2009, 09:44 AM   #10 (permalink)
Thanks for the part numbers.
Old 11-07-2009, 10:02 AM   #11 (permalink)
tomjon For future reference. In case my NAPA GPR goes south soon. What did you pay for your white/roger GPR? Did you order it from some place or what?
I have seen a post some place about some massive GPR that will last forever... I think it is pricey though.
I can drive about 30 miles to an International dealer though, so probably will get OEM part if Napa part doesn't last too long.. NAPA is 2 miles away.
2000 F-250 7.3 PSD
cman962 is offline
Old 11-07-2009, 11:10 AM   #12 (permalink)
Supporting Member
bugman's Avatar
My Photos: (16)
When you get tired of replacing relays evey year and decide to find a better one just order a STANCOR if you don't like their price do a search and you may find a better price elsewhere.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 11-07-2009, 12:32 PM   #13 (permalink)
LTFFNREMTP's Avatar
I had a Napa relay that cost me $104.... made it about 9 months on it. Found the Motorcraft relay from dieselfiltersonline and had it shipped to my door for i think it was $63. No more NAPA relays for me.
'99 F250 CC-SB 4x4, AFE Stage 2 intake, coolant filter, Full gauges, AIC, On board air +
Buell emergency series air horns, Striker TT turbo timer, TC lockup and 6.0 trans cooler.
LTFFNREMTP is online now
