just changed out my trans what oil should i put in - Diesel Forum - TheDieselStop.com
Old 11-18-2007, 05:47 PM   #1 (permalink)
strobes110's Avatar
just changed out my tranny and wanted to know what type of tranny fluid should i put in and how much of it?
2000 ford f-250 turbo diesel 7.3 lariat crew cab, lifted 8" w/37x12.50 cooper tires, 4" dual after market exhaust, 4" downpipe, tymar intake, tony wildman 4 pos chip, tripple under dash gauges egt,boost,trans temp 200k and counting
1997 f250 7.3 XLT ext cab long bed 4x2 bone stock 167k and counting
strobes110 is offline
Old 11-18-2007, 06:01 PM   #2 (permalink)
Send a message via ICQ to coldair
Re: just changed out my trans what oil should i put in
royal purple atf max
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission FASS and ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:30s ARB air lockers front and Dana80 rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
OneUp ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
coldair is offline
Old 11-18-2007, 06:40 PM   #3 (permalink)
strobes110's Avatar
just called around and looked online but no one has royal purple tranny fluid. how do you get it?
Old 11-18-2007, 07:38 PM   #4 (permalink)
Schaeffer's oil from http://www.brianstruckshop.com/ it is the best you can get if you want second best Amsoil
2003 7.3 250 cc 4x4 mbrp turbo back, DP tune, gauges, (BB, OIL still waiting for install) traded for higher education
new transportation 2004 wrx stock but the 30mpg is great
[censored].com/
sdymn518 is offline
Old 12-28-2007, 09:37 AM   #5 (permalink)
You can get Royal Purple from Brian's truck shop
95 F250, Extended cab XLT, 3.55, BTS Transmission, Hypermax 4' exh. Royal Purple Bumper to Bumper
97 F350 Crew Cab, Dually, XLT 3.55, BTS Engine, BTS Transmission, BTS chip, H2 Hypermax Turbo, Hypermax 4" exh. Royal Purple Bumper to Bumper
97 F350 Extended Cab, Dually, XLT, 3.55, BTS Transmission, BTS chip, Banks 4" exh. Royal Purple Bumper to Bumper
02 F450 Crew Cab, Dually, Lariat 4.30,BTS Engine, BTS Transmission, BTS chip, H2 Hypermax Turbo, Hypermax 5" exh. Royal Purple Bumper to Bumper (what a truck!)
02 F450 Crew Cab, Dually, XLT Banks exhaust, BTS Engine, BTS Transmission, BTS chip, H2 Hypermax Turbo, Royal Purple bumper to bumper
02 F450 Crew Cab, Dually, Lariat, Magnaflow exhaust, BTS Engine, BTS transmission, BTS chip, H2 Hypermax Turbo, Royal Purple bumper to bumper
04 F350 Extended Cab, XLT, 3.73, 4WD, BTS Chip (what a difference). Royal Purple bumper to bumper
Advanced_Lube is offline
Old 12-28-2007, 09:51 AM   #6 (permalink)
ELLIOT02's Avatar
IMHO ,Mobil 1 is great fluid and is available at all of the auto parts stores including Kmart,Wal-mart,target.(Walmarts the cheapest) Availability is what keeps me from using RP,Amsoil,Schaeffer's etc.
ELLIOT02 is offline
Old 12-28-2007, 09:55 AM   #7 (permalink)
SmokeyWren's Avatar
My Photos: (44)
If you want "the best", then any synthetic ATF rated MERCON/MERCON V is good. Easiest to get quickly is Mobil 1. I got mine at Wal-Mart a few weeks ago for less than $6 per quart.
The tranny system holds almost 18 quarts. If you replaced the oil-to-air cooler and the torque converter as part of your overhaul the way Ford requires their techs to do it, then you need to buy 18 quarts of new ATF. Pour in 6 quarts, then crank the engine and let it idle for 30 seconds. Then pour in 6 more quarts and crank the engine and let it idle for 30 seconds. Then pour in 4 more quarts and crank the engine and let it idle for 30 seconds. Check the level. You should still be low by more than a quart. Pour in that quart, then wait a few minutes and check the level again. Top off until you're full but not over full.
Schaeffer's #204S ATF full-synthetic ATF is just as good - but no better - than Mobil 1 or Royal Purple or any other synthetic ATF rated MERCON/MERCON V. But if you insist on that brand, then
click on the following link to find your nearest dealer. http://www.schaefferoil.com/dealer_locator.html
My nearest Schaeffer's dealer that carries ATF is over 100 miles down the road. But I don't worry about it since Wal-Mart now carries Mobil 1 ATF.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: wingman036</div><div class="ubbcode-body">just called around and looked online but no one has royal purple tranny fluid. how do you get it? </div></div>
http://www.royalpurple.com/
Click on dealers, then on your state.
When I do that, the results show that Advance Auto Parts, O'Reilly Auto Parts, and Autozone all three are Royal Purple dealers in Midland.
SmokeyWren is online now
Old 12-28-2007, 10:46 AM   #8 (permalink)
Top selection would be Schaeffers, Royal Purple....
Stay away from Amsoil.....tooooo much lubricity
XS_SUV
Graupp is offline
Old 12-28-2007, 12:16 PM   #9 (permalink)
I got RP from the 2 Advanced Auto Parts in town. I bought out all their stock but they replace it regularly.
RP Max ATF is pretty easy to find, it's their 75W140 gear oil that is tough to find...
- C
2002 Ford F-250 Lariat Supercab 4x4 7.3L Auto.
Under Hood: DP Tuner F5 (NS, S, 60T, 80E, 120R), BTS VB, TM Waste Gate Controller, BRV Plus, MBRP SS 4" Turbo Back Exhaust, BrightBox, Ford AIS, Auto Meter Guages(Pyro, Trans, Boost).
Under Everything Else: Hankook RT03 MT 285/75/16, 16x8 Wheels, Monroe Reflex Shocks.
Best line ever on TV: "I need more cowbell".
CamoFlogged is offline
