Just had oil change and now leaking alot of oil - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 05-23-2010, 08:33 PM Thread Starter
Hello. Just got back from Firestone having my oil changed and it is leaking oil pretty bad. I took it back down to them and they said that it is not really their fault and looks like the rear gascit needs replacing(i think). the mechanic said he needs to take out the tranny to get to it. is this true and is it a hard fix? Also is it leaking because it might have a little to much oil in it and will stop leaking soon?
any help is gladly appreciated. They just got me for new rotors and brake pads.
2001 F350 Lariat 7.3 shortbed 4X4 with dual exhaust no cool mods yeat but always looking!
1835 2seat sandrail
honda 400ex
polaris 90
POS 50 quad
1979 honda odyssey
2006 32ft fsc weekend warrior toyhauler
skoolteechr is offline
post #2 of 11 (permalink) Old 05-23-2010, 09:03 PM
RT
RT's Avatar
Don't do it! These trucks rarely if ever leak from the rear main seal. There is a drain at the back up the valley that funnels all leaks from the top out the back, where it drains down. This will fool anyone that doesn't know better into replacing the seal - which will NOT fix the problem.
Take a degreaser and soak the valley area of your truck. Hose it down or use a low pressure pressure washer (car wash wand) and then get up there with a flashlight to find the leak.
Most likely culprits are HPOP o-rings or turbo pedestal.
If you are not comfortable doing this yourself - find a shop that specializes in diesels. Stay away from these franchise shops. You WILL get burned.
RT is online now
post #3 of 11 (permalink) Old 05-23-2010, 10:48 PM Thread Starter
Wow. Thanks for the advice. I will take it to a recommended diesel mechanic.What would be a reasonable cost to fix this leaK?
1835 2seat sandrail
honda 400ex
polaris 90
POS 50 quad
1979 honda odyssey
post #4 of 11 (permalink) Old 05-23-2010, 11:30 PM
I would suspect that you may not have a leak if in fact it wasn't leaking before having the oil changed. They may have spilled some oil in the valley..........intentionally or unintentionally. I would clean the valley and the under side of the truck and then watch for leaks, as suggested previously. I would not take it to anyone until you have eliminated other possibilities.
1999 (early, 10/98) F-350 Supercab 4x4 6-spd DRW limited slip....Drk Tor. Red
4" exhaust, EGT gauge, Severe Duty AIS Filter
teesh is offline
post #5 of 11 (permalink) Old 05-24-2010, 08:39 AM
RT
RT's Avatar
I agree with teesh - wash it down and verify there actually is a leak. Confirm the oil is at the right level with the dipstick - although this wouldn't cause it to leak unless it was grossly overfilled - I still worry about where you had your service done. Do you even know what kind of oil they used?
If it is truly leaking, then like I said - it is probably HPOP related or turbo pedestal related. Of the two, the turbo pedestal is the most expensive, as you have to pull the turbo to get to the base. You are probably looking at 250-500 bucks for that. If it is HPOP related - like o-rings - you could get away with less than 100 bucks. If you did the work yourself - you'd be looking at less than 20 dollars in parts for either one.
Watch this video for a general understanding of where these beasts leak from:
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
You might want to view other videos at the sight - just remember to take everything in context of getting familiar with your motor.
RT is online now
post #6 of 11 (permalink) Old 05-24-2010, 11:00 AM Thread Starter
The oil they said they used was 15w40 diesel oil by Kendal full sythetic and installed the TF2286 oil filter(It is white with red Ford writing on it-I guess thats the oil filter) They said they only use one kind of oil for diesels. Does that seem true and is it a good oil?
When the truck is sitting for about 10 min, the dripping stops. When I start it the dripping begins again. I am assuming it is pressure build up that causes the leaking. It was not really leaking before (a few spots here and there but nothing like this) But of course the mechanic put on the courtesy check that it had an oil leak.
1835 2seat sandrail
honda 400ex
polaris 90
POS 50 quad
1979 honda odyssey
post #7 of 11 (permalink) Old 05-24-2010, 11:56 AM
Are you sure its not coming from the oil filter because he forgot to tighten it all the way? I had this happen and I gave the filter another 1/4 turn and everything was happy (but i was able to clearly see it was coming from the oil filter seal)
Just a thought.
2000 F350 7.3l auto 4x4 CCLB Dually lariat, my new baby purchased 8-22-11
. 66/74/1.15 S300 turbo, TS chip from swamps (daily with 60 tune), proper gauges, coolant filter w/ ELC, 19.5s.
2006 E350 6.0 auto cutaway van XLT with fiberglass roadside assistance box w/ air compressor. Company owned but mods will come.
AutoEnginuity w/ Ford Enhanced - Tampa Bay area, FL. Just buy me dinner + fuel
Demoh is offline
post #8 of 11 (permalink) Old 05-24-2010, 12:29 PM Thread Starter
Good idea. I will check that when I clean underneath today. The oil filter is a white cylider with red writing right?
1835 2seat sandrail
honda 400ex
polaris 90
POS 50 quad
1979 honda odyssey
post #9 of 11 (permalink) Old 05-24-2010, 01:34 PM
Located on the drivers side of the engine.
2OOO F-250 4WD Crew Cab, 267,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator, H2O Pump. AIS Severe Duty Filter, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Mesa, Arizona
PRDATR is offline
post #10 of 11 (permalink) Old 05-24-2010, 02:01 PM
most likely yes. Its about the size of a 1 liter bottle, maybe a little bigger. Its a large cylinder that hangs on the drivers side of the oil pan/engine.
Demoh is offline
post #11 of 11 (permalink) Old 05-25-2010, 10:18 PM
buckmeister2's Avatar
Everything you have read so far is great advice, and you should follow it. It sounds like you really do not have much experience with vehicle repair, which is fine...everyone starts at that point. Because of that, though, if the oil filter is not obviously leaking, better to leave it alone. If that is where the leak is from (doubtful), it will be very noticeable. Last bit of advice is that you should learn how to change your own oil. It is simple, no harder than most simple things you have done in your life. Even if you choose not do it yourself after you learn how to do it, it will help prevent you from getting screwed by these rip-off repair facilities (not includine Firestone, or anyone in particular, in that comment). Not understanding the most basic maintenance item(s) puts you at their mercy, and that can get very costly.
Early '99 F250 XLT 7.3 ext cab, SB, 4x4, auto tranny, 153K miles, completely stock. Installed GlowS**t gauges (never again!) and DIY air filter, Tru Kool trans cooler, 4" exhaust, 50 HP chip. Tows 10K 5th wheel.
buckmeister2 is offline
