Key on, won't turn over? - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 04-30-2009, 06:58 PM Thread Starter
Guys,
Had a weird problem today with the truck. Shut the truck off at a fast food drive-thru so they could hear me order my #3 with sweet tea.
Turned the key on, turned to crank, nothing. No click, engine not turning over. Cycled the key on and off probably 5-10 times with the same results. Didn't hear the fuel pump energizing/priming when I was turning the key on. Popped the truck into neutral and rolled it into a parking spot. Turned the key off for about 5 minutes, back on, truck starts fine. Drove fine all the way home, shut it off and fired it right back up 4-5 times once I got home.
Any thoughts on what it may be? Never have replaced the CPS. Would the CPS just be a turns over but no crank, or could it cause the truck to not even turn over?
Thanks in advance.
'00 Ford F250 4x4 PSD
'89 Pontiac Turbo Trans Am
'03 BMW 530i Sport
HiPsi is offline
post #2 of 19 (permalink) Old 04-30-2009, 10:16 PM
klhansen's Avatar
My Photos: (180)
Are you sure you shifted into park or neutral before you shut it off. You do know that if it's not in either park or neutral that no power goes to the starter relay, right?
On the other hand, if you weren't getting the WTS light when you turned the key on, then it's something in the PCM power circuit not energizing the PCM. Could be the ignition switch or possibly the PCM power relay sticking.
), AIS,
regulated return,
klhansen is offline
post #3 of 19 (permalink) Old 05-01-2009, 10:58 AM Thread Starter
Yes, it was definitely in park. Everything was coming on just as it should, except when you turned the key to crank the engine, nothing happened. No clicks, not fading of power as if it was weak batteries, nothing. Just silence. I don't think it was a starter issue since it wasn't even making it that far. Like I said on some of the later tries after cycling the key a few times trying, I wasn't hearing the fuel pump kicking on and priming. Then after sitting for about 5 minutes while I was grabbing my tool bag from behind the rear seat, I turned the key on again, heard the fuel pump priming, kicked the key over to crank and she fired right up. Drove home, shut it off, cranked right back up. Did this 2-3 times and have driven it since and can't reproduce the problem.
It's never happened before, and may end up being just a fluke and never happen again, but I'd still like to pinpoint what may have caused it.
'03 BMW 530i Sport
HiPsi is offline
post #4 of 19 (permalink) Old 05-01-2009, 11:00 PM
klhansen's Avatar
My Photos: (180)
In that case, I'd lean toward the ignition switch. There are multiple switch circuits in it, one being the starter circuit that sends power to the starter relay. For it to work, the power has to get thru the fuse, ignition switch, another fuse, neutral safety switch (in the DTRS on the auto tranny, or clutch switch on the 6-speed), and then the starter relay.
Hope you can figure it out. It sucks to be stranded with a no-start.
), AIS,
regulated return,
klhansen is offline
post #5 of 19 (permalink) Old 05-13-2009, 12:30 AM
Dead ignition at start
I am having the exact same problem on my '02 F-350 2WD DRW. Mine did not start after 5 min though. I'm trying to figure out where the problem is. It was running fine when parked. I had a bad battery, replaced it, and now get nothing after WTS light and fuel pump pressurizing. I cycled the security system, and checked the fuses and battery cables. I'm VERY knowledgeable on these 7.3L's, but this has me a little stumped. Maybe a locked up starter solenoid?? Anyone have any other ideas??
CarTotem is offline
post #6 of 19 (permalink) Old 05-13-2009, 01:17 AM
jroller's Avatar
I had the exact same probelm. I could drive the truck all day then shut it off only to try to restart and nothing would happen. Checked and replace BOTH starter solinoids (one on the fender and one on the start). Still same thing would happen every now and again. Also when it would start, it would turn over real good. Replaced both batts and didnt help.
Finally ordered a new gear reduction starter after it wouldnt start after about 100 key cycles. Problem solved. These starters kinda let you know that the stators and brushers are giving up the ghost gradually. Eventually your truck wont start no matter what you do.
Cant remeber the starter I got but it was highly recomended on one of these sites and it is an absolute hulk.
jroller is offline
post #7 of 19 (permalink) Old 05-13-2009, 12:12 PM
Nyghtryderz's Avatar
My truck was doing the same thing. Mine was that i had some play in the shifter and when i threw it into park the shifter would slide down like i was trying to go into the next and would not start. try holding the shifter up and see if it starts. I had to take out the play and now no problems.
2015 F-350 lariat Crew Cab SRW LB 4x4
6,000 miles
5000K 55W HID headlights
5000K 55W HID fog lights
6000K 50" LED light bar
2001 Ford F-250 Diesel 4x4 XLT Super Duty
DP Tuner AIS intake
6" Lift with Bilstein shocks
38" Toyo Open Country M/T
5000K 55W dual HID headlights
5000K 55W HID Foglights
6000K 50" LED light bar 48,000 Lumens
Prodigy P3 Brake Controller
Warn Premium Hubs
160,000 miles
Tow four horse gooseneck with living quarters
flatbed hay hauler
Nyghtryderz is offline
post #8 of 19 (permalink) Old 05-13-2009, 09:37 PM
Found the problem
It was the park safety switch. Must have oxidized up while sitting.
CarTotem is offline
post #9 of 19 (permalink) Old 05-13-2009, 10:02 PM
Where is the park safety switch? I've had this problem as well and would like to get it fixed. It usually does it to me after I wash the truck.
2002 F-350 crew cab, long bed, SRW. 4 inch exhaust, 6.0 tranny cooler, AFE Stage II, High Performance tranny from Mountain Transmission in Montrose Co. DP Tuner F5 switch stock, 40tow,60tow,4low exhaust brake, 80econ, regular exhaust brake. DB Starter, Ranch Hand front bumper,
ITP in tank and prefilter mod, Harpooned tank. Custom front springs/leveling kit (thanks Spring Works) with Ranch RS9000 front shocks. Centramatic Wheel Balancers
SS317 is offline
post #10 of 19 (permalink) Old 05-13-2009, 10:11 PM
klhansen's Avatar
My Photos: (180)
It's down somewhere on the tranny. The service manual refers to it as the DTRS (Digital Transmission Range Selector), and it closes switches to tell the PCM (and the starter relay circuit) what gear it's in.
), AIS,
regulated return,
klhansen is offline
post #11 of 19 (permalink) Old 05-15-2009, 11:22 PM
JimTJr's Avatar
My Photos: (20)
I had a similar problem, I finally found it today. ON the back of the fuse box behind the starter relay area. I had a loose wire I guess. It only seemed to mess up when the temperature was hot outside, and the truck was warm inside. It would just click a bit, AIH relay clicking, GP relay clicking, lights on the dash on, radio went off in "Start" ect... everything worked but the starter cranking. I stuck my finger behind the fuse box while I held the key to "Start" and just touched some wires, it cranked. I backed off, no crank. Touched that "Bundle" again, instant crank! I unplugged that bundle from it's indivitual plug on the power distribution box, put some dielectric grease on it, and re-seated it. Seems to start everytime now,, we'll see how long it lasts.. but at least I KNOW where the problem is now. I was having to lay under and short the terminals on the starter while the key was left on to start it when it messed up.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #12 of 19 (permalink) Old 05-16-2009, 12:22 AM
klhansen's Avatar
My Photos: (180)
You must be psychic, Jim, to find just the right spot to poke and prod. Or was it just the last place you poked around? Electrical issues like that can be a bugger to find. Yours might be a wire terminal that's come unlatched and has backed out of the connector.
), AIS,
regulated return,
klhansen is offline
post #13 of 19 (permalink) Old 05-16-2009, 11:41 PM
JimTJr's Avatar
My Photos: (20)
I was kind of concentrating on the area behind the starter relay. And it was there. I did tug on those 6 or so wires, all pins seem to be locked in.
I don't know if it will reoccur or not, but if it does, I KNOW where to look now! LOL
JimTJr is offline
post #14 of 19 (permalink) Old 10-17-2009, 10:42 AM
How did you take out the play?
I believe I'm having the same issues. Here's the thread.No start unless I jump it
1999 F250, 7.3L ext cab
7.3L Tacklebox is offline
post #15 of 19 (permalink) Old 10-18-2009, 02:23 AM
To determine if it is the park safety switch, try starting the truck in neutral. If it starts, run your gear selector in and out of park a few times. There is a little electric switch in the steering column that can get oxidized and cause the problem, but a little friction on the switch from repeated movement will give you good contact. That's what did the trick in my case.
CarTotem is offline
