leaky exhaust manifolds - Diesel Forum - TheDieselStop.com
Old 11-03-2009, 11:02 AM   #1 (permalink)
Gustad2005's Avatar
My back cylinders on both sides are leaking, theres a good amount of soot around the back port. I have a loud exhaust noise under load and in the morning while driving unloaded but goes away once warmed up. I crawled under and noticed the rear exhaust bolts were not tight. So I tightend them down and still leak. I have read alot of posts and in the air as what to do. Either install gaskets, new manifolds, resurface existing or ceramic coated manifolds. Any suggestions?
2001 F-250 4X4 LARIAT Crew Cab,7.3, ZF6
WOP GQSSB, Carson S. T4i kit, Valair Ceramic/Kevlar
Clutch GEARHEAD TUNES!, ADRENALINE, ITP RR w/ Fuel Bowl Delete, 5" exhaust, AFE Stage II,
Isspro EV2 Gauges, Leveled
Gustad2005 is offline
Old 11-05-2009, 12:22 PM   #2 (permalink)
Gustad2005's Avatar
Anyone?
Old 11-05-2009, 12:45 PM   #3 (permalink)
ford_doctor's Avatar
Some leakage is typical but a leak is a leak. Usually installing the gaskets is the simplest and least expensive option. I say "usually" because you never know when you will encounter a seized bolt that breaks or a manifold that is unknowingly rotted away. Consider new bolts with the gaskets on this project.
Ford Master Diesel Technician
Diesel Technician Society
ford_doctor is offline
Old 11-05-2009, 03:23 PM   #4 (permalink)
fxdwgi's Avatar
A exhaust manifold gasket on a 7.3 ??
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 11-05-2009, 07:14 PM   #5 (permalink)
Gustad2005's Avatar
Are these numbers the right ones?
For the gaskets
Ford F4TZ-9448-A
Int'l 1814219C1
For the bolts:
Ford W301160
Int'l 1844517C1
Old 11-06-2009, 06:10 PM   #6 (permalink)
amberjax's Avatar
Anyone have the torque specs and sequence of the manifold bolts on the 7.3? I have the service manual on DVD, but can't seem find either.
NEW TRUCK: 2002 F350 CC,Short Bed, Dually w/ 7.3L, Air Raid intake, 3 gauge pod w/ISSPRO V2 gauges, Overhead gauge mount with DP Tuner gauge switch, DP F6 tuner w/stock, 1300 hi idle, 80 econo, 120 race, 40 & 80 tow and decel tunes. 4" turbo back Magnaflow exhaust.
http://community.webshots.com/album/576806969VrqaZx
OLD TRUCK:97' F250 4x4 crew cab. 4:10 gears,High Idle mod, Dana 60 conversion using 3"SKY RSK w/03' SD springs and 3 3/4" rear blocks to level. Tymar, Issopro gauges on 3 gauge pod, 3" down pipe, shimmed FPR and DP tuner 6 pos. chip (12-13-07).
http://community.webshots.com/user/amberjax
amberjax is offline
Old 11-06-2009, 07:08 PM   #7 (permalink)
woodnthings8's Avatar
Exhaust manifold bolt/nuts get torqued to 45 ft/lbs
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 11-09-2009, 12:43 PM   #8 (permalink)
Gustad2005's Avatar
Thanks good to know!
Old 12-10-2009, 12:13 AM   #9 (permalink)
78Southwind's Avatar
So how did you end up fixing it? Gaskets/Bolts or new Exhaust Manifolds?
2000 Excursion Limited (BUILD DATE
05/31/2000) 4X4, 7.3 PSD, 3.5" LIFT and SuperChip
78Southwind is offline
Old 12-10-2009, 03:31 AM   #10 (permalink)
Excavator's Avatar
My Photos: (11)
some more exhaust manifold repairs in this link and what I did
RUSTED exhaust manafolds
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline
