Less than .25 cent UVCH fix - Diesel Forum - TheDieselStop.com
Old 05-21-2009, 09:42 PM   #1 (permalink)
jroller's Avatar
Cool Less than .25 cent UVCH fix
There seemed to be some concern about loose change in the valvle cover with the valvetrain. Some have decided to use the zip tie method ( I didnt like the zip tie fit). Instead I made a plastic wedge. AE'd after clearing all codes and no more codes plus my cruise control works now.
Next up, lock actuators.
As you can see below I have a loose harness.
2001 PSD 7.3 auto DP Tuner, 4" TBE, KNN Intake (with filter charger), CCV Mod, DB Starter, Stancore GPR, ITP Overboost, John Wood installed valve body. External coolant filter. International Up Pipes.
1994 RAM 4x4 Cummins KNN, 3GSK, AFC Spring, #10 Plate, BD Valve Body, KDP, SCHWITZER S300 turbo 4" TBE.
jroller is offline
Old 05-21-2009, 09:47 PM   #2 (permalink)
jroller's Avatar
jroller is offline
Old 05-21-2009, 09:51 PM   #3 (permalink)
jroller's Avatar
I meased the size I wanted with a set of dial calilers just about 1.130 inches long. Cut a piece of plastic from the lid of a blue storage bin I had my stock Evolution VIII turbo sitting in.
jroller is offline
Old 05-21-2009, 09:54 PM   #4 (permalink)
jroller's Avatar
Insert said blue shim and thats it. No more nasty IDM codes.
jroller is offline
Old 05-23-2009, 03:00 AM   #5 (permalink)
klhansen's Avatar
My Photos: (169)
Good Job
You do know you can buy essentially the same fix from Ford or International for about $10 (for 3 little pieces of plastic), right?
Hard or no-start? Check Here
klhansen is offline
Old 05-23-2009, 04:14 AM   #6 (permalink)
jroller's Avatar
Originally Posted by klhansen View Post
Good Job
Yes, but I know of no dealer/ IH parts supplier that is open at 10:30pm when I decide to pull the VC off just to have a "look see." Then theres the satisfaction I get from fabricating my own fix like McGiver
jroller is offline
Old 05-23-2009, 07:48 PM   #7 (permalink)
thats awesome!! good job man...lmao
dsltek is offline
Old 05-24-2009, 02:26 AM   #8 (permalink)
Bill1013's Avatar
Fixed mine with a 1/2" long piece of 1/4"ID X 3/8"OD clear tubing, just slipped it under the locking arch. Been there for 5000 miles.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
