OK friends, here goes. (I hope I can make this clear to ya'll)
The transmission in my 2001 F350 dually has a mind of her own. (Just like most females, including me) She has a leak. There is no doubt about that. It seems to be coming through the inspection plate, and at times, she shots a fine stream of fluid. The strange part is, she does not leak when idling or when I 1st start her up in the morning to go to work. She only does this when she is hot and driven for some time. [img]/ubbthreads/images/graemlins/confused.gif[/img]
The Ford dealer here says it is some kind of seal and they want 900.00 (low end) to fix it.
Another dude, locally, says it is the enternal pump inside of transmission, it isnt holding pressure so this is why the leak. We need to replace whole transmission. Cost anywhere from 1800.00 to 2100.00 plus labor.
I do not trust these above dudes, but I do trust ya'll. You nailed it correctly on the CSP, or however u say that. Please help me now. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
01 F350, fully loaded Lariat, Super duty, long bed, dually, 7.3 PSD, She is fire engine red, that's why we call her "Fire" She hauls a 6-horse gooseneck trailer.
Re: Lex is back with a Transmission problem. HELP!!!!
[/ QUOTE ]i had the same problem. is ur fluid burn if so there is a good chance ur tranny is burning up and the heat making the fluid rise and break the seals. atleast thats what happened to me. anyway i got a new one for 2500 and it was a heavier t/q and shiftkit. im so happy now.
[/ QUOTE ] is ur fluid burn
no, the fluid is clean.
This trouble started last Saturday, the 14th.
Add any fluid to it lately? Sounds like it might be over filled and spewing out of the dipstick. Just a reminder that the fluid is checked with the engine running.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Lex, I also haul valuable livestock with a heavy head to head GN trailer and there is only one place for you to get your transmission. BTS. It is late on Friday afternoon but I would call Brian at Brian's Truck Shop (870-422-FORD). Talk to the man. Your tranny may have enough legs to make it to Lead Hill AR. Go and get a 6.0 cooler and new TC/tranny if Brian says that is what you need. There is no comparison to stock. I have not towed with mine with a fully loaded trailer yet but my tranny temps have not hit 170 yet this summer. Brian's reputation is everything you hear about and then some. Your horses are not worth taking a chance on. It will cost more than you have been quoted but you will then have a tranny that you will want to take with you to the next truck. Search on "BTS" and you will find many many satisfied customers. Do not fool around with anything less.
On edit: He may be able to ship one to an installer he trusts near you and then you would not have to travel so far. With the price of fuel that would save quite a few bucks.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
LOL, hey how did you know I am a blonde? [img]/ubbthreads/images/graemlins/bleh.gif[/img] but I do know she needs to be running when checked. LOL I changed filter and fluid 2 days ago. Okay, I didnt actually do the work, but I did hand tools and the beer. [img]/ubbthreads/images/graemlins/wink.gif[/img]
BTS. It is late on Friday afternoon but I would call Brian at Brian's Truck Shop (870-422-FORD). Talk to the man. Search on "BTS" and you will find many many satisfied customers. Do not fool around with anything less.
What is BTS? oh oh never mind, is it Brain's Truck Shop? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
YEP,, and if you need a rebuild, that is one of the best places to go,, A good drive for you, but WELL WORTH it!
Call him and see what he says, if your have something simple, he will guide you in the right direction....not mislead you in anyway for sure.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics!'03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
He's right, it's the front seal.
He's looking to make a lot of $$$$.
It is possible that you need a rebuild, especially if you have a lot of miles. But if it works fine other that the leak, you can probably get away with just changing the seal. Now that does require removing the trans and a partial teardown to change it, so $900 doesn't sound out of line.
Thank you for the post thus far. I'll keep checking in to see if anything new is left.
I am still here, waiting for more replies/suggestions. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Hey Lex,
I would recommend giving Brian a call at BTS and let him know what is going on with your trans. He will help find the problem and will make sure you do not get burned. Brian walked me through fixing my old trans without charging me a dime.
When I finally decided to upgrade I went with the full BTS set up. I now have over 100K of hard miles on my BTS and it still shifts like the day I installed it.
Good luck....
If you live in AZ come join us at Arizona Powerstroke Group... Click here http://www.azpsg.com/index.php?referrerid=6
99.5 F-350 BTS Trans / Termys / Swamps 200/30 AA Injectors / Swamps IDM / GT38R BB Turbo / AFE Stage 2 / DP/ Evans Coolant, ART Rotors / Dynatrac Spin Free HD Front Hubs, 4 inch Stainless Exhaust, Auto Meter Cobalt Gauges.
How many miles on your tranny?
Pump does not usually make seal leak.
Can cause sloppy shifts, slipping, slow shifts.
Can also cause TC and clutches to shed material too.
Pump seals do go bad without over heating the tranny fluid.
If they pull tranny to fix seal might consider a new TC while it is off as more times than not the TC go out before the rest of the stock trans.
Tim
2001 F-250 Crew Cab, short bed, 4x4, 4R100 with VB tuned by Travis's Automatic Trans, Lariat, Snugtop shell, Line-X bedliner, 265/75/R16 GY Silent Armor. DIY open element air filter. DIY 4 inch exhaust, from stock DP back to 45 degree turn down. Quadzilla Recon XZT moniter- EGT, Trans temp, Boost. DP tuner Stock, 40T, 40T high altitude, 80E, Curt MFG Q5 20K slider hitch, P3 brake controller, ATS housing. Blue Bullet
Sold-- Bright RED 1996 F350 XLT, 4X4, CC, 4.10 gears ,E40D, SRW, Rebuilt E40D at 190K with a 3yr/36K mile warrenty, by Travis's Auto Tranny 719-574-8104. Big Red
Proud Member of the NRA, helping to protect our American Rights!
i had brian ,[bts] ship me one, believe me you will have no more worries.
as haulin horses said ,your horses are worth it.
99250
early 1999 ,f250,psd,s/cab,7.3,3.73 ,4*4,short box
harvest gold, snug top cover,xle 4 ,ais filter, bts trans ,
isspro pyro ,trans temp guages.autometer boost
bought new from spokane,wa ,and converted to rhd in australia. sold.
forrest river wildcat, 30rlbs. sold. 06, f250, 7.3 [standard out of brazil factory] bts valve body,tuned by cale at bts.firestone air bags on rear.coolant filter ,isspro trans,temp, boost, pyro guages.
cougar , 5er model 309, fitted with full air brakes.,trail air hitch
Thanks for the new posts. I will give BTS a call on Monday and see what he says.
As for now, there is no metal in fluid, she shifts smoothly still, no slipping. She has 131k miles on her and runs great except for the leak.
Time for me to get to work. Tractor is calling my name. I'll check back this evening.
Again, many many thanks for ya'lls input.
Peace,
Lex (Sheryl)
