I'll take a crack at it. If it is like turning off the ignition with all relays de-energizing, than it would not seem to be the ICP, CPS, IPR, or any other sensor. They sent info to the PCM, which controls everthing according to what they send. They do not control the relays. Your ICP might have been bad to begin with, and the truck will run without, not well , but will run.
Have you payed particular attention to anything that DOES work when this happens? Any dash lights, heater fan, radio, etc. It does sound like an electrical problem, be it a ground or power wire. The PCM controls alot of relays, including the fuel pump and IDM, which would be like shutting the truck off. Try taking a good look at the PCM relay and ground for it. Try wiggling it, tapping on it, grabbing the wire harness there and move it to try to recreate the problems.
99.5 F350 SRW 7.3PSD 6SP CC 4x4
<span style="color: red"> autometer pro-comp pyro-n-boost, wicked wheel, Reg return, AIC mod, Exhaust brake mod </span>
banging on all 8 since 11/24/06
Tom
Hmm, that is strange. I agree it's a gremlin, and you need some gremlin exterminator spray. [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
If you can hang a voltmeter on the ignition switch "run" output wire and observe that, it may tell you something. It could be that your ignition switch is going bad. If the voltage drops when the engine cuts out, then you've got your gremlin. That wire controls all the "hot in run" circuits, so would kill the fuel pump relay, PCM and IDM power relays, ect. if it lost voltage.
tlutman,
I agree it just doesn't seem like a sensor,but at the same time it doesn't happen on rough roads or during vibrations which would make me believe it's not a connection issue. I do though hear the relays under the dash click off when it dies.
Everything on the cluster still works except the tach and oil pressure instantly drops to 0. Radio and everthing else is not affected.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: WaveEater</div><div class="ubbcode-body">tlutman,
never had a ses light come on abnormally </div></div>
Sounds more like the ignition switch all the time.
4 separate circuits come out of the switch that are hot in "run".
If ckt 1000 is intermittent, then the PCM would shut off when it drops out, meaning the SES wouldn't work, Fuel pump relay would drop out, tach would quit working, etc. Just like you had shut off the key. All the other circuits could still be powered.
Wouldn't necessarily take a rough road to cause the switch to open a circuit. Could be heat buildup across a burnt contact, etc.
Don't write it off without checking. A test light hooked to that circuit would be a good indicator.
Heres your problem, I have seen/repaired 3 of them now, The ICP plug needs to be replaced.
The ICP plug will become saturataed with oil and it loses it connection, I have seen a couple get water in them and it corrodes the electrical connection, YOU HAVE to change the connector, I cut mine off and got one from Ford, and soldered it on and heat shrink the wires.
If you lock close at the plug connector terminals you will see corrosion on the terminals, you can scrap them with a toothpick or Xacto knife..
What technically happens is the ICP loses connection with the PCM, and dosen't give the PCM a ICP parameter, so the PCM says that is out of range and then shuts down the engine.
Have seen this a couple of times, especically when its high humidity out...
2000 F250 SC 4A SB OEM TC, OEM Trans, OEM Turbo, OEM Injectors, OEM Airbox, OEM CAC, Quad Pod W/4 Autometers, 3 Guage cubby-hole, Jody-isized, Fuel System Mods, Mag Hy-Tec, Schaefers 9000, Transgo, Interior is soundproofed, 3.5" DP SS XL Magnaflow, LPG, 106k miles, NVK5 to MNMO, 2200 WATT BI-AMP, 18"s, Best MPG-22.80, Best MPT-760 miles.
FORD-DIESEL.COM MODS--Heater Hose Cutoff Valve, T/C lock, EBV brake, MIAH Plug, QD's removed, Wrapped CAC Tubes, Double Clamped Coolant Hoses, Zoodad, Relocated License plate, painless fuse box. Other RSB Mods
388HP 818Ft.Lbs.@ 130MPH. 4th gear dyno run, 2.1 60, Home-Made Traction bars.
This is a Street truck, 18+MPG(No LP), 14.2 at 98mph, 13 sec Motor, 14 sec Truck(NO Traction)
2004/03 CC SB Auto 6L W/OCT flash, 19+MPG, 20%Bio, AFE, Magnaflow XL SS 4" Exhaust, 75K, Heater By-pass mod, 21.1 MPG best.
2006.5 Jetta DSG 14K 41MPG Best
2005.5 VW Jetta 1.9 TDI 49MPG Best 73K
Kubota 7800 30 HP Hydrostatic 4X4
All Diesels
1969 Mach1 351C 4M 9"
I agree with Mach1. Years ago I read here where a Ford mech said these trucks come in all the time with these exact symptoms. He recommended putting permatex on top of the ICP plug where the wires go into the plug. Water and dirt go down in the plug from the top and make for a bad connection over time.
I had a problem with my 02 6 months ago where the thing would just quit going down the highway. Like turning the key off. Thought CPS at first and changed that. After a week of the problem, I bought AE and found cranking oil pressure was only 165 and not the 500 psi the injectors need to start. It was the coil part of the IPR. After the motor got hot, it quit. After it cooled off for an hour, it would start and run 10 minutes. Bought a new IPR and that did the trick. Placed the old coil part of the IPR on a buddy's truck to confirm, and his quit too. Found a new IPR on eBay for 105.00.
Bill
'02 Black C/C Dually, Auto, Sonnax valve, Tricumulator springs, 3.73, Issopro EV gauges, Cyclops, Racor crankcase breather filter, Evans Coolant, coolant filter, Line-X, Michelin XPS Ribed, Reflashed to VDH4, Dahl fuel filter, Fuel tank mod., H/X mod, 203* T-stat, Power elbow and 6" Grand Rock Aussie Stacks.
Thanks I put a couple LEDs on the red/black wires to check and see if the voltage drops out at the switch. It sounds like the most logical solution so far.
I can't see why it would be a bad ICP connection When unplugging the whole connector makes no difference. I could see that it may have possibly been shorting out across the oil in the plug, but now the plug is dry there is no way corrosion would cause a short, only an open.
IF it was the IPR or the fuel pump or fuel pump relay it would run rough and sputter before dieing and it would have to be running first of course
Let me explain a little further, when you unplug the connector, the PCM sees no input and defaults to limpmode, which I believe is 800 psi, enough to limp home. When the PCM sees a high/low resistance, it says something is out of the normal range and shuts the engine down. Then there is the resistance within the range and the truck drives normally.
TECHS use this method to diagnose ICP problems (under certain conditions), If they think it is ICP related(before getting the Computer out to diagnose) some will unplug the harness to see if it will start.
This problem is getting more and more common as the wiring harness loosens up and moisture penetrates the connector and corrodes the wire terminals..
Tip--unplug yours and look very cafefully at the terminals.
Or put the AE software on there and monitor the ICP.
All Diesels
I just finished replacing the last part of my particular series of issues (see previous post in this thread), and everything seems fine. I have replaced the glow plugs, the inside-the-valve-cover harness (it needed it 'fer shur'), the valve cover gasket, the outside-the-valve-cover-gasket wiring harness (which came with the glow plug relay, or whatever it's called, already installed), the intake system rubber (with the adapter kit), and a new CPS. So far, so good. I plan on replacing the ICP when I can, and I will post the parts list and prices when I am confident that the system is good and all is well (finally). Mine is a '97, and I am told that it is a transition year. The first run at an external harness was priced at $950, but my parts man at Ford (thanks, Ray) talked to an old mechanic and got a new reference that brought that price down to around $500 with the relay in the harness. I buy from International when I can, but sometimes there is no other option.
Something to try.....worked on a 95 Jimmy with the exact symptoms (relays click when the truck stalled, would reboot the PCM while driving, sometimes a complete stall, sometimes flashing airbag/SES/Batt lights and no power and then would magically go away).
Spray your ignition key and lock with WD40 and work it back and forth in the ignition. You wouldn't believe the crud that accumulates in the ignition switch amongst the tumblers and all.
Only ever had to do it once, never had the problem again.
i have a truck that is starting to quit going down the road...reading all the possibilites ...this truck had its ignition key assembly fooled with to silence the warning bells.. did you guys ever go in there to silence the bells ?? could it be that messing in there [ignition switch] is coming back to haunt ?? i remember when the silencing of the warning bells thing was the thing to do and the means of doing it became better and better as the understanding of how it worked increased.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: aridzone</div><div class="ubbcode-body">i have a truck that is starting to quit going down the road...reading all the possibilites ...this truck had its ignition key assembly fooled with to silence the warning bells.. did you guys ever go in there to silence the bells ?? could it be that messing in there [ignition switch] is coming back to haunt ?? i remember when the silencing of the warning bells thing was the thing to do and the means of doing it became better and better as the understanding of how it worked increased. </div></div>
Several possibilities and not enough info. Start a new post and tell us all you can and we'll see if we can get it fixed for you.
