Locating coolant leak - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 11-13-2011, 05:59 PM Thread Starter
Surlyman1's Avatar
This weird coolant leak is driving me nuts. I first noticed it from under the truck. There was a coolant trail coming from the de gas bottle hose to the radiator. Easy fix, just tightened the hose clamp at the de gas bottle and problem solved. Now there is another coolant leak and here are the symtoms: Coolant on top of the water pump near the thermostat housing.
Coolant dripping off the lower radiator hose and de gas bottle hose.
Coolant running down the passenger side on the front of the engine/oil pan area.
I checked everywhere and couldn't figure out the leak. I cleaned all the coolant off and ran the truck for about 30min then drove for about 30min. No leaks! What the heck?! I just want to know if I need a water pump or if the thermostat housing is leaking. Any suggestions?
Surlyman1 is offline
post #2 of 18 (permalink) Old 11-13-2011, 06:17 PM
RT
RT's Avatar
If it is above the water pump, it would almost have to be coming from the thermostat housing, the upper hose(s) or the degas bottle. You could have a cracked degas tank - might be worth pulling it and cleaning it up really good. Never hurts to pull the thermostat and clean everything up - replacing the o-ring, of course. If it really is hard to find, get a bottle of UV dye ( Quest/8 oz. cooling system UV dye with measure and pour (385) | UV Light and Accessories | AutoZone.com ) and a cheap UV flashlight. Run it for the shortest amount of time you think necessary to leak some coolant and then go hunting - at night in the dark makes it easier to find the dye.
RT is offline
post #3 of 18 (permalink) Old 11-13-2011, 06:42 PM Thread Starter
Surlyman1's Avatar
I'll get some of the UV dye and get to it this coming week. I tried to check the weep hole with the wife's compact mirror (LOL) but couldn't really get a good angle to see it. I replaced the thermostat with a dieselsite 203 degree and the billet housing about a year ago. I was thinking that maybe the water pump was leaking so bad that the fan was blowing coolant on top of the water pump. The truck has about 140k on the original water pump. A friend of mine who used to work at a ford dealer said that you should get about 160k out of a stock water pump. I'm just concerned because I'm back and forth to school every 2 months. School is 7 hours away with lots of long stretches of nothing.
post #4 of 18 (permalink) Old 11-13-2011, 08:29 PM
RT
RT's Avatar
As cheap as waterpumps are - and considering the upper and lower hose housings go to the pump, I'd swap it out. Beats getting stuck in the middle of nowhere. Good time to do a flush and upgrade to a good extended life coolant (if you are in the 99.5+ year range)
RT is offline
post #5 of 18 (permalink) Old 11-13-2011, 08:46 PM
F350_6's Avatar
I've heard of the billet housing leaking before. Did you use any RTV with it or just the gasket? The best time to look for a leak is when the engine is hot. You might be able to see a small drip, even if it doesn't hit the ground, when the engine is hot and the coolant is pressurized.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 500,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
post #6 of 18 (permalink) Old 11-15-2011, 11:23 PM Thread Starter
Surlyman1's Avatar
Found the leak today! Billet t stat housing is leaking at the base and the water pump is leaking from the weep hole. Getting ready to buy a new water pump. I hear GMB and Airtex are good. Any suggestions?
post #7 of 18 (permalink) Old 11-15-2011, 11:32 PM
RT
RT's Avatar
Airtex is OEM supplier - RockAuto has good prices.
Here's a code for 5% off
68680765701298
Using Your Discount Code
Enter the code above in the "How did you hear about us" line of the shopping cart. If you are using our traditional HTML catalog, please click the "Apply" button to the right of the field. Your discount will automatically appear, subtracted from your order total.
Please note: We sometimes get calls from people who put the word "discount" in front of their code and do not get the discount. Please enter ONLY the discount code, no other words or numbers.
The discount takes 5% off our already-low prices. There's no limit on order size or the number of orders. Use the code for your next order, and share the code with friends, neighbors, relatives, the guy at the corner garage--anyone you know who works on cars or trucks.
RT is offline
post #8 of 18 (permalink) Old 11-15-2011, 11:49 PM
ajohansson's Avatar
International who made your engine, and who's engine your Ford cooling system was designed around, recommended a Heavy Duty Extended Life Coolant (HD ELC) for all 2/2/99-up built engines (SN 940614-up). After this build date they began to use a sealant in the injector cups that was compatible with the Organic Acid Technology that the ELC coolants use. These are generally red coolants with operation lives of 300K-750K miles/6-8 years, depending on brand. They are very robust and require no maintenance or additives. Popular brands include International's Fleetrite ELC, Shell Rotella ELC, CAT ELC, Chevron Delo ELC, Peak Final Charge, Prestone Heavy Duty ELC, Zerex Extreme Heavy Duty, etc.
*Tip* Due to International's compatibility tests, all pre-2/2/99 build engines (pre-SN 940614) should use a conventional coolant with the addition of SCA (or a pre-charged conventional coolant already charged with SCA). Most conventional coolants will be green, "low-silicate" and meet ASTM D4985. There are too many brands to list. They will require the addition of a supplemental coolant additive (SCA) at initial fill and maintenance of that SCA thereafter. Most pre-charged conventional coolants will be pink, purple, or blue and meet ASTM D6210. These coolants do not require an initial dose of SCA, but will require SCA maintenance thereafter. These are coolants like Peak Fleet Charge, Prestone Heavy Duty, Zerex Precharge, Shell Diesel Ready, Fleetguard Fleetcool, Fleetrite Fully Formulated, and so on.
Now many folks with OBS and Pre 2/99 build 7.3's have used the ELC without issue but there are those that have had the issue International worried about with the injector cup sealant eroding. I got all this info off of FTE.
1999.5 F-350 CC-SB 4x4 - 7.3 liter
2003 Excursion 4x4 - 7.3 liter -
ajohansson is offline
post #9 of 18 (permalink) Old 11-16-2011, 12:32 AM Thread Starter
Surlyman1's Avatar
Just ordered the airtex. The code didn't work but I do have to order a few more parts and rock auto was cheaper than e bay.
post #10 of 18 (permalink) Old 11-16-2011, 12:38 AM Thread Starter
Surlyman1's Avatar
Switched to ELC last year and added a coolant filter. This will also give me a chance to fix my radiator drain. Hopefully the new water pump will last another 140k!
post #11 of 18 (permalink) Old 11-16-2011, 07:20 AM
A cooling system pressure tester is a tool you may not use very often but is invaluable for finding those small leaks that drive you nuts. I found a used one for $40. A new one is around $75.
2001 F-250 XLT 4X2, 7.3L, 4R100, 158,000 miles
Cat ELC, ScanGauge II, SC 1705, Dahl fuel filter
Dieselsite transmission and coolant filters
Hawk LTS pads, Ford Severe Duty AIS, Isspro EV2 gauges
Uncle Salty is offline
post #12 of 18 (permalink) Old 11-16-2011, 09:49 PM
lance1955's Avatar
Also, check the condition of the thermostat housing bolts once removed if they are rusted, my advice is replace them. You can take one with you to napa and they can match it up its ok if its a hair longer.
Found out the hard way when my pump went south the bolts snapped when I tried to remove the tstat housing. Just FYI to ya
2002 Excursion 7.3L 200K+, After market tranny cooler, diesel site transmission filter kit, coolant filter kit and complete boot kit, bilstein shocks. Original transmission with mobile syn ATF
lance1955 is offline
post #13 of 18 (permalink) Old 12-08-2011, 10:35 PM
The dieselsite housing only fixes half the problem. As you've found out, the poor Ford square cut o-ring causes as many leaks as the weak housing does. The kit below corrects the problems with both the housing and o-ring.
T-Stat Housing Ring
Shawn
96 Roll-A-Long F-350 4x4 Crew: 110,000 miles, built E4OD, 1.0 housing, and 3"x4" down pipe.
AZStang is offline
post #14 of 18 (permalink) Old 12-11-2011, 10:57 PM Thread Starter
Surlyman1's Avatar
The new pump is in! The old one was trashed! The impeller was starting to dig into the water pump housing and the bearings were gone. Removing the fan clutch wasn't as hard as everyone makes it out to be. The guy on youtube using an air hammer is an idiot. Hopefully I'll get another 140k out of the new pump. And I got the thermostat housing sealed up. No leaks so far and she runs great! Thanks to rock auto for getting the parts to me so fast.
post #15 of 18 (permalink) Old 12-12-2011, 12:03 AM
klhansen's Avatar
My Photos: (180)
You can say that again. The proper tool makes it easy and doesn't damage things.
Glad you got it fixed up.
Mine's going in soon for a leak from the coolant into the oil pan. I think we've narrowed it down to the front cover gasket where it connects to the block, or the front cover itself. Drove it today with some UV dye in the coolant, for diagnosis and it lost about 1 gal coolant in a 10 mi or so test run. Only leaks when it gets warm and apparently at higher rpm's (faster WP speed), as it hadn't dropped coolant level in over a week just sitting. First time I'd driven it in over a week. It was a short respite from the withdrawl symtoms, but not all that satisfying.
), AIS,
regulated return,
klhansen is offline
