Looking for torque/hp chart for 2001 7.3L PSD - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 11-30-2007, 12:39 PM Thread Starter
I'm looking for a chart showing torque and horsepower over the entire RPM range for a box-stock 2001 7.3L PSD engine with an automatic transmission. A web link to such a chart or even a table with RPM's and torque plus horsepower would be fine.
FWIW, I believe there was a chart in the 2001 official F*rd brochure for Excursions/Super-Duty trucks.
Thanks in advance,
Richard
2001 Excursion PSD LTD 4x4
2003 VW Jetta TDI 5sp
2006 John Deere 3320
DieselFan is offline
post #2 of 9 (permalink) Old 11-30-2007, 01:03 PM
Re: Looking for torque/hp chart for 2001 7.3L PSD
Here is one. This one is lower than the one you will see in the Ford info because Fords is at the crankshaft and thie one is at the wheels. But the curves should be the same.
444-4D is offline
post #3 of 9 (permalink) Old 11-30-2007, 03:58 PM
jordanmills's Avatar
That image link is broken.
2002 F-250 black super cab 7.3 L PSD auto trans. 4X4 Lariat with a little lift and mud tires.
Veggie oil system removed while I rebuild and redesign it.
jordanmills is offline
post #4 of 9 (permalink) Old 11-30-2007, 04:33 PM
works fine for me
2001 7.3. Lariat...
muffler delete,Isspro guages,AIS,SCMT 1705,CCV Mod,Zoodad Mod
Lone20 is offline
post #5 of 9 (permalink) Old 11-30-2007, 07:56 PM
I wouldn't believe that chart. Banks propaganda. Way Overpriced but quality items. Can get the same or better results for 1/2 the price.
BTM, 10k mod, EBPV brake & torque convertor lockup, air ride 5'er hitch. 99.5 F350 dually.
fsheare is offline
post #6 of 9 (permalink) Old 11-30-2007, 08:46 PM
69mach1377's Avatar
So the baseline is wrong?
That's all the OP asked for, not your judgement on any vendor.
The 99 info may be low for a 2001 by a few...
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Super Zoodad, SC tuner, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, Billet compressor wheel with ported shroud.
Jayco 26BHS elite, no RV parks...just the woods.
69mach1377 is offline
post #7 of 9 (permalink) Old 12-03-2007, 10:17 PM
SmokeyWren's Avatar
My Photos: (45)
http://photos.thedieselstop.com/data...7_3L_curve.jpg
Basic numbers are 505 lb/ft torque @ 1,600 RPM, and 250 HP @ 2,600 RPM. Sorry for the lousy scan, but the source in the brochure is pretty awful.
Scale is 550 torque at the top, 250 HP at the top, with decreasing increments of 50 as you go down the chart. RPM scale is 500 to 3,000, with increments of 500 RPM.
SmokeyWren is offline
post #8 of 9 (permalink) Old 12-04-2007, 10:48 AM Thread Starter
Thanks much all for your replies.
Smokey, that works perfectly. What I'm looking for is where the torque plateau starts and drops off on the 2001 PSD 7.3L. Even if it might be a few pounds off automatic vs. manual, I would think the shape of the curve would be the same.
I've adapted the principals of "progressive shifting" to my driving technique where I want (as much as I can in an automatic) the truck to shift and operate on the top of that torque plateau between 1,500 and 2,500 RPM. FWIW, the trucking company I worked at beat this into driver's heads at every opportunity. The engine is most efficient, according to the experts that figured this stuff out, at lower RPM's when the torque is at the highest.
post #9 of 9 (permalink) Old 12-04-2007, 05:00 PM
SmokeyWren's Avatar
My Photos: (45)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DieselFan</div><div class="ubbcode-body">The engine is most efficient, according to the experts that figured this stuff out, at lower RPM's when the torque is at the highest. </div></div>
That's somewhat true, but not when loaded to the gills. At anything below around 1,900 RPM, you don't have enough horses to pull the load, regardless of torque. At the torque "peak" of 1,600 RPM, you'll do okay unloaded, but don't try to pull much of a load below 1,900 RPM with a stock engine.
With my hot-rodded engine, I can gross around 16k and get along just fine at 1,800 RPM, or when the road is flat as a pancake, I can even get along at about 1,750 RPM. But at 1,600 RPM there's simply not enough horses available.
