This looks wrong - can someone identify? - Diesel Forum - TheDieselStop.com
Old 03-07-2010, 04:56 PM   #1 (permalink)
2002 F250 7.3. This looks odd to me, this hose is cut off and seems like it should be going somewhere. Can someone identify this for me?
Rosswp is offline
Old 03-07-2010, 05:41 PM   #2 (permalink)
tbpower's Avatar
Make sure you MAP hose is hooked up. There should be a hose going from the map sensor to the intake spider. BTW you should enter the dirtiest engine contest.
edit: here is a pic of the map sensor: http://img151.imageshack.us/img151/3...tt73llgwd6.jpg
You will notice a hose covered in wiring loom that goes to the spider.
2000 7.3 powerstroke. PHP 6 position chip (stock,high idle,60tow,80dd,100hp,no start) . 6637 riffraff filter kit . AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. EBPV delete. Walker 21470 muffler. Riffraff FRX
tbpower is offline
Old 03-07-2010, 05:43 PM   #3 (permalink)
That barb is solid though (no hole in it). Not sure what the story is with that either.
Rosswp is offline
Old 03-07-2010, 05:51 PM   #4 (permalink)
Here is where that goes
BTW: I am not sure if it was my dog or my fan that chewed on my oil cap. I'll let you guess!
2002 Excursion Diesel-Stock owned 3 years 203k miles
Planning upgrades with the following order: durability, milage, power: 203 thermostat, Cat ELC, AIS delete, DieselSite engine and intercooler boots,
2002 VW Golf TDI-Nearly stock +taller 5th gear, LSD, 50+MPG, owned since new, 205k miles
I am 6'5" so the Golf is know as the clown car
ftboomer1 is offline
Old 03-07-2010, 05:51 PM   #5 (permalink)
F350_6's Avatar
X2 on the MAP line and X2 on the dirty engine. I thought mine was dirty.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 393,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
Old 03-07-2010, 05:59 PM   #6 (permalink)
Is that solid with brass or dried mud?
JK, JK
Old 03-07-2010, 06:00 PM   #7 (permalink)
Thanks guys - it is indeed the map sensor. For some reason it is cut off on both sides. Why would someone do that and what would be the result? Would it explain low power?
Re: Dirty - I've only had this truck for 2 weeks, no time to clean yet!
Thanks again.
Rosswp is offline
Old 03-07-2010, 06:04 PM   #8 (permalink)
tbpower's Avatar
re
Thanks again.
Yes that would explain the low power. My guess is that it broke.
tbpower is offline
Old 03-08-2010, 11:38 AM   #9 (permalink)
Wow! That is without a doubt the dirtiest engine I have ever seen. That's going to take some work to get it all clean and then fix everything that caused it to look like that. I can't imagine that just the leaking boots caused all that. That's a job I wouldn't want.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
Old 03-08-2010, 12:15 PM   #10 (permalink)
Bill1013's Avatar
Looks like it's been used as a mudder, must be up North of Tucky, otherwise it would be Red mud.
DISCONNECT YOUR BATTERIES BEFORE YOU WASH IT DOWN.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 03-08-2010, 06:03 PM   #11 (permalink)
Disconnect batteries: thanks, good point. Yeah I'm in NY. It was actually a fleet truck for a construction company previously. I'm the proud new owner at 337,000 miles. I'm hoping as a fleet vehicle it was serviced regularly.
Runs great now that I put a hose to the MAP sensor - what a huge difference.
Rosswp is offline
