Lost all of the oil - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 05-07-2006, 12:07 AM Thread Starter
Lost all of the oil
2001 f350 cc.
I was driving the truck tonite and noticed that the motor was not running smoothly. I also smelled oil. All of the temp gages were fine. Drove about 2 miles and all of the lights went dim and the truck died. When I checked the oil, there was nothing on the dipstick. Tons of oil in the vally and all over the bottom of the truck.
I am thinking that I blew a hpop plug and dumped all of my oil.
My question is; did I damage the motor or with out any oil to drive the injectors did the motor save itself?
thanks
Rich
yardape1 is offline
post #2 of 9 (permalink) Old 05-07-2006, 12:15 AM
Re: Lost all of the oil
Fortunately with the HEUI injectors, once the oil level drops approximately 8 quarts in the PSD, it loses oil to fire the injectors and the engine dies with pretty much no further damage to the engine. I wouldn't worry about it, just repair your oil leak, refill with oil and you are good to go again.
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
post #3 of 9 (permalink) Old 05-07-2006, 08:42 AM Thread Starter
Will loosing the oil have done any damage to the hpop? I was running synthetic [img]/ubbthreads/images/graemlins/frown.gif[/img]
yardape1 is offline
post #4 of 9 (permalink) Old 05-12-2006, 08:18 AM Thread Starter
It was the plug in the back of the hpop. The mech. replaced the O ring and refilled the oil. Everything seems to be ok but I think that I am noticing more blowby from my CCV mod.
Is there any chance that dumping all of the oil would have caused cyl wear?
yardape1 is offline
post #5 of 9 (permalink) Old 05-12-2006, 08:30 AM
My Photos: (5)
What BuddyM said, the injectors quit firing when your oil pressure drops below a certain point. When you loose 8-10 quarts of oil, your HPOP no longer can draw enough oil to fire the injectors. Basically this is a very good way to protect the engine from any damage. Remember that these trucks take 15 quarts, so you still had plenty for lubrication. Once you blow an o-ring on the HPOP, it only takes a few minutes at most to dump several quarts of oil, so your engine does not have time to loose lubrication.
I had this happen to me last summer, and my truck died after losing 10 quarts. It's been almost a year and there is absolutely nothing wrong with my truck. Don't worry, you are fine.
Pocket is offline
post #6 of 9 (permalink) Old 05-12-2006, 03:30 PM
Flywheel's Avatar
I agree - I helped a guy out whoe goes about 15-20k between changes and has run low on oil 3 times!!!! We just filled it up and off he went...craziest thing ever....
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #7 of 9 (permalink) Old 05-12-2006, 06:08 PM
These trucks need oil and coolant level detectors so that if the fluids
drop below a certain point a warning indicator/alarm goes off in the cab
before any damage is done. Nobody wants to clean up an oil mess under
the hood either... You'll never get it all off and the oil will attract
all the cud blowing around, making for a messy engine compartment.
--Old_Dog
2002 Ford F-350 Lariat Duallie 4x4 CrewCab 7.3-L PowerStroke, Arizona Beige with
6-speed, 3.73:1, Camper Package, Off-Road, TT power mirrors, Dual Alternators,
Reverse Vehicle Aid Sensor, Heated Captain's Chairs, Trailer Hitch Receiver, Coolant
Filter, Tranny Filter, OilGuard Bypass Oil Filter, Mag Hy-Tech Dana-80 Cover. Topped
off with a Lance-1130 camper.
Old_Dog is offline
post #8 of 9 (permalink) Old 05-12-2006, 06:13 PM
My Photos: (5)
My dad used to have an '89 F-250 with the 7.3L IDI. He went 10-15K between oil changes, only washed it once, changed fuel filters every 30K or so, air filters every 50K if he was in the mood, and generally neglected it about as much as I've ever seen. He sold it with nearly 300K on the odo, and it ran like a champ. It's amazing the punishment that some of these engines can go through.
Pocket is offline
post #9 of 9 (permalink) Old 05-12-2006, 07:28 PM
Not to worry about rings.
Main/rod bearings are first to receive oil, so you will spin a bearing first.
01'f-350
dzl wannabe is offline
