Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-31-2008, 08:33 PM   #1 (permalink)
DieselXXX's Avatar
Talking Max Boost For a 7.3 ????
Just wondering what kinda Boost you guys are making...??? 29 lbs is the most I've ever seen.....thanks.
01' F250
Edge Juice with attitude
Banks quickspool turbo with wheel
Power elbow
5" Straight exhaust with MBRP over the diff
Banks technicooler system
Banks brake and trans command
DieselXXX is offline
Old 01-31-2008, 09:33 PM   #2 (permalink)
JUSTING's Avatar
i only hit 22lbs but i have a weak tranny and the TC just slips when i try to load it up, so i don't push it to hard, but i will have a BTS in a few months, i can't wait
Early 1999 (4/98) f-250 superduty, 4x4, crewcab, shortbed.
knn intake
banks exhaust
banks turbo housing
banks power elbo
big head waste gate-disconnected
edge juice w/ attitude (just till i get a DP)
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
automatic tranny
ranch hand front and rear bumpers
pro comp 2.5 inch leveling kit w/315/75R16
JUSTING is offline
Old 01-31-2008, 09:38 PM   #3 (permalink)
31 - 32 on my truck, but thats really pressing the issue on a stock turbo.
OP, you are ALLOWED to change your userID on this board
Just eating rainbows and butterflies
01 F350 dually 4x4 CC auto.
311 hp 610 torque a while back.
My Pickup
Some Photos and Sound Clips
Diesel Power & Performance Derby Ks.
#46
Kanman is offline
Old 01-31-2008, 09:59 PM   #4 (permalink)
High PSI's Avatar
My Photos: (18)
Kanman meant to say: CHANGE YOUR USER ID ON THIS BOARD!!!!
'02 Black F350srw,Lariat,CC,SB,OR. - BTS TRANS,Coated 1.00 BB TN-non EBP-6.0 Spearco IC-DP Tunes(stock,HI,60T,80E,120R)MAP maximizer-ITP reg ret.-AirDog-Fluidampr-BWD coated/ bellowed pipes-AFE2-4" Magnaflow-Dieselsite coolant filter&ESOF SS lines-Billet/203*stat-Fleetrite ELC-Bilsteins-Hawks&Cryo's-Centramatic-Billet-Extang-Husky box-Husky Liner-EGR-LineX-Alpine-Kicker-PIAA-Dynamat-Sirius-Viper-ES Poly's-BFG 315/75/16 AT's-DTS 4.56LS-31 row 6.0 Cooler-UltraLite trans,pyro,boost-DiPricol fuel-PML pan-Mag-Hytec cover-Powerslot-Hawk. Marinco,Snowman,Harpoon,AIH,CCV,foil,door ding,console mods. http://good-times.webshots.com/album/557543120DKiWId
High PSI is offline
Old 01-31-2008, 10:06 PM   #5 (permalink)
DIESELSITE's Avatar
just over 55 lbs. right now in our 1999 F250
My poor h2e is on it's last leg right now.
Bob Riley, Owner DieselSite.com & BlueOvalSite.com
CPR Fuel Systems, Wicked Wheel, The PULSE
Proud Sponsor of TheDieselStop.com
GOT DIESEL? call us at 888-414-3457
DIESELSITE is offline
Old 02-01-2008, 09:51 AM   #6 (permalink)
31-32 i push with a banks turbo
1999 f350 build date 2/99, red, ts 6 position, banks compressor turbo wheel, banks big head wastegate, mbrp 5" with 6" grand rock stacks, diy tymar, Zoodad mod, AIH plug UPCOMING MODS: , stage 2 injectors,Stage 2 water meth injection, 95 gph fass fuel, 6.0 intercooler, ballbearing turbo, 6.0 trans cooler, and arp head studs.
fast99f350 is offline
Old 02-01-2008, 04:49 PM   #7 (permalink)
28 is my max but I watch it on hills and keep it under 25.
LeRoy
Y2K F-350 Lariat SRW SC LB PSD 4X4 Man Hubs, Auto, Leather, Harvest Gold. 50 gal in the bed xfer-flow fuel tank. Banks exhaust and stinger kit. AIS cold air intake
LeRoy is offline
Old 02-01-2008, 06:01 PM   #8 (permalink)
High PSI's Avatar
My Photos: (18)
I usually get 28 sometimes 30psi if I hold it.
High PSI is offline
Old 02-04-2008, 12:13 PM   #9 (permalink)
what are they supposed to pull from the factory?
lakejunkie is offline
Old 02-04-2008, 01:06 PM   #10 (permalink)
My Photos: (6)
turbo pressure
a stock 7.3 should be about 15# boost if you go to a smaller houseing you could see 23-25#
jakes350 is offline
Old 02-04-2008, 04:02 PM   #11 (permalink)
thank you.
Old 02-04-2008, 04:30 PM   #12 (permalink)
27 lbs of boost on the stock, but the turbo surge is bad!
2002 F-250 PSD shortbed supercab, 4R100, BTS transmission w/ 6.0 trans cooler, 285/75R17s Copper STTs, TS chip (stock,high idle,50 tow,80 tow,100,125), tymar intake, diamond eye 4 inch exhaust, isspro boost, pyro, trans temp guages, firestone ride-rite airbags, light cup-holder mod
fatyesno is offline
Old 02-04-2008, 07:58 PM   #13 (permalink)
lemans454's Avatar
What exactly is Turbo surge?
2002 F350 4X4 Short Box, Ext.Cab Welding Rig
Side exit Flowmaster, Red/Silver, BFG All Terrains, Zoodad.
lemans454 is offline
Old 02-04-2008, 08:16 PM   #14 (permalink)
Turbo builds too much boost and my wastegate keeps fluttering to try and keep it in check. Really i am building boost too fast for it to keep up....
fatyesno is offline
Old 02-04-2008, 09:04 PM   #15 (permalink)
lemans454's Avatar
Would disconnecting the red tube help?
